Parallel or series wiring when building new speakers - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 07-04-2013, 08:20 AM - Thread Starter
Audiojab's Avatar
I have a 4 ohm crossover that will send lows to a woofer, and highs to 2 full range speakers. Currently I have 2, 4 ohm fullranges which I will wire in series, bringing the resistance to 8 ohms while coming out of the crossover, and 1, 8 ohm woofer. Is a 8 ohm crossover acceptable for this, and would the load on the receiver be 8 ohms? Or should I use a 4 ohm crossover, with 2, 8 ohm fulls wired in parallel, bringing the resistance to 4 ohms, and a 4 ohm woofer. Would the resistance at the receiver then be 4 ohms also?
Thanks for your help
2-Channel
Apple iPad
Hitachi Turntable
Emotiva XDA-1
Heathkit AR-1219 Customized
Emotiva UPA-1s
Polk RTA-15TL Towers
Audiojab is offline
post #2 of 4 Old 07-04-2013, 08:46 AM
tuxedocivic's Avatar
Quoted: 2177 Post(s)
Liked: 2047
It's not that simple. For starters, I would not use 2 full range drivers to cover the treble. Even if the woofer is more sensitive, that is ok. Don't use 2.
But the biggest mistake is using just some random cross over. Thankfully it's hard to screw up a full range + woofer combination. But still. It shouldn't be done.
Impedance varies with frequency, so there's no way to know what load your amp will see. You need to know the whole impedance plot to make decisions on how your amp will handle it. For instance, suppose a speakers is 8 ohms everywhere except there's a dip down to 3ohms at 200hz. I'd say that's a difficult load to drive and a demanding frequency. If it was 8ohms everywhere and dipped down to 2ohms at 20khz, I'd say no big deal. How much demand is there at 20khz.
My youtube channel: Impulse Audio
tuxedocivic is offline
post #3 of 4 Old 07-04-2013, 08:49 AM - Thread Starter
Audiojab's Avatar
10 ohms for the full range, but I'm also looking at just doing a normal 3-way system, with the woofer, 1 fullrange, and a tweeter. Would that be better do you think?
2-Channel
Apple iPad
Hitachi Turntable
Emotiva XDA-1
Emotiva UPA-1s
Audiojab is offline
post #4 of 4 Old 07-04-2013, 08:53 AM - Thread Starter
Audiojab's Avatar
The graphs for the 3-way system I'm looking at are here.
http://www.parts-express.com/pdf/295-310s.pdf
http://www.parts-express.com/pdf/295-380s.pdf
http://www.parts-express.com/pdf/275-070s.pdf
Here is the crossover
http://www.parts-express.com/pe/pshowdetl.cfm?&Partnumber=260-210&scqty=2
This is my second pair of speakers I'm building, but my first time I'll be incorporating a crossover, so I'm somewhat new to finding a good match.
2-Channel
Apple iPad
Hitachi Turntable
Emotiva XDA-1
Emotiva UPA-1s
Audiojab is offline
