MFW15 speakers avail, or something similar? - AVS Forum | Home Theater Discussions And Reviews
Old 07-05-2013, 06:50 PM - Thread Starter
diaz's Avatar
Looking for a second MFW15, wondering if there are any floating around? Or what is a comparable 15" speaker?
diaz is offline
Old 07-05-2013, 07:46 PM
Mrkazador's Avatar
Quoted: 252 Post(s)
Liked: 378
I think the Dayton DVC385-88 can be used as a replacement.
Mrkazador is offline
Old 07-05-2013, 08:06 PM - Thread Starter
diaz's Avatar
I tried to model the DVC385, and it doesn't look right... the 390HF seems really close though, but a lot more expensive..
diaz is offline
Old 07-05-2013, 08:15 PM
LTD02's Avatar
Quoted: 2341 Post(s)
Liked: 2578
what are you trying to do with the driver?
is this for a horn?
Listen. It's All Good.
LTD02 is offline
Old 07-05-2013, 08:25 PM - Thread Starter
diaz's Avatar
is this for a horn?
Yes it will be a second horn.. haven't decided if I would build two identical horns or two different ones.
diaz is offline
