Power conditioner vs PDU - AVS Forum | Home Theater Discussions And Reviews
post #1 of 18 Old 07-07-2013, 11:48 AM - Thread Starter
Rebel975's Avatar
Quoted: 12 Post(s)
Liked: 106
Anyone ever use an APC G50B-20A2? http://www.amazon.com/APC-G50B-20A2-9-Outlet-Rack-Mountable-Conditioner/dp/B003GSLL1U
The other thing I was looking at was the Tripp Lite PDU1220. http://www.newegg.com/Product/Product.aspx?Item=N82E16882750014 - it's half the price, but doesn't have the fancy delays/screen/"filters"/etc. On the other hand, the Tripp Lite has 13 outlets, vs the APC's 9. (not that the extra outlets is a big factor or anything - 9 is plenty).
I was also looking at the Belkin PF60, but it seems to be a crap shoot whether they send you the rack ears or not.
Would the APC be worth it over the Tripp Lite? Or, is there another product I should be looking at in a similar price range? Whatever I get needs to be rack mountable.
Note: I realize that the "filters" in the APC unit don't really do anything to improve audio/video quality. The main reason I was looking at it is that it can be used to turn everything on/off simultaneously, and it will even delay the amps a bit. Unfortunately, a few of my things don't have 12v triggers, so it would be nice to have a master on/off button for my system.
Thanks guys.
Rebel975 is offline
post #2 of 18 Old 07-07-2013, 12:51 PM
Bill Fitzmaurice's Avatar
Liked: 4631
http://www.racksolutions.com/rack-power?gclid=CK-umYKGnrgCFcWZ4AodJkQAJQ
If they ain't got it you don't need it.
Bill Fitzmaurice is offline
post #3 of 18 Old 07-07-2013, 01:04 PM - Thread Starter
Rebel975's Avatar
Quoted: 12 Post(s)
Liked: 106
20a, 8 outlets for $65 is pretty nice, but what about the on/off thud when the amps aren't delayed?
Rebel975 is offline
post #4 of 18 Old 07-07-2013, 08:55 PM - Thread Starter
Rebel975's Avatar
Quoted: 12 Post(s)
Liked: 106
Rebel975 is offline
post #5 of 18 Old 07-09-2013, 06:22 AM
Martycool007's Avatar
Quoted: 280 Post(s)
Liked: 176
You do not want to plug an amp or receiver up to a surge protector or power strip as that can restrict the current flowing into the amp. You are much better off just plugging in your Bbluray Player, TV, Cable Box, ect...just no amplifiers or receivers. For the amp & receiver, just plug them into a wall outlet on a dedicated 20a line. If you really want to make things better, have an electrician come by and run a dedicated 20a line for your amps and/or receiver. Then, and only then, if you want to really protect everything in your home, have an electrician install a whole house surge protector.
Martycool007 is offline
post #6 of 18 Old 07-09-2013, 10:42 AM - Thread Starter
Rebel975's Avatar
Quoted: 12 Post(s)
Liked: 106
Surge suppression wasn't my goal here- hence me looking at what are basically 20a splitters (the PDU's). I think what I'll do though is build a couple 12v relays for the amps, and then put everything else on one a 15 or 20a PDU.
Rebel975 is offline
post #7 of 18 Old 07-09-2013, 11:11 AM
Bass Enabler
Scott Simonian's Avatar
Quoted: 5285 Post(s)
Liked: 4168
Hmm. So what does one hook up saaayyyy..... ten amps? Not enough nearby wall outlets for that, I'll tell you. wink.gif
Scott Simonian is offline
post #8 of 18 Old 07-09-2013, 11:13 AM
N8DOGG's Avatar
Quoted: 967 Post(s)
Liked: 1038
If you have 10 amps and they are plugged into a surge protector, that person deserves a dropkick to the lips..... tongue.gif
N8DOGG is offline
post #9 of 18 Old 07-09-2013, 11:16 AM
pauleyc's Avatar
Liked: 24
If it only draws 10 amps then its not a respectable amplifier and you can go ahead and plug it into the power strip tongue.giftongue.giftongue.giftongue.gif
N8DOGG likes this.
pauleyc is offline
post #10 of 18 Old 07-09-2013, 12:09 PM
Bass Enabler
Liked: 4168
Well.... I don't plan on using a 'surge protector' but I'm gonna have to use something! tongue.gif
post #11 of 18 Old 07-09-2013, 01:23 PM - Thread Starter
Rebel975's Avatar
Quoted: 12 Post(s)
Liked: 106
Seriously though, I don't see how a 20a PDU can be a bottleneck to a 15 or 20a service.
Rebel975 is offline
post #12 of 18 Old 07-09-2013, 02:36 PM
N8DOGG's Avatar
Quoted: 967 Post(s)
Liked: 1038
Scott, you have no way to run some new lines for plugs? You'd only really need to run 3 lines and could have 6 plugs. 2 amps per plug would be perfectly fine. The cost would be not a lot more other than the wire, plugs and breakers. Maybe $150 extra plus the time of the installer (which would be minimal)
N8DOGG is offline
post #13 of 18 Old 07-09-2013, 03:07 PM
Bass Enabler
Liked: 4168
Trust me. I know. Can't happen. Not at this house, unfortunately. The system as a whole will be power limited but thankfully it will be mostly >100dB/w over the vast majority of the audible bandwidth.
Sorry to threadjack but I am looking into similar devices right now. redface.gif
post #14 of 18 Old 07-09-2013, 04:12 PM - Thread Starter
Rebel975's Avatar
Quoted: 12 Post(s)
Liked: 106
You're not threadjacking if it's related to the original subject. I mean, we even have the same amp (CV5000).
Rebel975 is offline
post #15 of 18 Old 07-09-2013, 05:37 PM
Liked: 4631
You do not want to plug an amp or receiver up to a surge protector or power strip as that can restrict the current flowing into the amp..
Power strips and surge protectors don't restrict current flow, so they're OK. Active 'power conditioners' can restrict current flow, and that's why if mentioned at all by amp manufacturers they say do not use them. Whatever 'conditioning' of the AC that's actually required is accomplished by the amp power supply anyway.
post #16 of 18 Old 07-09-2013, 05:55 PM
Bass Enabler
Liked: 4168
Yes. Yes we do. Although I'm stacking on six ep2500/4000's and three Samson SX1200's. Oye! redface.gif
post #17 of 18 Old 07-09-2013, 05:58 PM
N8DOGG's Avatar
Quoted: 967 Post(s)
Liked: 1038
You'll likely be able to run 3 ep's on one 15 amp breaker without much trouble. I ran 3 in my old place on a 15 amp and pounded tunes, the breaker tripped 2 times in 4 years.
N8DOGG is offline
post #18 of 18 Old 07-09-2013, 06:26 PM - Thread Starter
Rebel975's Avatar
Quoted: 12 Post(s)
Liked: 106
I think the best option for me would be to build a 12v triggered relay for a 20a PDU, and use my pre/pro to activate/deactivate it. That way, all I need to do to turn on the system is turn on the pre/pro, and I'd avoid any on/off thumping issues.
Anyway- thanks for the responses.
Rebel975 is offline
