0db way to loud? - Page 3 - AVS Forum | Home Theater Discussions And Reviews
post #61 of 64 Old 07-16-2013, 05:30 AM
DiscoDuck's Avatar
Quoted: 14 Post(s)
I thought I heard somewhere it was good to calibrate to 85dba for each channel playing the test tone with the volume at 0.
Sr7009 + external amp for 9.3.4
jbl - northridge x11; sp6cii ceiling
Dayton HF15 sealed x2 on xls1500
av123 mfw15 w/ bash 300
DiscoDuck is offline
post #62 of 64 Old 07-16-2013, 05:58 AM
kgveteran's Avatar
Quoted: 437 Post(s)
Liked: 165
I enjoyed 0db, but really enjoyed -10db better, not all the time, but most of the time :0)
kgveteran is offline
post #63 of 64 Old 07-16-2013, 05:59 PM
absolootbs's Avatar
Quoted: 18 Post(s)
Liked: 27
depends on what level your receivers test tones are. a correct calibration should result in a 0 dbFS (bandwidth limited, yadda yadda yadda) signal being 105 db at the listening position when the volume is set to 0 db. if the receivers test tones are -20 dbFS then you should calibrate to 85 db at listening position with master volume set to 0. if they're -30 dbFS... 75 db. in my experience, most receivers tones are -30.
absolootbs is offline
post #64 of 64 Old 07-16-2013, 06:00 PM
maxmercy's Avatar
Quoted: 63 Post(s)
Liked: 168
KG,
Good observation. DynEQ does a pretty good job of things, but it is not the same thing as 0dBRef. I use a certain scene for people to tell the difference. IN Transformers 1, when they are inside Hoover Dam looking at Megatron, Sam explains that Megs is after the cube. When he doesn't get a response, he huffs or says 'huh' really softly right before saying "You guys know where it is, don't you?" At -10dBRef, it is nearly muted, and you essentially lip-read it. At Reference, it is clear. There are no huge dynamics, so turning any system up to 0dBRef for this particular bit is safe for nearly everyone. But it does hammer home that at -10dB, you do miss some stuff, and the midbass punch simply doesn't pack the slam. I like DynEQ from -15dBRef and up. at lower volumes, it is as if some kid got crazy with the bass knob, and the surrounds are way too prominent (DynEQ EQ's moment by moment and adjusts surround levels moment by moment as well, it's look-ahead time is only 1-2 frames, so it is limited, but a good tool nonetheless).
JSS
maxmercy is offline
Behringer Europower Ep4000 Professional Amplifier
