Help with Ported Dayton 18" HO for MUSIC ONLY! - AVS Forum | Home Theater Discussions And Reviews
Old 07-07-2013, 06:38 PM - Thread Starter
Shan87's Avatar
Quoted: 16 Post(s)
Liked: 27
I've got Dayton 18" HO that I've been using at my shop(4000sqft) that is currently sealed and was thinking I could gain a little more output from it if I go with a ported set up. Only problem is I've never really used winisd for anything other than sealed boxes. The box its currently in is about 5cuft but if needed I can always slap something else together... Listen to pretty much everything so I would like it to dig down to at least 25 hz.
Anyone mind modeling a set up for me??
Shan87 is offline
Old 07-07-2013, 07:50 PM
Mrkazador's Avatar
Quoted: 252 Post(s)
Liked: 378
5cu ft tuned to 25hz looks decent with 1000w
3 x 12 x 26" slot port
Mrkazador is offline
Old 07-08-2013, 11:14 AM
BassThatHz's Avatar
Quoted: 2034 Post(s)
Liked: 1560
That's a big room for a single low-end 18 to be pushing.
Don't expect a ported box to do "worlds better" than more subs and amps would.
BassThatHz is offline
Old 07-08-2013, 12:40 PM
mastermaybe's Avatar
Quoted: 370 Post(s)
Liked: 309
Are you actually pushing the current subwoofer to (or beyond) its limits in your workshop...seriously? 4,000 cubes or not, you should be able to get pretty good (read: sensible workshop output) response out of the driver in a 5 cube cabinet. But perhaps my expectations for "shop bass" are grossly distorted. Even so, will another 2-6 dbs really change much? To even get to 5-6 dbs of additional output, you're talking about time and cost FAR exceeding that of adding a port.
Further, I didn't realize the Dayton HO was "low end". Because it's only ~$250 from a online warehouse supplier or because it's not a TC Sounds Ultra or UXL 18? I'd be willing to bet it's actually closer to an "8" on the 1-10 18" subwoofer performance scale when you take an honest look at the full scope of 18" drivers available.
James
Actual phone call (see pic to left):
Tech (responding to laughter): "I'm sorry sir, did I miss something?"
Me: "Yeah, a case of Diet Mountain Dew walking across my living room."
mastermaybe is online now
Old 07-08-2013, 01:42 PM
BassThatHz's Avatar
Liked: 1560
Also, what electronics do you have to protect the Dayton below 25hz?
Or conversely, what electronics do you have NOW to boost below 20hz to compensate for the natural roll-off of your sealed box?
Curious, what SPL are you getting now?
and how much extra SPL, would you like to have?
Old 07-08-2013, 02:04 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
Shouldn't need a hpf if he isn't listening to music with content below 25hz.
Jay1 is offline
Old 07-08-2013, 04:53 PM
LTD02's Avatar
Quoted: 2341 Post(s)
Liked: 2578
blue is driver in 5 cubic feet sealed
orange is same enclosure with one 6" x 18" long port
added (4.75 cubic feet tuned to a little under 24hz)
500 watts to each. no filters on either.
Listen. It's All Good.
LTD02 is offline
