Newbie needs help for Rock / Disco speakers - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 07-09-2013, 12:52 PM - Thread Starter
vdzele's Avatar
Hi to all,
12 years ago I have bought Dynaudio floorstanders. They have proven to be very bad for rock /disco music that I occasionally listen. At the time I was younger and inexperienced to notice what a terrible choice I made.
Over time I have listened to home speakers that suited my taste. Among them were Cerwin Vega and Klipsch. They were speakers that could provide me round / focused / punch bass that hits me in the chest. I was also DJ and I got addicted to that sound. I need to have that punchy kick bass in 100-300Hz that makes me move.
Trying to find a better replacement on the internet I found this site. I see you create nice speakers similar to what I need. But so far I could not find exactly what I need so somebody could point me where to look. My targets and limitations are:
- For home listening but also could be for small clubs (50-100 people). So it needs to be a mix of Hi Fi and PA.
- Max width could be 18", so if there is 15" bass design that could suite this - great. Otherwise 12" is OK.
- I prefer 3-way
- Bass should go bellow 40Hz.
- It has have nice audiophile features - hi fi details, 3D, warm mids, not harsh at highs,....basically a sound that is as “hi-fi ” as reasonably possible and to show some PA attributes.
- My budget is up $1,200 for parts
Bob Crites CS-1.5 and Darren Kuzma's design of The Blue Wonders are the ones that are interesting. But, 1st is 2-way and goes to only to 40hz and the 2nd is too big.
Your opinion is the one I would appreciate.
vdzele is offline
post #2 of 11 Old 07-09-2013, 05:13 PM
LTD02's Avatar
Quoted: 2345 Post(s)
Liked: 2583
http://www.pispeakers.com/catalog/product_info.php/products_id/105
upgrade the woofer to the jbl 2226h and the c.d. to the de250.
and then hang on to your head... :-)
Listen. It's All Good.
LTD02 is offline
post #3 of 11 Old 07-12-2013, 12:28 PM - Thread Starter
vdzele's Avatar
Ok I did a little research and my conclusions are:
1. I will not buy anything new because of their quality.
2. I might buy something old, late 70's or from the 80's, and upgrade it in full. Totally new crossovers and wiring. Changing even drivers if needed.
3. I might give somebody to build me a DIY speaker. Some kind of hybrid, probably bass and mid drivers will be PA and tweeter will be Hi Fi. Was thinking of eminence drives for PA and for tweeter I did not decided yet.
I am not sure will I use horns, what benefits will I gain and what would I loose.
What are your thoughts, am I in the right direction?
vdzele is offline
post #4 of 11 Old 07-13-2013, 07:53 AM
mobeer4don's Avatar
Quoted: 123 Post(s)
Liked: 117
You really want to stick with a proven design rather than playing mix and match with with drivers and crossover. This is critical for getting hi-fi sound quality....not so much if all you want is loud for blasting away in a bar.
Horns can be be hi-fi when implemented properly....and horrible when done poorly. The 4pi kit referenced above is done right (as are some other similar kits/designs). The standard version uses Eminence drivers. The difference between 2-way and 3-way is more or less moot due to the invention of subwoofers. Build a simple 2-way and add a subwoofer.
If you really do intend to use these in clubs then there is a lot to be said for finding some used PA cabs locally and fixing them up. You might get lucky and find nice empty cabs for dirt cheap. Or you can find nice stuff that needs nothing.....
Good luck!
mobeer4don is offline
post #5 of 11 Old 07-13-2013, 07:26 PM
Manic1!'s Avatar
Quoted: 180 Post(s)
Liked: 76
Whats wrong with the quality of new stuff. Mixing a P.A. woffer with a tweeter is not a good idea. Whats your buget? do you use a sub? I would look at http://www.diysoundgroup.com/
Manic1! is offline
post #6 of 11 Old 07-14-2013, 01:25 PM - Thread Starter
vdzele's Avatar
New speakers are mostly bad plastic, except for few firms that still care for quality. But they are expensive for me.
I just found out that mixing two concepts is not good.
My budget is up to1500 dollars in total.
I don't like subs, they sound bad and make fake noises. They separate the sound picture.
vdzele is offline
post #7 of 11 Old 07-14-2013, 04:01 PM
petew's Avatar
Quoted: 25 Post(s)
Liked: 68
Then you've never heard a system that was set up properly.
Building Bass - Subs
Surrounds - Easy as Pi
Storage - unRAID unDELL
Mains - Another piece of Pi
petew is offline
post #8 of 11 Old 07-14-2013, 04:11 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
How about something like an active bottom, passive top setup? You could take one of the proven, extremely well designed SEOS kits, and build it sealed
http://www.diysoundgroup.com/waveguide-speaker-kits/fusion-series-kits/fusion12-kit.html
With a bass bin of your liking, featuring a high end woofer that can play up to 300hz or so. You take an active crossover like a miniDSP
http://www.minidsp.com/products/minidsp-in-a-box/minidsp-2x4
and a pair of 2 channel amps. Build the kit, build the woofer box, glue the kit on top, set the active crossover, and adjust the levels so the top/bottom matches.
An example for the woofer setup would be this little guy
http://www.parts-express.com/pe/showdetl.cfm?partnumber=290-578
In a 18" W x 20" H x 28" D box, with three 4" x 12" ports (40hz tune). You would be good for about 122 db from 500 watts, F3 of 40hz.
Jay1 is offline
post #9 of 11 Old 07-15-2013, 06:53 AM
diaz's Avatar
This. A crappy implemented sub will sound like garbage, but done right it will blow away a setup that doesnt have subs.
diaz is offline
post #10 of 11 Old 07-15-2013, 12:28 PM
Manic1!'s Avatar
Quoted: 180 Post(s)
Liked: 76
You need to go out and listen to some more systems. All the big disco clubs in the 70's including Studio 54 used subs.
Manic1! is offline
post #11 of 11 Old 07-15-2013, 12:56 PM
Stumbo's Avatar
Quoted: 55 Post(s)
Liked: 88
http://www.billfitzmaurice.com/DR250.html
http://www.speakerhardware.com/dr-250-piezo-deluxe-kit.php
http://www.parts-express.com/pe/showdetl.cfm?partnumber=390-808
Build a couple of these, ported. Mate with an inuke 1000dsp. Will require room measurements and EQ. Will blow your head off.
Based on your comments, it sounds like you're not much a fan of deep bass, but rather you prefer a lot of midbass punch. This will get you there under your 1500 budget.
Oppo 103D
Samsung pn64f8500
Pioneer vsx-82txs
And a bunch of DIY speakers and subs.
Coming soon: Dirac Room Correction
Stumbo is offline
