Different look at magnet and voice coil structures - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 07-10-2013, 12:18 PM - Thread Starter
dbldare's Avatar
Check out this setup from Powersoft Audio
Here's the text from the video.
As displayed by Ken Blecher at InfoComm 2013 in this exclusive video for FRONT of HOUSE magazine's FOH-TV, Powersoft unveiled its M-Force system, a revolutionary drive system for subwoofers that uses fixed coils and moving magnets (rather than the traditional moving voice coil and stationary magnet structure). Intended for high-performance professional sound reinforcement applications, the technology will be offered to other companies as an OEM system and can be used with various types and materials of woofer cones -- a 30-inch is shown and up to 40-inch is supported.
dbl
LTD02 likes this.
Let's all go to the lobby
....Let's all go to the lobby
dbldare is offline
post #2 of 11 Old 07-10-2013, 01:00 PM
Stumbo's Avatar
Quoted: 55 Post(s)
Liked: 88
I need two of these, in a tapped horn.
Oppo 103D
Samsung pn64f8500
Pioneer vsx-82txs
And a bunch of DIY speakers and subs.
Coming soon: Dirac Room Correction
Stumbo is offline
post #3 of 11 Old 07-10-2013, 01:13 PM
lilmike's Avatar
Quoted: 64 Post(s)
Liked: 160
Interesting.
Internal pics and diagrams in this vid.
lilmike is offline
post #4 of 11 Old 07-10-2013, 08:42 PM
filtor1's Avatar
Quoted: 71 Post(s)
Liked: 73
Very cool!
filtor1 is offline
post #5 of 11 Old 07-10-2013, 08:47 PM
Bass Enabler
Scott Simonian's Avatar
Quoted: 5283 Post(s)
Liked: 4167
Scott Simonian is offline
post #6 of 11 Old 07-10-2013, 09:10 PM
LTD02's Avatar
Quoted: 2340 Post(s)
Liked: 2575
that is pretty amazing. i was just thinking
of something similar early today. essentially
using "rail gun" technology to drive a subwoofer
piston.
a big advantage of moving the magnet
instead of the coil is you no longer have
to try to keep the coil light weight, so
you can have a MONSTER of a coil.
one challenge that i see is that like
the slug in a rail gun, the energy inside
it will be enormous and that might cause
problems like demagnetization of the slug.
neat post. props.
Listen. It's All Good.
LTD02 is offline
post #7 of 11 Old 07-10-2013, 09:40 PM
Rosenbush's Avatar
Mmmmm... , The moving iron speaker was the earliest type of electric loudspeaker.
Rosenbush is offline
post #8 of 11 Old 07-10-2013, 10:07 PM
Bass Enabler
Liked: 4167
piston.
neat post. props.
Definitely. This is some motor technology I'd see like to see more of in the near future.
The Servodrive Contrabass comes to mind. Although that was different tech altogether. Belt driven, iirc.
post #9 of 11 Old 07-11-2013, 07:35 AM
Ricci's Avatar
Quoted: 184 Post(s)
Liked: 472
They have been working on this for 5 years if not longer...Yes the stationary coil moving magnet system is not new by any means. However they are doing some more advanced things in this design that haven't been done to my knowledge. Multiple gaps, magnetic centering, magnetic limiting, etc. I dont think we will see this on anything that isn't a finished system costing VERY big money for quite some time. Hopefully I am wrong.
Ricci is offline
post #10 of 11 Old 07-11-2013, 08:46 AM
Bill Fitzmaurice's Avatar
Liked: 4630
Chances are it will never be seen on anything smaller than an 18 either. Even if the magnet is a 10oz neo that's a lot of weight added to the MMS of a typical driver. It would have to be insignificant to be worthwhile, thus using it now in a 30 incher. Even then it's going to cost a fair bit of sensitivity, but that's overcome by not having to keep the coil gauge small, allowing a lot more power than a moving coil driver. It looks like they're heat-sinking the coil too, allowing even more juice. As for price, chances are these will be mainly pro-touring sound oriented, where paying $5k and more per sub isn't blinked at, and the space savings offered compared to other options can save in diesel fuel in one season what they pay for the speakers.
Bill Fitzmaurice is offline
post #11 of 11 Old 07-11-2013, 09:27 AM
andy497's Avatar
Quoted: 13 Post(s)
30 inch by 3 inch P-P excursion = ~34 liters? I think 4 should do it. Sealed box dimensions sound workable as well.
andy497 is offline
