Full range sonotubes ? - AVS Forum | Home Theater Discussions And Reviews
Old 07-11-2013, 05:59 AM - Thread Starter
Platform's Avatar
I am in the process of building another pair of speakers, this time I want to try some sonotunbes.
At the top firing into a inverted cone, for an 'omin directional' output I was thinking the Dayton 4" RS100
At the bottom firing down like a traditional sonosub a Exodus EX-Anarchy, then adding a crossover at something like 2000Hz between these two.
My question is would this be worth my time, or would this be a misfit ?
If this is viable my next question would be the cone at the top, dimensions, angle etc, any specifics I should worry about?
Made a quick 3D model of what my thought are:
Platform is offline
Old 07-14-2013, 12:20 AM
Mik James's Avatar
Quoted: 105 Post(s)
Liked: 81
That's a really neat idea. I too am looking to utilize sonotube for fullrange speakers.
I was originally going to do open baffle, but then i was leaning toward bipoles with one driver facing the wall and one facing out into the room.
Hopefully someone can chime in on the benefits of both designs.
Mik James is offline
Old 07-14-2013, 05:47 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
One classic design that is something like this is the Linkwitz Pluto
http://www.linkwitzlab.com/Pluto/Pluto-2.1.htm
You could scale it up to work as a 3-way with a large bottom end driver.
A 4" driver can be very effective with a far lower crossover point - as low as 400-600 Hz. I'd recommend that because it and the bass driver are so far apart.
arnyk is offline
