Fusion-10 Max; Stereo Integrity HT 18 D2; build thread. - Page 3 - AVS Forum | Home Theater Discussions And Reviews
post #61 of 82 Old 07-28-2013, 04:39 PM
brian6751's Avatar
Quoted: 885 Post(s)
Liked: 679
Very nice. Can you tow the speakers in at all?
That's not science! - Cyborg
Steam ID: The Barbeerian
Rivers Edge Theater
brian6751 is online now
post #62 of 82 Old 07-30-2013, 12:33 AM - Thread Starter
aspd's Avatar
Originally Posted by mhutchins View Post
Very nice build!
You wasted no time getting those speakers completed and the finished result looks great! You must be lovin' the sound!!
Awesome job on the build!
Thanks! I'm very happy with the sound from them!
Originally Posted by filtor1 View Post
That looks so mean!!
I agree! They should be playing Star Wars "Imperial March" on repeat. tongue.gif
Originally Posted by mynym View Post
Looks really nice man. Great job on this.
aspd is offline
post #63 of 82 Old 07-30-2013, 12:35 AM - Thread Starter
aspd's Avatar
They are toed-in a tiny bit, but my apartment is so small that if I do more of it I will be sitting in the middle of the speakers wearing them as headphones. tongue.gif
aspd is offline
post #64 of 82 Old 07-30-2013, 08:03 AM
goonstopher's Avatar
Quoted: 289 Post(s)
Liked: 55
Not sure about the crossover. There are 2 capacitors that seem to be undecided on what is right (parallel or series)
I am going to look for clarification because I'm having the same issue
goonstopher is offline
post #65 of 82 Old 07-30-2013, 08:15 AM - Thread Starter
aspd's Avatar
I'm not sure where this confusion is, not in this thread at least? Here they are definitely wired in parallel. smile.gif
aspd is offline
post #66 of 82 Old 07-30-2013, 08:22 AM
Quoted: 289 Post(s)
Liked: 55
In the main thread for DIY sound group someone is saying they are in series. I think it was the designer.
I took it as in series and so did my friend who works with electronics.
Edit: I think I am wrong... Will update this or delete it once confirmed
post #67 of 82 Old 07-30-2013, 09:00 AM
JWagstaff's Avatar
Quoted: 28 Post(s)
Liked: 71
I don't have the schematic so I don't know what it shows, but...
parallel capacitors
series capacitors
I saw your picture and you have your capacitors wired in series I believe, and I saw aspd's and they look to be wired in parallel.
JWagstaff is offline
post #68 of 82 Old 07-30-2013, 09:23 AM - Thread Starter
aspd's Avatar
The schematic says 26 uF, which only the 22 uF and 4 uF capacitor wired in parallel can give. smile.gif
aspd is offline
post #69 of 82 Old 07-30-2013, 09:25 AM
Quoted: 289 Post(s)
Liked: 55
Argg my life is over... I hot glued one of my crossovers down to the speaker
post #70 of 82 Old 07-30-2013, 09:29 AM
JWagstaff's Avatar
Quoted: 28 Post(s)
Liked: 71
Just take your soldering iron and put it up to the glue, it melts easily.
edit: oh it's glued to the speaker. :S might be hard to do this then :P
yeah, I could see someone getting confused that you have to have capacitors in parallel to get them to add their capacities together. opposite of resistors.
post #71 of 82 Old 07-30-2013, 12:40 PM
Quoted: 289 Post(s)
Liked: 55
Well I have confirmation...
I am wrong - Shocking! ha
Parallel it is!
post #72 of 82 Old 08-02-2013, 10:23 AM - Thread Starter
aspd's Avatar
Alright, this is very much unscientific. But I've done a measurement (as seen, every channel on) with a calibrated UMIK-1 microphone and a DSPeaker Anti-Mode 8033Cinema connected between the Yamaha RX-A2020 and the t.amp TA1400 MK-X power amplifier for the subwoofers. This was done after the 8033Cinena finished its calibration.
The Yamaha DSP is set to "through", so nothing done there yet. But I'll try to start tweaking the DSP on the Yamaha and see if I can get that dip between 100-200Hz more flat, and update this thread with new measurements.
aspd is offline
post #73 of 82 Old 08-02-2013, 11:14 AM
MemX's Avatar
Quoted: 55 Post(s)
Liked: 64
I'm surprised at the drop off between 20Hz and 10Hz there, that's qute a steep slope for a sealed setup, isn't it??
MemX is offline
post #74 of 82 Old 08-02-2013, 12:09 PM
Mike-ht's Avatar
I expect that is a room null, and possibly the TA1400 MK-X rolling off, not the natural response of the sealed sub.
Mike-ht is offline
post #75 of 82 Old 08-02-2013, 12:30 PM
tuxedocivic's Avatar
Quoted: 1907 Post(s)
Liked: 1728
[quote name="aspd" url="/t/1481968/fusion-10-max-stereo-integrity-ht-18-d2-build-thread/60#post_23589080" see if I can get that dip between 100-200Hz more flat, and update this thread with new measurements.[/quote]
Was the mic at the LP when you did the measurements? If not, that null could shift around. It's probably floor or ceiling bounce, so probably won't shift much.
Ryan
tuxedocivic is online now
post #76 of 82 Old 08-02-2013, 02:30 PM
Axel's Avatar
Quoted: 73 Post(s)
Liked: 24
Don't want to carry these around, wheels-a-go!
The dreaded T-nuts (had no issues).
I like the idea of using casters. (Great color choice BTW!)
What size are these?
_____
Axel
Axel is offline
post #77 of 82 Old 08-03-2013, 01:15 AM - Thread Starter
aspd's Avatar
_____
Axel
aspd is offline
post #78 of 82 Old 08-03-2013, 01:19 AM - Thread Starter
aspd's Avatar
The microphone was located where you see it in the picture, about a meter away from right Fusion-10 speaker.
I wish I had more room, might give trying moving one of the subwoofers to another placement. But in this tiny apartment I don't have (m)any options.
aspd is offline
post #79 of 82 Old 08-03-2013, 01:23 AM - Thread Starter
aspd's Avatar
The subsonic filter is in the Anti-Mode 8033Cinema, I can turn it off, but don't see why I should?
  • Red line, Anti-Mode bypassed.
  • Green line, with Anti-Mode on.
I've set 100 Hz as the crossover to the Fusion-10's. But disconnected them both for this measurement.
aspd is offline
post #80 of 82 Old 08-03-2013, 07:27 AM
Liked: 1728
I'm surprised the anti mode can't do a little better.
If that's your mic position it's not representative of the LP, but its a good measurement to have. I wonder if the anti mode did better at the LP.
aspd likes this.
Ryan
post #81 of 82 Old 08-08-2013, 11:54 AM - Thread Starter
aspd's Avatar
You got me curious as well. So now I placed the Anti-Mode microphone at my listening position and did a new calibration (hoping my neighbours don't freak out, those sweeps are mean!). Afterwards placed the UMIK-1 microphone at same place (LP) for some new measurements... OMG. biggrin.gif
red line is anti-mode default.
green line is anti-mode without subsonic filter on.
blue line is anti-mode bypass.
aspd is offline
post #82 of 82 Old 08-08-2013, 12:11 PM
Liked: 1728
So its better there eh, great!
Ryan
Stereo Integrity Siht18
