HT DYI 7.2 build help me decide SEOS? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 07-18-2013, 11:47 AM - Thread Starter
cw5billwade's Avatar
Quoted: 328 Post(s)
Liked: 184
I am looking at building DYI speakers for 7.2 surround for my dedicated Home Theater room the room is a bonus room over the garage but very large. It is 19W x 22L with 10’ ceiling in front (7’knee walls) and 9’ceiling on riser (6’ knee walls). I will have an acoustical transparent screen 24” from front wall. I want L/C/R matching vertical behind screen. Here is my build thread http://www.avsforum.com/t/1468993/the-retirment-dream-home-theater I was looking at many DYI kits and I am down to three. The surrounds and rears will need to fit in my columns and will be limited to 15”W x 11”D x 14”H, I would like to keep the LCR and sourounds under $1000 and the 2 subs under $1000
cw5billwade is offline
post #2 of 11 Old 07-18-2013, 05:01 PM
bass addict's Avatar
Quoted: 360 Post(s)
Liked: 437
What kits are you currently looking at?
Achievement Unlocked
Psychotic Episode Averted
bass addict is offline
post #3 of 11 Old 07-18-2013, 07:42 PM
Dank1209's Avatar
Bill. I. Read your build thread .nice theater and thank you for your service !!
I don't think u could go wrong with any of the seos designs But at minimum.I would look at
4. Fusion 8's for surrounds. Note these are 17" tall
3. Tempest 12's. For. LCR.
2. Dayton or. Stereo integrity 18" subs with the 4 cu. Ft. Flatpacks with a ep 4000 or a cv 2800 to drive them.
Both the fusion and tempest are designed by Jeff Bagby. .I'm sure you'll get some more input from some of the other guys. There very helpful
Dank1209 is offline
post #4 of 11 Old 07-18-2013, 08:08 PM
tuxedocivic's Avatar
Quoted: 1910 Post(s)
Liked: 1730
Do you require a flat pack? Or can you build your own.
At $1000 I'd say 3 Fusion Pure and 5 Kahrma 8. That'll be more like $1100 but a pretty good way to go. 97db mains will go a long ways in your theatre.
Ryan
tuxedocivic is online now
post #5 of 11 Old 07-18-2013, 08:09 PM
Liked: 1730
Or cheap thrills.
Ryan
post #6 of 11 Old 07-19-2013, 07:34 AM - Thread Starter
Quoted: 328 Post(s)
Liked: 184
thanks but my columns are limited to 14" in height
I can probaly build them I have some wood working skills. I will look at your sugestions
post #7 of 11 Old 07-19-2013, 07:40 AM - Thread Starter
Quoted: 328 Post(s)
Liked: 184
Link for the tempest 12 please
edit found it
post #8 of 11 Old 07-19-2013, 11:38 AM
Dank1209's Avatar
17". Was the shortest I seen .on DIY. Maybe it could be customized.
Dank1209 is offline
post #9 of 11 Old 07-19-2013, 12:16 PM - Thread Starter
Quoted: 328 Post(s)
Liked: 184
that is what Eric led me to belive
post #10 of 11 Old 07-19-2013, 01:14 PM
Mrkazador's Avatar
Quoted: 252 Post(s)
Liked: 378
http://www.diysoundgroup.com/forum/index.php?topic=71.0
The smallest waveguide kits uses an 8" woofer so that doesn't leave a lot of room for the waveguide. If you could somehow add another 2 inches to your columns then you could fit them in.
Mrkazador is online now
post #11 of 11 Old 07-19-2013, 01:56 PM
Liked: 1730
If you can build your own boxes, then you can get them quite a bit shorter. Go sealed and make it as tight as possible. Just ask the designer for the XO.
Are these in a wall? As often as it happens, that's not ideal unless using a design specifically for in-wall use. There are a few available.
Ryan
