My Cheap Thrills Thread - AVS Forum | Home Theater Discussions And Reviews
 2Likes
post #1 of 164 Old 07-20-2013, 09:33 AM - Thread Starter
wormraper's Avatar
Quoted: 321 Post(s)
Liked: 175
Ok guys, after much debating and hemming and hawing I've decided on the cheap thrills for my new L/C/R to replace my polk Monitor 70's and CS2 center. I JUST received the Celestion drivers and xover components from Parts Express and I'll be receiving the "kit" portion of the cheap thrills from Eric in the next 4 days (impatiently pacing back and forth). now the BIG thing for me will be the Crossovers. I'm a newb to speaker building (just done subs in the past) so I've never had to do a crossover. I have all the components listed on the Cheap Thrills page, but I noticed that when I looked up people's SEOS build threads they all had a piece that I noticed wasn't included in the components list (of any build actually). I circled the pieces in the picture below. I'm ASSUMING that it's just something to make connecting the wires a bit easier, but I'm not sure (remember with crossovers I'm a complete child so be gentle )
my buddy and I are each building a trio of them for L/C/R channels and have twin THT's each to back them up on the low end so building boxes with MDF shouldn't be a big thing.
wormraper is offline
post #2 of 164 Old 07-20-2013, 09:55 AM
Looneybomber's Avatar
Liked: 27
You're right, it's for easy connecting. Your other option is to solder directly.
YID DIY
Looneybomber is offline
post #3 of 164 Old 07-20-2013, 09:59 AM - Thread Starter
wormraper's Avatar
Quoted: 321 Post(s)
Liked: 175
ahhh, that's what I was wondering. is it something simple that I can pick up at radio shack or home depot? and what is the piece CALLED (I kinda like the look and security of those screw down plugs vs just soldering a crap tone of speaker wire together)
post #4 of 164 Old 07-20-2013, 11:51 AM
turbosc297's Avatar
turbosc297 is offline
post #5 of 164 Old 07-20-2013, 11:55 AM
Mrkazador's Avatar
Quoted: 262 Post(s)
Liked: 390
Mrkazador is offline
post #6 of 164 Old 07-20-2013, 01:15 PM - Thread Starter
wormraper's Avatar
Quoted: 321 Post(s)
Liked: 175
Originally Posted by turbosc297 View Post
Those are my boards lol
http://www.parts-express.com/pe/showdetl.cfm?partnumber=090-862
nice n cheap at Parts express. wish I'd have thought of those BEFORE I placed my order with them. ah well.
coming from someone who's built the cheap thrills (and since I don't have access to the crossover schematics yet till I get my supplies from Eric). how many terminal blocks would I need per speaker to make the crossovers? (I've seen it vary on the design)
post #7 of 164 Old 07-20-2013, 01:23 PM
turbosc297's Avatar
I built the tempests. But you can figure one for the amp input, and one for the xover output to each driver. (3 per speaker)
post #8 of 164 Old 07-20-2013, 01:29 PM - Thread Starter
wormraper's Avatar
Quoted: 321 Post(s)
Liked: 175
sweet. that makes it easy. 9 total for my L/C/R setup then.
post #9 of 164 Old 07-20-2013, 02:00 PM
mhutchins's Avatar
Quoted: 91 Post(s)
Liked: 111
Here is another option using a single barrier strip. The schematic is on the DIY Sound Group Forum for this design.
I just got my kits today and I am so excited. I just wish Erich had the flat packs ready so I could start building the boxes and listen to these beasts! My woodwoorking skills are not the best, so i really don't want to start cutting up MDF to try and make boxes. On the other hand, I neeeed my 'Thrills!!!!
mhutchins is offline
post #10 of 164 Old 07-20-2013, 02:03 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2696
Ill be curious to hear your opinion
Mfusick is offline
post #11 of 164 Old 07-20-2013, 02:30 PM - Thread Starter
wormraper's Avatar
Quoted: 321 Post(s)
Liked: 175
now that's a CLEAN looking crossover board. I like the top design. although my brain is having a hard time connecting things on the back lol. (not spacially oriented by nature). I like the compact look though and a six way terminal block is pretty clean looking.
you mind linking WHERE you find that schematic on the diysoundgroup forum? I couldn't find it.
post #12 of 164 Old 07-20-2013, 02:42 PM
mhutchins's Avatar
Quoted: 91 Post(s)
Liked: 111
The boards are roughly 6"x7" and I was going for a more "Pro" look for the finished product, and I wanted to be sure the board would fit between any internal bracing in the flat packs.
For the wiring, I challenged myself to see if I could come up with a layout where no wires crossed, so if I wanted, I could actually make a printed circuit board for the design. I admit, the wiring layout is convoluted...I guess I'm a slave to appearance!
post #13 of 164 Old 07-20-2013, 02:50 PM - Thread Starter
wormraper's Avatar
Quoted: 321 Post(s)
Liked: 175
lol, challenging is right. my brain has smoke curls trying to trace all the wires back to their locations biggrin.gif
I'll slog through that thread so hopefully I can come up with a layout that works.
post #14 of 164 Old 07-20-2013, 04:22 PM
mhutchins's Avatar
Quoted: 91 Post(s)
Liked: 111
If you click on the word "schematic", it should open up the discussion for the Cheap Thrills design.
Link : http://www.diysoundgroup.com/forum/index.php?topic=221.0
post #15 of 164 Old 07-20-2013, 04:50 PM - Thread Starter
wormraper's Avatar
Quoted: 321 Post(s)
Liked: 175
lol, thanks, I actually found it out when my mouse accidentally brushed across the word "schematic" and I saw it change into the "clickable" icon... kind of a "durrrrrrrrr" moment there
post #16 of 164 Old 07-20-2013, 06:18 PM
HopefulFred's Avatar
Quoted: 521 Post(s)
Liked: 477
I am just finishing mine up - I have two up and running. For reference, here's the image of the XO schematic
I took a slightly different approach and separated the woofer components from the tweeter components. My work is a little sloppy, maybe, but the boards work. Maybe you can make out where I've labeled the inputs/outputs in sharpie. Notice that the amp connections are soldered together at the terminal rings for the binding posts. Here's the front:
Here's the reverse:
HopefulFred is offline
post #17 of 164 Old 07-21-2013, 06:07 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2696
Fred I am looking forward to your impressions in your theater build thread biggrin.gif
Nice progress BTW.
Mfusick is offline
post #18 of 164 Old 07-22-2013, 09:08 PM - Thread Starter
wormraper's Avatar
Quoted: 321 Post(s)
Liked: 175
al right. for people who have done flat packs before. I MAY have access to a CNC machine so we were gonna just create our own flat packs basically. for the dados... how deep and wide are they? I'd assume about .75-.77 inches for the width, but how deep do they into the wood ??
post #19 of 164 Old 07-23-2013, 07:58 AM - Thread Starter
wormraper's Avatar
Quoted: 321 Post(s)
Liked: 175
oh and one more idea. I was thinking of using Arauco Plywood from home depot (3/4 inch thick) instead of MDF for weight issues. I know Bill Fitzmaurice uses Arauco in his THT builds as an alternative, but didn't know if it was acceptable in a speaker build for any weird reasons. any thoughts?
OR
I was thinking 1/2 Baltic Birch... I know BB is much stiffer than MDF so I was wondering if I could do 1/2 inch baltic birch (the good stuff from a lumber yard) vs. the 3/4 mdf
post #20 of 164 Old 07-23-2013, 08:30 AM
Erich H's Avatar
Quoted: 1470 Post(s)
Liked: 1881
You'll want to use 3/4" material.
If the CNC machine doesn't have a vacuum to suck the panels down on the table, you don't want to cut plywood with dados or rabbet joints. They will be warped if the wood is warped.
_______________________
The SEOS Waveguide Project
Erich H is offline
post #21 of 164 Old 07-23-2013, 08:32 AM - Thread Starter
wormraper's Avatar
Quoted: 321 Post(s)
Liked: 175
lol, sorry, the CNC machine with dado's would ONLY have been with MDF. the plywood option would only have been with standard table saws etc and glue no dados. dados in plywood would be fing nuts I assume
ok, no 1/2 inch BB ... well that means Arauco or MDF it is then. since BB is about $50 a 5x5 for 3/4 material. oof
post #22 of 164 Old 07-23-2013, 09:35 AM
mobeer4don's Avatar
Quoted: 130 Post(s)
Liked: 128
Use a dado blade to cut dados in plywood. No big deal. Or you can use a router and straight edge to cut them.
mobeer4don is offline
post #23 of 164 Old 07-23-2013, 12:09 PM
andy497's Avatar
Quoted: 16 Post(s)
Here's my crossover for a Cheap Thrills if this helps anyone. I went for compact with minimum wire runs. Inductor placement might not be optimal, but I think they are far enough apart for little interference. I hope so anyway.
Edit: Just for reference, the above black lamp cord is going to ground at each point. I know it looks like one is touching a positive terminal, but it is indeed snaked over to the negative at the solder point.
andy497 is offline
post #24 of 164 Old 07-23-2013, 12:29 PM - Thread Starter
wormraper's Avatar
Quoted: 321 Post(s)
Liked: 175
thanks, those up close shots made it so I could see the wiring a bit easier. I'm assuming that those two 6 ohm large resisters were just paired together in place of the 12 ohm resistor from the parts list (I noticed you had an extra resistor once I counted)
post #25 of 164 Old 07-23-2013, 01:43 PM
Quoted: 521 Post(s)
Liked: 477
Careful - the two 6 ohm resisters in parallel make 3 ohms - which is correct. The 12 ohm resister is in the tweeter section parallel with the smaller cap.
post #26 of 164 Old 07-23-2013, 01:45 PM - Thread Starter
wormraper's Avatar
Quoted: 321 Post(s)
Liked: 175
durr, you're right, the 12 ohm is already right next to the 1.5uf capacitor. that's what I get for just taking a quick glance. (I blame it on 4 hours of sleep last night)
post #27 of 164 Old 07-24-2013, 12:50 PM - Thread Starter
wormraper's Avatar
Quoted: 321 Post(s)
Liked: 175
thinking of spraying a flat black paint on these things. Can I use a standard latex paint on those or should I use an acrylic paint that's sandable?
post #28 of 164 Old 07-24-2013, 01:14 PM
Quoted: 521 Post(s)
Liked: 477
I don't know about all the details - but I used Rustoleum flat black enamel because I was done fooling with it and wanted something I could pick up at a local store - Lowes had plenty and the label says it's extra durable, which will be handy when positioning my 64 pound speakers. I wouldn't say I regret it, but I won't be using it for speakers that I have to look at. Probably most of the problem was in my prep work, which included only flush trimming with a router, a light sanding and then a coat of sanding sealer. The paint seems okay, but the overall finish is pretty crummy. For future builds, I'll be upgrading to duratex.
This picture gives a pretty good idea of how it came out, despite being poorly focused. I don't have any pictures of the edges that show the places that didn't get enough sanding or sanding sealer and have uneven uptake. There are a number of areas where the finish feels uneven.
post #29 of 164 Old 07-24-2013, 01:50 PM
JWagstaff's Avatar
Quoted: 28 Post(s)
Liked: 71
make sure you prime the mdf with a shellac base, like zinsser bin. it will just soak up paint without a primer.
JWagstaff is offline
post #30 of 164 Old 07-24-2013, 01:56 PM - Thread Starter
wormraper's Avatar
Quoted: 321 Post(s)
Liked: 175
shellac based primer? will do. was gonna uze zinsser bullseye, but I'll grab a quart of the shellac primmer
Polk Audio Monitor70 Series Ii Floorstanding Loudspeaker , Polk Audio Monitor Series Cs2 Center Channel Speaker Single Cherry
