dual 12" monster subwoofer enclosure - AVS Forum | Home Theater Discussions And Reviews
post #1 of 43 Old 07-21-2013, 10:28 AM - Thread Starter
mike d263's Avatar
I have 12 huge subs that i dont have any paper work for. the thiele small parameters are unknown.
Is there any way of testing the subs to find out want encloser would work best for them?
mike d263 is offline
post #2 of 43 Old 07-21-2013, 10:48 AM - Thread Starter
mike d263's Avatar
Uploaded with ImageShack.us
this is the subwoofer in question
post #3 of 43 Old 07-21-2013, 10:53 AM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 221
Might be worth it to buy DATS
http://www.parts-express.com/pe/showdetl.cfm?partnumber=390-806
Can you post a pic of the cone side?
Jay1 is offline
post #4 of 43 Old 07-21-2013, 11:03 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2697
or the backside?
There is no MFG on it ?
Seems odd
Where did you get them ?
Mfusick is offline
post #5 of 43 Old 07-21-2013, 12:34 PM - Thread Starter
mike d263's Avatar
Originally Posted by Mfusick View Post
or the backside?
Seems odd
ok this is what i know about the sub. the basket is from the old phoenix gold titainum elite
when that woofer was dicontinued a company by the name of ultratech bought the baskets and created the woofer i have called the Ultra Blue Monster
i also know the motor structure is completely different.
so using the pheonic gold specs most likely wont work
the tag on it says
Ultratech
12686a WO:1268A
BLUE MONSTER-12 0807
I also know this is a dual 4 ohm and can handle 1000 watts RMS
https://sphotos-b.xx.fbcdn.net/hphotos-prn1/11057_1280110805529_2771580_n.jpg
these are the pheonix gold ti12
this is my woofer
[/URL
post #6 of 43 Old 07-21-2013, 12:48 PM
diaz's Avatar
Two F20's, or two 20" THT's.
diaz is offline
post #7 of 43 Old 07-21-2013, 01:14 PM
Looneybomber's Avatar
Liked: 27
The woofers may have the wrong TSP's for those enclosures.
YID DIY
Looneybomber is offline
post #8 of 43 Old 07-21-2013, 01:43 PM
Mrkazador's Avatar
Quoted: 262 Post(s)
Liked: 390
Mrkazador is offline
post #9 of 43 Old 07-21-2013, 02:06 PM
diaz's Avatar
Sorry, I meant to add that... "If it has the right TS, then the F20 would work"... as the THT only has an 8" clearance for the speaker.
diaz is offline
post #10 of 43 Old 07-21-2013, 02:45 PM - Thread Starter
mike d263's Avatar
well i have tried getting the specs form ultratech.... dead end there.
i didnt want to spend the money on the DATS. i had looked at a while back for this reason. i my just have to pony up and get it.
i was hoping maybe some one close might have one. then i could just take the woofer over there and have it tested.
i am hoping they will work in a 1.75 cubic foot box ported each. i dont have a lot of room to play with in my living room.
post #11 of 43 Old 07-21-2013, 02:51 PM
diaz's Avatar
I really wouldn't bother porting those with such a small volume.. you'll start eating into the little volume you have just making the ports. I'd concentrate on two sealed boxes and a good amp.
diaz is offline
post #12 of 43 Old 07-21-2013, 04:20 PM - Thread Starter
mike d263's Avatar
it got the amp covered. its a QSC RMX2450
i could go a bit bigger on the box if i needed to. i have one of them in a 3.5 ft3 box tuned to 19 hz. the box is too big. i cant put a ton of power on it. but it does get down.
post #13 of 43 Old 07-22-2013, 05:00 PM - Thread Starter
mike d263's Avatar
Ok i bought the DATS today. so when it get here iin a few days i will get the T.S.P. on these things!!
I would like to run a few ideas by you fokes to see if what i am thinking is a good idea or not.
first off my wife does not like the audio system i am building. she says its too big size wise. my thought bigger is better?!?!?!
i would like to hide the subs some where. i saw a post a while back where the woofers where in the floor. i think this guy had a basement.
questions:
could the same be done but in the attic of my home?
if that didnt work could i put them in the closet where my a/c unit is. there is a lot of room in there.
i am open to ideas too. i am just tring to make my wife happy and have a bad ass sound system.
my LF and RF are 1.5 ft3 boxes i made ported and tune to 42Hz using a dayton 10" mid woofer and a selenium 220ti horn driver
they sound good but they real need the sub for bottom fill.
these are my LF and RF
post #14 of 43 Old 07-22-2013, 07:28 PM
Martycool007's Avatar
Quoted: 280 Post(s)
Liked: 181
Those mains look pretty sweet! I wonder how those would compare to the Seos? What kind of horn is that?
As for the subs, my advise would be to make them into really nice end tables. There are all kinds of builds in the archives that did just that. You can make them look no different than any other end tables, only these will have subs in them. You could even go with a down firing driver arrangement so that no one would know otherwise!
mike d263 likes this.
Martycool007 is offline
post #15 of 43 Old 07-23-2013, 04:25 AM - Thread Starter
mike d263's Avatar
marty that's an awsome idea!! Maybe even 2 end tables. yeah now we are getting some where.
the horn on my front channels is this
Dayton Audio H6512 6-1/2" x 12" Waveguide 1" Threaded
Model: H6512
the driver is a selenium 220ti horn driver
i am still a noob what is Seos?
post #16 of 43 Old 07-23-2013, 06:29 AM
rlj5242's Avatar
Quoted: 58 Post(s)
Liked: 48
I would have offered but you don't list your location.
From the looks of it, that's a pretty standard TC-9 type motor. And I'm surprised that Phoenix Gold let them use the gasket with the PG logo on it. It also looks like they went with a single spider instead of dual spiders with a spacer. Here's the internals of the original - http://www.caraudioclassifieds.org/forum/fix-my-speaker/41783-recone-ti12d-elite.html
rlj5242 is online now
post #17 of 43 Old 07-23-2013, 06:34 AM
stormwind13's Avatar
Quoted: 62 Post(s)
Liked: 96
The f20 is based on a 15 inch speaker. And the clearance of the access panel likely will not accommodate that depth even if it did model out well.
stormwind13 is offline
post #18 of 43 Old 07-23-2013, 06:37 AM - Thread Starter
mike d263's Avatar
i live in beaufort sc about 50 miles form savannah ga
post #19 of 43 Old 07-23-2013, 08:13 AM
rlj5242's Avatar
Quoted: 58 Post(s)
Liked: 48
I'm interested in how these measure out. I almost bought a pair of these baskets to make some custom subs. I ended up buying old Elemental Designs AV.2 baskets though.
post #20 of 43 Old 07-23-2013, 06:42 PM - Thread Starter
mike d263's Avatar
yeah thats a bit far but thanks for the offer.
i cant wait to see what these 2 subs can do if they work well i might get the other 2 from the place i got these and get a bigger amp. i really like the QSC Powerlight 6.0.
once i get the tsp on the woofers can someone model a box for me?
post #21 of 43 Old 07-23-2013, 07:13 PM
Mrkazador's Avatar
Quoted: 262 Post(s)
Liked: 390
I could do it for sure unless someone beats me to it.
post #22 of 43 Old 07-26-2013, 05:04 PM - Thread Starter
mike d263's Avatar
I got the DATS and set it all up. i did the free air responce test.
do we need the Vas to figure out a box size?
post #23 of 43 Old 07-26-2013, 05:45 PM - Thread Starter
mike d263's Avatar
this is what i have so far
post #24 of 43 Old 07-26-2013, 06:22 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 221
Jay1 is offline
post #25 of 43 Old 07-26-2013, 07:04 PM - Thread Starter
mike d263's Avatar
ok here is with the vas calculated
post #26 of 43 Old 07-26-2013, 08:00 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 221
Anywhere in the 4 - 5 ft3 box range, tuned around the low 20hz range looks good. The variable now is how much power can it handle, and how much Xmax does it have. Just looking at the thing I would imagine it's safe for 1000 watts, which would take it to 21 mm excursion in a 4.5 ft3 box tuned to 22 hz. Which means at the minimum you're going to need a pair of 4" ports (or equivalent slot port). In 4.5 ft3 the 4" ports would need to each be 28" long, or a slot port that is 1.5" high x 18" wide x 29" long for example.
Here's a great resource for planning out a box
http://www.hometheatershack.com/forums/enclosure-volume-calculator/
Here's the response with 1000 watts
Jay1 is offline
post #27 of 43 Old 07-27-2013, 05:37 AM - Thread Starter
mike d263's Avatar
Is that 4~5 cubes per driver?
thats way too big. i could go as big as 2.5 cubes per driver. i think it may be time to look at a new woofer. that requires a smaller enclosure.
does any one have any recommendation for a driver.
oh there is a budget of 450$ for this whole thing.
i was happy cause i got these for free so i would have money just tied up in a box.
post #28 of 43 Old 07-27-2013, 09:44 AM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 221
Yes that is per driver. You could do a simple 2 ft3 sealed box, f3 of 45 hz. The only way to properly port a high output driver in a small box is to use PRs, otherwise you're going to end up with a slot port that substantially increases the cabinet size, or is tuning you in the 40-50hz range like a car sub.
Here are two options
http://www.parts-express.com/pe/showdetl.cfm?partnumber=295-466
http://www.parts-express.com/pe/showdetl.cfm?partnumber=295-185
You would need a pair of these PRs
http://www.creativesound.ca/details.php?model=APR12
The 315HO can handle 700 watts, the DVC 500 watts.
Just for comparison here's your driver and the UM12-22 each in 2 ft3 with 700 watts
http://www.parts-express.com/pe/showdetl.cfm?partnumber=295-512
Jay1 is offline
post #29 of 43 Old 07-27-2013, 02:50 PM - Thread Starter
mike d263's Avatar
http://www.parts-express.com/pe/showdetl.cfm?partnumber=295-467
i think i will be using a pair of these on 1200 watts a side.
ported they want less than 1.5 cubes says the website.
post #30 of 43 Old 07-27-2013, 03:15 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 221
Yes but how are you going to prevent massive chuffing, and bottoming the driver in a 1.5ft3 ported box with 1200 watts?
Jay1 is offline
