DIY 18" sub for less than $700 - AVS Forum
post #1 of 24 Old 07-22-2013, 10:21 AM - Thread Starter
blee0120's Avatar
Quoted: 33 Post(s)
Liked: 55
I been looking at DIY subs. I looked at building dual 18" subs and it came out to be less than $1300. Am I missing something?
blee0120 is online now
post #2 of 24 Old 07-22-2013, 10:38 AM
dragonleepenn's Avatar
Quoted: 12 Post(s)
What subs are they?
dragonleepenn is offline
post #3 of 24 Old 07-22-2013, 12:05 PM
Jay1's Avatar
Liked: 102
RS18 + flat pack X2 = $650
NU3000DSP = $400
I dont think assembling/finishing is going to cost $250.
Jay1 is offline
post #4 of 24 Old 07-22-2013, 12:48 PM - Thread Starter
blee0120's Avatar
Quoted: 33 Post(s)
Liked: 55
Originally Posted by dragonleepenn View Post
What subs are they?
DIYsoundgroup flat packs and two Dayton 18s with a ep4000
post #5 of 24 Old 07-22-2013, 01:45 PM - Thread Starter
blee0120's Avatar
Quoted: 33 Post(s)
Liked: 55
NU3000DSP = $400
I just saw I can buy the cabinet and sub for 325. Then I can do two and use the ep4000 for both. I plan on doing 4. So that will be $2060. I hope assembly and finish will cost no more than $140 to bring the cost to $2200. Maybe I should go with a 5.4 setup at first
post #6 of 24 Old 07-22-2013, 01:49 PM
BassThatHz's Avatar
Quoted: 176 Post(s)
Liked: 333
But then you can't EQ/XO. Need a DSP amp/box for that.
Some AVR's are fancy enough to do that for the singular LFE channel I suppose...
BassThatHz is online now
post #7 of 24 Old 07-22-2013, 01:54 PM
wormraper's Avatar
Liked: 38
the Inuke 3000dsp should give him enough umph for both subs + those features
wormraper is online now
post #8 of 24 Old 07-22-2013, 02:15 PM - Thread Starter
blee0120's Avatar
Quoted: 33 Post(s)
Liked: 55
So that's better than the ep4000?
post #9 of 24 Old 07-22-2013, 02:19 PM
Jay1's Avatar
Liked: 102
It basically puts out the same power, and has full DSP control down to 20hz, for $30 more then the 4k.
Jay1 is offline
post #10 of 24 Old 07-22-2013, 02:21 PM
Thatsnasty's Avatar
Quoted: 14 Post(s)
They are basically the same amp.
Only difference is the EP series has SLIGHTLY less low frequency roll-off.
While the Inuke has the option to buy as a DSP version allowing EQ all in one package. (i own one of each)
Thatsnasty is offline
post #11 of 24 Old 07-22-2013, 02:30 PM - Thread Starter
blee0120's Avatar
Quoted: 33 Post(s)
Liked: 55
I guess ill go with the Inuke
post #12 of 24 Old 07-22-2013, 06:14 PM
Sibuna's Avatar
Quoted: 93 Post(s)
Liked: 265
yea cant go wrong with either amp. i use the EP4k because it was on sale for 279 with free site to store shipping last year biggrin.gif
Dual SI 18s will save you a ~$100 over 2 of the daytons and sound basically identical
Sibuna is online now
post #13 of 24 Old 07-22-2013, 06:33 PM
wormraper's Avatar
Liked: 38
sheesh, I remember that. I ALMOST picked up one last year for a future project but didn't have the cash. I have 2 THT's that are monstrosity's but I'd love to do dual 18 sono's to get a bit lower than 22-24 hz.
post #14 of 24 Old 07-22-2013, 07:34 PM - Thread Starter
blee0120's Avatar
Quoted: 33 Post(s)
Liked: 55
Ok, thanks. I might as well save some more money
post #15 of 24 Old 07-25-2013, 10:36 AM
JWagstaff's Avatar
Quoted: 28 Post(s)
Liked: 68
but then you don't get the deal on the flatpack, which saves you $120.00
so in the end the SI would be $20.00 more for basically identical sound.
JWagstaff is offline
post #16 of 24 Old 07-25-2013, 11:21 AM - Thread Starter
blee0120's Avatar
Quoted: 33 Post(s)
Liked: 55
I know, I looked that up. Basically, dual 18" Dayton subs will cost me a maximum of 1200, maybe even 1150. That's with the Inuke3000 dsp. If I did just the Inuke3000, I could save $100
post #17 of 24 Old 07-25-2013, 11:33 AM
nfraso's Avatar
Liked: 165
No reason to mess with the iNuke for a sealed setup, stick with EP4000 even if you have to find EQ options elsewhere (which likely would be better anyway):
http://www.avsforum.com/t/1435795/first-diy-project-for-a-guy-looking-to-upgrade-multiple-sealed-18s/900#post_23080227
It rolls off at 10Hz and fairly steeply. The EP4000 does not do this. Your electronics chain has enough roll-off in it already, you don't want to pile on.
nfraso is offline
post #18 of 24 Old 07-25-2013, 11:54 AM - Thread Starter
blee0120's Avatar
Quoted: 33 Post(s)
Liked: 55
Thanks for the info. Good thing I'm not starting to build until Sept when I get my place. My first HT upgrade is my dual subs. I still haven't decided on speakers yet
post #19 of 24 Old 07-25-2013, 11:56 AM
mastermaybe's Avatar
Quoted: 53 Post(s)
Liked: 155
Are we actually forgoing otherwise reliable, well-performing sub $300 amplifiers because they roll off in the single digits? Especially so in regards to relatively modest arrangements like these that may even benefit from some 1-9hz nose-diving? Wow. Ok I guess.
James
Actual phone call (see pic to left):
Tech (responding to laughter): "I'm sorry sir, did I miss something?"
Me: "Yeah, a case of Diet Mountain Dew walking across my living room."
mastermaybe is offline
post #20 of 24 Old 07-25-2013, 12:12 PM - Thread Starter
blee0120's Avatar
Quoted: 33 Post(s)
Liked: 55
James
I don't start my build for a month, so all help is appreciated. It gives me time to look everything upand rresearch to make the best purchase
post #21 of 24 Old 07-25-2013, 12:22 PM
nfraso's Avatar
Liked: 165
James
How is the EP4000 not a reliable well-performing sub-$300 amp? You've already got roll-off in your chain, no need to pile on a 10Hz nose dive too. If you've got cabs and drivers that can give you single digits, why not feed it? Just seems like a waste.
nfraso is offline
post #22 of 24 Old 07-25-2013, 12:39 PM
Sibuna's Avatar
Quoted: 93 Post(s)
Liked: 265
well its generally not sub 300 unless you find a good deal one one. but the amp is pretty much bulletproof.
post #23 of 24 Old 07-25-2013, 12:52 PM
nfraso's Avatar
Liked: 165
True, I just looked up Amazon's history and the lowest the NU3000DSP hit was $340, the EP4000 $240.
nfraso is offline
post #24 of 24 Old 07-25-2013, 12:55 PM
JWagstaff's Avatar
Quoted: 28 Post(s)
Liked: 68
a couple times a year from amazon, a couple times a year from walmart http://camelcamelcamel.com/Behringer-EP4000-Professional-Accelerated-Technology/product/B001U5JFNM
Behringer Europower Ep4000 Professional Amplifier
Gear in this thread - Ep4000 by PriceGrabber.com
