Recommendations for Sealed Reference System - Page 3 - AVS Forum | Home Theater Discussions And Reviews
post #61 of 72 Old 08-02-2013, 07:46 PM - Thread Starter
HopefulFred's Avatar
Quoted: 492 Post(s)
Liked: 425
That's kind of what I figured Jay - I appreciate you running the numbers. My understanding is that the change may move f3 down a couple Hz at the expense of output above that - is that right?
HopefulFred is offline
post #62 of 72 Old 08-02-2013, 07:58 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
The 3 ft3 flat packs really aren't really an optimal volume for the UM honestly. They aren't bad by any means, and of course they're very convenient/well built. With 3.5 ft3 your power handling vs xmax doesn't even drop off until below 10hz, so it isn't an issue, and you gain a db at 20hz.
Jay1 is offline
post #63 of 72 Old 08-02-2013, 08:33 PM - Thread Starter
Quoted: 492 Post(s)
Liked: 425
post #64 of 72 Old 08-03-2013, 10:28 AM
nograveconcern's Avatar
Quoted: 91 Post(s)
Liked: 128
I would put the driver as close to the floor as possible. With it at the top like in your sketchup drawing it is going to rock back and forth much more due to the added leverage. This results in a loss of output and wasted energy.
nograveconcern is offline
post #65 of 72 Old 08-03-2013, 10:52 AM - Thread Starter
Quoted: 492 Post(s)
Liked: 425
That is probably a good idea. I have conflicting thoughts about driver placement, in that I want to have some easy way to disrupt the primary vertical resonance, but also don't want the driver to be directly behind the head of a listener. The mechanical issue your talking about is another good reason to put the driver at the bottom. Thanks for mentioning it.
post #66 of 72 Old 09-17-2013, 06:30 PM - Thread Starter
Quoted: 492 Post(s)
Liked: 425
Okay guys, I said I would come back when I had some stuff built. I'm back, but not because it's finished - because I messed it up and need to know if it's recoverable.
I've had some cash flow issues to get straight, so buying drivers got pushed back a little, and PE has the knockdown boxes on back-order for a couple more weeks, so I still haven't received the two kits I bought. In the mean time, I've been building and finishing the two tall cabinets I posted about. Here's the picture of their current status:
The problem is that I'm a dummy and can't manage to read specifications and cut to the right dimensions. The cutouts for the drivers are 15 3/8 inches across - which is too big, even for the the overall dimension given by PE for the UM15-22.
Overall Outside Diameter 15.28"
Baffle Cutout Diameter 13.78"
Are these cabinets trash or can I add some supports and shim out the driver? The cabs are a little larger than optimal for Qtc anyway. Don't sugar-coat it. frown.gif
post #67 of 72 Old 09-17-2013, 07:04 PM
filtor1's Avatar
Quoted: 88 Post(s)
Liked: 82
There are a couple of things you can do to fix it. 1) Remove the finish on the front and cut another baffle. Glue, cut correct opening, and refinish. 2) Cut a ring the correct size ID to fit the driver and OD the inside width of the box. Cut it into two equal halves and glue them to the back of the front baffle. Care will need to be taken in clamping in either case. I have used both methods after messing a couple of boxes up in the same manner.
The first one is the easier method if the depth of the enclosure is not set in stone. The second option assumes the current cutout is larger than the OD of the drivers frame making a recessed mounting flange.
HopefulFred likes this.
filtor1 is offline
post #68 of 72 Old 09-17-2013, 07:16 PM - Thread Starter
Quoted: 492 Post(s)
Liked: 425
I was a little panicked and disgusted and couldn't see this solution. I know I can do this - I see it now. Thanks for layout it out like this so I could see it - it's actually not such a big deal, since I have some finish work to redo in a few spots, so adding a few more screw holes will not be the end of the world.
post #69 of 72 Old 09-17-2013, 07:54 PM
steve nn's Avatar
Liked: 433
I hear you things happen and one can get pretty discusted! Hang in there, looking very nice! cool.gif
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
On-going SW management class
Denon
PS3
steve nn is offline
post #70 of 72 Old 09-17-2013, 08:18 PM
filtor1's Avatar
Quoted: 88 Post(s)
Liked: 82
I am just glad I could help. smile.gif Those cabinets look great BTW!
filtor1 is offline
post #71 of 72 Old 09-17-2013, 08:38 PM - Thread Starter
Quoted: 492 Post(s)
Liked: 425
Thanks guys - I'm cautiously optimistic that I can make this look good in the end. That was the primary goal in design and finish, so I hope that getting the drivers recessed neatly actually improves the results vs the original design. If you're interested, the details of the paint and process I've used are in my dedicated theater build thread - here
post #72 of 72 Old 11-19-2013, 08:10 PM - Thread Starter
Quoted: 492 Post(s)
Liked: 425
This isn't really a build thread, but I wanted to keep this relatively complete and up to date - insofar as it contains my path to completing this system.
I finally got some partial repairs to my poorly measured cab - only one of two so far. I'm still holding off on amplification, and the repairs I've photographed are not yet finalized - bolted, but not yet glued. I decided to make a more stylistic choice than to go with my initial reaction, which was to make a seamless repair. Instead, I went with carriage bolts. I'll probably buff/sand the numbers off the heads and paint them black, but maybe not.
Anyway, here's the basics of the repair process in pictures.
Behringer Europower Ep4000 Professional Amplifier , Dayton Audio Um15 22 15 Ultimax Dvc Subwoofer 2 Ohms Per Coil
