Recommendations for Sealed Reference System - AVS Forum | Home Theater Discussions And Reviews
post #1 of 72 Old 07-24-2013, 11:41 AM - Thread Starter
HopefulFred's Avatar
Quoted: 490 Post(s)
Liked: 422
Hey guys - I'd appreciate some input. I think I might be making some things more complicated and expensive than it needs to be. I'm trying to spec a set of subs for my in-progress HT space. I'm still building - no riser or stage or soffits yet - no door either - but I want to get my sub system up and running so that I can integrate some modal control features and maybe placement into the design before I get all my finishes and woodwork bought and installed. I've built with decoupled framing (room-within-a-room) including the ceiling atop my poured concrete foundation, green glue, three layers of wall board (OSB, 5/8Drywall, 5/8Drywall) on standard 16" centers.
My room is medium-small at a volume of about 2000-2300 cubic feet - 12x22x9 or so. I would be glad if I could get to reference down to below 20Hz, but I'm a little flexible on the extension; maybe not so flexible on the output.
I have already built a set of three Cheap Thrills for LCR, and I'll build something else for surrounds. I'll be doing all the setup and calibration myself and would like to keep everything sealed in hopes of improving my success in calibration as well as ultimate extension. I'm not quite set on integration and setup theories for multiple subs, but reference output and minimal seat-to-seat variation are central design goals, so I was thinking a MiniDSP or maybe some kind of BFD and four or more subs. I prefer rack-mounted amplification and have as much as 2 20-Amp circuits I can dedicate to them, in a closet outside the room, so fan noise is not an issue.
What is an issue is space. 6 seats in the room will eat up a lot of real estate, so a small footprint would be best. I can fit a couple boxes behind my screen wall, but I figure at least two will need to be out in the room. And of course, the budget is always an issue. I'm sure I could go buy a handful of orbit shifters or something and make it work, but I live in world with limited funds, like most of the DIYers I'm sure.
My initial plans were to start with 2 CHT SS-18s and add more later, but at this point I'd rather get four integrated properly from the beginning while the budget is still flowing and I haven't gotten used to a particular system - strike once, strike hard, no mercy Sir! ya know? Now I'm hoping that I can get it done with 15s or a mix of 18s hidden and 12s or 15s out in the room. I'm a noob to some of this (really all of it, though I've done a lot of research) so I'm not sure what I can expect from these sorts of designs and what it'll really take to get me 115dB with a respectable amount of THD in a room of this size.
Would you buy two stereo amps and give one channel to each sub? Would you just buy one amp and wire them all together, using only one channel of EQ? What's the reliable way to get to my goals with minimal size and expense? Anyone have a setup they think would fit the bill? Am I silly to think a sealed system is the way to go?
Thanks for your feedback, in advance.
Fred
HopefulFred is offline
post #2 of 72 Old 07-24-2013, 11:53 AM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
4 ea RS18 or UM15 should get you what you want, assuming you get them enough power.
This is showing four rs18s each in 4 ft3 with 900 watts each, and four um15s each in 3 ft3 with 800 watts each. Both are over 115db at 20 hz. This doesnt account for any room gain.
Jay1 is offline
post #3 of 72 Old 07-24-2013, 12:15 PM - Thread Starter
Quoted: 490 Post(s)
Liked: 422
Thanks Jay! It looks like 15s should be good - though I'm happy to entertain other ideas if someone has a different take on this.
So that'd be 4 of these drivers http://www.parts-express.com/pe/showdetl.cfm?partnumber=295-514 ($760)
Four of these cabinets (or build my own) http://www.parts-express.com/pe/showdetl.cfm?partnumber=300-7082 ($500)
And 2 EP2000 http://www.parts-express.com/pe/showdetl.cfm?partnumber=248-746 ($600)
Would you spring for the EP4000 or something else entirely to get some future-proofing or additional headroom?
Anyone have any other ideas as to how I can get this done reliably for less than $1860 plus finishing and 12 cubic feet?
post #4 of 72 Old 07-24-2013, 12:32 PM
JWagstaff's Avatar
Quoted: 28 Post(s)
Liked: 71
on sale you can get EP4000 for 275 each
JWagstaff is offline
post #5 of 72 Old 07-24-2013, 01:14 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
http://www.parts-express.com/pe/showdetl.cfm?partnumber=300-7097
$1048 for 4 ea.
A pair of EP4000's would give each driver about 650 watts each RMS. That is the minimum power level you should be looking at. That will bring you right to 115db, if the output from all 4 drivers are "mutually coupled" compared to a single driver with 650 watts. The room should help you a good bit down near 20hz.
Jay1 is offline
post #6 of 72 Old 07-24-2013, 01:54 PM - Thread Starter
Quoted: 490 Post(s)
Liked: 422
I thought there might be a package option somewhere around there. Thanks for the link.
I was thinking that the driver was 2 ohm - but you're saying I'd be better to drive both VCs at 4 ohms. I wasn't sure if there was a difference between driving one VC or both (apart from the impedance).
Is the sale at $275 a regular thing, or do I just need to keep my eyes open?
post #7 of 72 Old 07-24-2013, 02:14 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
It's dual 2 ohm VC's, meaning you can wire the sub for 1 ohm or 4 ohm. I'm not aware of any amps outside of car audio stable at 1 ohm.
Jay1 is offline
post #8 of 72 Old 07-24-2013, 02:26 PM
BassThatHz's Avatar
Quoted: 2034 Post(s)
Liked: 1566
The highest output and most efficient use of power would likely be a quad RE-18 IB powered by a pair of CV5000's or clones.
If you don't want holes in your walls, than a pair of dual-opposed HO-18's powered by a pair of EP4k's would be a common alternative, but not as beefy or efficient; but still a solid design.
That said I didn't go with either of those, I went in the direction of quad LMS-18's with clone power and quad PA-18 kick bins sprinkled about.
BassThatHz is offline
post #9 of 72 Old 07-24-2013, 02:31 PM - Thread Starter
Quoted: 490 Post(s)
Liked: 422
I liked the sound of the 15s a lot more, if they'll do it - which I think they will.
post #10 of 72 Old 07-24-2013, 02:53 PM
zora's Avatar
Quoted: 48 Post(s)
Liked: 51
I wouldn't recommend it, but the Sunfire amps could handle 1 ohms loads with ease. People use the Carver/Sunfire amps in industrial settings (shaker tables), and you can practically arc weld with them.
MemX likes this.
zora is online now
post #11 of 72 Old 07-24-2013, 04:26 PM
BassThatHz's Avatar
Liked: 1566
instead of two ep2k's, try and get a nu6000DSP, it's just as expensive but it also has all the EQ/XO stuff you'd need (and watts).
Quad 15's at dual 8-ohm.
The only amp that I know of that is dual 1-ohm capable is the Crown iTech. That's how I run some of my subs. But... there goes the budget wink.gif
MemX likes this.
post #12 of 72 Old 07-24-2013, 04:56 PM - Thread Starter
Quoted: 490 Post(s)
Liked: 422
You'd prefer two channels of AMP/EQ over four? I was figuring a MiniDSP would be the more complete solution.
post #13 of 72 Old 07-24-2013, 10:19 PM
bass addict's Avatar
Quoted: 360 Post(s)
Liked: 437
Mini DSP would be my choice. The EP's are also known to roll off a lot lower than the Inukes.
Achievement Unlocked
Psychotic Episode Averted
bass addict is offline
post #14 of 72 Old 07-25-2013, 06:58 AM
JWagstaff's Avatar
Quoted: 28 Post(s)
Liked: 71
minidsp is better than the inukes dsp. and at least the ep4k's look industrial and have sort of a rough cool look. the inukes just look like plastic toys.
post #15 of 72 Old 07-25-2013, 07:00 AM
kgveteran's Avatar
Quoted: 367 Post(s)
Liked: 131
My experience with multiples..... My main system was quad 15's upfront and center. Measurement from the LP showed little variation from seat to seat from 10hz to 55hz. The big variations in FR was 55hz to 80hz ( the receivers lowpass ) and the null at the LP.....
I used tuning subs to the side of the listening position, one on each side of my sofa. This procedure allowed me to "fill" in the response where it needed to be to get the FR flat......
So, this is quite different from welti/devantier or Geddes. ALL the subs used to tune must be as capable as the mains. I'm sure my little 240watt plate amps gave up first, but that didnt stop me from realizing they arent really filling in a few Db here and a few Db there. They need to be full range subs ( between 20hz-80hz ). I realized this when i ran them alone and saw through OmniMic that there was almost no signal at all in the null of the seating position generated from the front of the room by my main subs. That null was not a problem from the side position, almost a nearfield position which hasnt been discussed here.
So, there are variations in subwoofer placements, experimenting will uncover them other than welti/devantier and Geddes...... This is exciting news !!!!!!
As of Jan 2017, im still looking for (1) Outlaw M-200 mono amp, and a used Marantz 7010
kgveteran is offline
post #16 of 72 Old 07-25-2013, 07:36 AM
Martycool007's Avatar
Quoted: 280 Post(s)
Liked: 176
So just out of curiosity, would adding some cabinets with something like a pair or trio of JBL 2226's for use in the frequencies between 60hz and 100hz be a big help?
I just purchased some of the 2226's for a guy on Craigslist yesterday and plan on trying this out in my theater room as mid-bass cabinets, but this is going to be a slow process as I have no earthly idea on cabinet size, ported versus sealed, power requirements, and how to properly implement and blend them with my Sierra-1's and UM15's.
Martycool007 is offline
post #17 of 72 Old 07-25-2013, 07:44 AM
kgveteran's Avatar
Quoted: 367 Post(s)
Liked: 131
As long as you measure first to see where the problem areas are and your tuning subs are capable of keeping up with the mains when called to duty, my first subs fell short due to incapable small plate amps
post #18 of 72 Old 07-25-2013, 08:19 AM - Thread Starter
Quoted: 490 Post(s)
Liked: 422
kgveteran, thanks for checking in. I've been reading your experience and your recommendation for equally capable subs. Do you think I'm on the right track?
post #19 of 72 Old 07-25-2013, 08:58 AM
nfraso's Avatar
Liked: 172
http://www.avsforum.com/t/1483092/uxl-15-custom-run-group-buy-interest
This is what you want- maximum output from a tiny enclosure. biggrin.gif Yes. Yes? Yes.
I also wouldn't suggest going with iNukes and a sealed build- unless you just don't care about <20Hz... in which case, why bother going sealed I suppose.
CV5000 seems like a decent option (kind of a beast) and preliminary reports of the IPR2-7500 seem to be favorable.
nfraso is offline
post #20 of 72 Old 07-25-2013, 10:32 AM - Thread Starter
Quoted: 490 Post(s)
Liked: 422
High output from a small enclosure is definitely what I want - but can I get it for comparable money and within the next 6 weeks or less?
post #21 of 72 Old 07-25-2013, 12:09 PM
nfraso's Avatar
Liked: 172
Yeah, I didn't know what your time frame was- not terribly likely I'd say. smile.gif
nfraso is offline
post #22 of 72 Old 07-25-2013, 01:59 PM
kgveteran's Avatar
Quoted: 367 Post(s)
Liked: 131
here's the catch..... my room was a nice rectangle. that's the only room I ever tried to fix using the flanked subs. I would say plan on using what I term full range sealed subs, meaning they are capable of single digit reproduction to at least 80hz.
post #23 of 72 Old 07-25-2013, 02:21 PM - Thread Starter
Quoted: 490 Post(s)
Liked: 422
post #24 of 72 Old 07-25-2013, 03:14 PM
Mike-ht's Avatar
The rolloff of the iNuke seems to get exaggerated a bit, or confused with the DSP 20Hz limitation. There are a number of people flat to 10Hz in room with this amp, as well as measurements showing a -3db point somewhere between 5 and 10 Hz. The OP was asking about getting to reference at 20Hz, where the iNuke should work fine. With 4 15's or 2 15's and 2 18's I don't know if he will have enough displacement to get to reference at 5Hz. If he decides he wants reference at 5Hz, he may want to look at a different amp, as well as the rest the equipment in his signal chain, which is probably also rolling off at this point. For 20Hz, or even 15Hz, the iNuke should be suitable if it meets all his other requirements.
The reason for sealed is because he asked for a small footprint.
Mike-ht is offline
post #25 of 72 Old 07-25-2013, 04:53 PM
nfraso's Avatar
Liked: 172
http://www.avsforum.com/t/1435795/first-diy-project-for-a-guy-looking-to-upgrade-multiple-sealed-18s/900#post_23080227
Yes, 20Hz should be fine if that's the goal. He did say to 'below 20Hz', with that being more flexible than output. But the iNuke rolls at 10Hz and fairly quickly, where the EP4K rolls 2nd order at 5Hz. If you have the displacement for 10Hz, you have the displacement for 5Hz- the room takes care of the difference, that's the beauty of sealed with as flat a signal as you can feed the driver. Of course since you need at least a pair of EP4Ks ($375 right now, but you could wait around for a better deal), you can look at amps in the $700 ballpark that would drive everything. I just don't see a reason to take a nose-dive at 10Hz if you don't have to, more likely than not your room is kicking in below 20Hz, and provided you have a proper LT in place, your extension will follow if you feed the driver properly.
We really need an amp sticky in here to tally up all of the useful HT sub amps, and the pricing, pros/cons for each.
nfraso is offline
post #26 of 72 Old 07-25-2013, 06:29 PM - Thread Starter
Quoted: 490 Post(s)
Liked: 422
I just don't see a reason to take a nose-dive at 10Hz if you don't have to.
I don't either. The price difference is fairly minimal, assuming I can wait for a sale - and not too bad even if I can't.
post #27 of 72 Old 07-25-2013, 07:19 PM - Thread Starter
Quoted: 490 Post(s)
Liked: 422
I don't want to upend the whole conversation, but I'd like to stop and regroup. It seems like Jay1's initial call was a pretty good one, but the driver choice was never questioned. I see that the UM15 is a "new product" so maybe it just hasn't caught on around here - but isn't the RSS series more popular? What does it provide that the RSS390s (HF or HO) don't? I see 5mm extra Xmax - but power handling is similar. I don't know enough about TS parameters to compare beyond that. +$25/driver isn't huge, but what does my $100 get me in the set?
post #28 of 72 Old 07-25-2013, 07:55 PM
kgveteran's Avatar
Quoted: 367 Post(s)
Liked: 131
Yeah, its a huge ball of wax..... Amp, Driver, Cabinet, EQ, Room, Placement, Bass Traps...... Amp sticky really needs to be in place, I second that, updated list of drivers probably isn't far off either.....
Kg
post #29 of 72 Old 07-25-2013, 08:05 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
Well, the UMs are really at 22 mm xmax. No idea why Dayton rates them the way they do, they put the driver on a Klippel and got 22 mm. At that point the geometric rating is useless. Considering that fact, this driver can easily be pushed beyond 22 mm cleanly. Other drivers (rs460) have been reported to run cleanly up to 20 mm in free air testing, that is good to know, but it isnt comparing apples to apples. I'm not aware of anyone who has attempted to verify xmax of the 15" RS woofers, but they will not handle massive excursion requirements like the UM drivers. Other then that, the response curve is practically identical between the 15HF and UM15 in the same size sealed box. If you were going to run a 500 watt amp the HF would make sense, your goals exceed that requirement, you need a driver capable of greater excursion to handle more power (that's the UM15).
Jay1 is offline
post #30 of 72 Old 07-25-2013, 08:10 PM - Thread Starter
Quoted: 490 Post(s)
Liked: 422
That makes great sense - I appreciate the cogent explanation.
Behringer Europower Ep4000 Professional Amplifier , Dayton Audio Um15 22 15 Ultimax Dvc Subwoofer 2 Ohms Per Coil
