Internal bracing - How critical is rounded edges for sealed sub? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 07-26-2013, 06:06 PM - Thread Starter
pauleyc's Avatar
Liked: 24
I just realized that I did not round the edges of my bracing for a sealed Dayton 18" HO build. Its a 3.6cuft box that will have about 3lbs of stuffing. I could try to get in there with sandpaper but that will be a pain ...
Thanks, Chad
pauleyc is offline
post #2 of 13 Old 07-26-2013, 07:32 PM
NathanJ's Avatar
I don't think you have to round over bracing for a sealed box.
NathanJ is offline
post #3 of 13 Old 07-26-2013, 07:46 PM
Bill Fitzmaurice's Avatar
Liked: 4629
With a sub don't bother, they're far too small to diffract ten foot and longer wavelengths.
Bill Fitzmaurice is online now
post #4 of 13 Old 07-27-2013, 08:28 AM
Martycool007's Avatar
Quoted: 280 Post(s)
Liked: 176
Is it necessary to round over the edges in a speaker build versus a sub?
Martycool007 is offline
post #5 of 13 Old 07-27-2013, 08:44 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
Learn from others. Learn from your own experiences. How many great-sounding speakers have you listened to that have square corners? Probably 2 gazillion more or less.
Diffraction at high frequencies is real, and can be measured. But out in the room with all the other things that are going on with the walls, ceiling, & etc., not so much.
arnyk is offline
post #6 of 13 Old 07-27-2013, 08:48 AM
LTD02's Avatar
Quoted: 2340 Post(s)
Liked: 2574
"With a sub don't bother, they're far too small to diffract ten foot and longer wavelengths."
+1
Listen. It's All Good.
LTD02 is online now
post #7 of 13 Old 07-27-2013, 10:10 AM
NathanJ's Avatar
I don't think Chad was talking about the front face of the speaker, he said the bracing. He also said he could get inside of it with sandpaper if needed so he is definitely talking about bracing.
I don't think that matters at all on a sealed enclosure.
NathanJ is offline
post #8 of 13 Old 07-27-2013, 01:44 PM - Thread Starter
pauleyc's Avatar
Liked: 24
Definitely internal bracing .. Thanks!
pauleyc is offline
post #9 of 13 Old 07-27-2013, 09:43 PM
bass addict's Avatar
Quoted: 360 Post(s)
Liked: 437
Achievement Unlocked
Psychotic Episode Averted
bass addict is offline
post #10 of 13 Old 07-28-2013, 07:30 AM
Quoted: 280 Post(s)
Liked: 176
I was referring to the bracing on a speaker, not a sub. I will ask again, is it important to round over the internal bracing on a speaker?
post #11 of 13 Old 07-28-2013, 08:04 AM
Liked: 4629
Only if the edge face of the brace is close to a wavelength in dimension within the pass band.
post #12 of 13 Old 07-28-2013, 08:41 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
Subwoofer pass band runs up to what, 150 Hz?
Wavelength is something like 7 feet...
arnyk is offline
post #13 of 13 Old 07-28-2013, 10:31 AM
kgveteran's Avatar
Quoted: 362 Post(s)
Liked: 130
Originally Posted by bass addict View Post
Lmao, its the gift that keeps giving.....
As of Jan 2017, im still looking for (1) Outlaw M-200 mono amp, and a used Marantz 7010
kgveteran is offline
