2 Rockford Fosgate P3D4-15 box build - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 45 Old 08-05-2013, 05:37 PM - Thread Starter
iBurn's Avatar
it definatly went out way too far and it made a weird noise like the coil came out for a brief moment or something. it looked like it came out like a full inch.
iBurn is offline
post #32 of 45 Old 08-05-2013, 05:47 PM - Thread Starter
iBurn's Avatar
maby i have the switches on the amp wrong or something?
iBurn is offline
post #33 of 45 Old 08-05-2013, 05:48 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
So are you just running test tones until you pushed it to hard? Anyway, if you plan on pushing the drivers that hard you need to build a smaller box, we went over that in post #16. The first day you set the sub up and you push it as hard as possible? For now you need to turn the gain down. You could also glue in a solid wood shelf inside the box to cut the cabinet volume.
If your goal is to really to just put full power into the drivers you might want to look at 2.5 ft3...
I still find it hard to believe you bottomed the driver at 20 mm. You sure the amp didnt clip?
Jay1 is offline
post #34 of 45 Old 08-05-2013, 05:56 PM - Thread Starter
iBurn's Avatar
i have it set to stereo, limiter on, and full range.
iBurn is offline
post #35 of 45 Old 08-05-2013, 05:57 PM - Thread Starter
iBurn's Avatar
i don't think the amp clipped. im pretty sure it was the sub.
iBurn is offline
post #36 of 45 Old 08-05-2013, 06:04 PM - Thread Starter
iBurn's Avatar
also the box is closer to 3.75 cubic feet. it is 18x18x25.25
iBurn is offline
post #37 of 45 Old 08-05-2013, 06:07 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
You need to turn the gain down on each amp channel by at least 6
Jay1 is offline
post #38 of 45 Old 08-05-2013, 06:20 PM - Thread Starter
iBurn's Avatar
if i do that, then it doesn't get very loud. i had originaly set the gain with a multi meter, but it was realy quiet, so i started turning it up. they are surprisingly quiet for 15 inch woofers. i think its the box.
iBurn is offline
post #39 of 45 Old 08-05-2013, 06:36 PM - Thread Starter
iBurn's Avatar
it only did it one time. it was the song bass i love you. i just tried it with my other subs that i know have a good box, and they didn't make the noise, but they went out realy far too. i think its just the song. i think that song gets down to like 17hz. it sounds good with everything else tho. the multi meter wanted the gain at 20, but ive got it at 21 now. im going to hook up the other one tomorrow once the glue has had plenty of time to dry.
iBurn is offline
post #40 of 45 Old 08-05-2013, 07:08 PM
Mrkazador's Avatar
Quoted: 262 Post(s)
Liked: 390
Bass I Love you goes down to 5hz so you need to be real careful with the volume...
Mrkazador is offline
post #41 of 45 Old 08-05-2013, 07:22 PM - Thread Starter
iBurn's Avatar
ohh. well then, yea. that's probably why. i had it at -10. so that's pretty high. and i had turned the gain up to about 30. id like to hear that song at 5hz tho. that must be why it never seems to have that much bass to me. it just has bass that i cant reproduce.
iBurn is offline
post #42 of 45 Old 08-05-2013, 07:27 PM
Mrkazador's Avatar
Quoted: 262 Post(s)
Liked: 390
Here is waterfall of that song.
post #43 of 45 Old 08-05-2013, 11:52 PM - Thread Starter
iBurn's Avatar
its working good now. I cant wait till the other box gets done drying. but I was wondering, how much do rca y splitters degrade the voltage and signal? I am considering putting another one in, so I can keep the 12" jbl I already had. it has a plate amp, and only needs a single rca/lfe to run it. so I would have a rca y splitter coming out of the receiver, with one end going to the jbl, and the other end going to the wall, through the attic back down to another wall, into a single rca/lfe, then into y splitter, and into the amp. do you think that would work if I got good cables?
I just tried it with a cheapy super thin wallmart y splitter, and it worked great until about -15 volume, then the receiver went into protect and said check wires. so im thinking maybe if I got good quality wires that it would work.
also I was wondering if its ok to plug my amp into a shared power strip or if I should plug it directly into the wall. I have it in the power strip now to protect it from surges in case of lightning or something.
iBurn is offline
post #44 of 45 Old 08-06-2013, 12:11 AM - Thread Starter
iBurn's Avatar
or maybe I could get some kind of splitter/amplifier?
edit
just realized I had one of my speakers disconnected with wires dangling when I did that, so that might be why it went into protect and said check wires.
iBurn is offline
post #45 of 45 Old 08-07-2013, 05:46 PM - Thread Starter
iBurn's Avatar
got the new fans soldered in today. the difference is night and day.
still wondering if my amp would have more power if it were plugged directly into the wall, or if it is fine in the surge protector.
iBurn is offline
