New iNuke NU4 6000 - 4 channel amp - Page 10 - AVS Forum | Home Theater Discussions And Reviews
 100Likes
post #271 of 452 Old 12-17-2015, 08:47 PM
dwaleke's Avatar
Quoted: 1154 Post(s)
Liked: 543
Before jumping all in I'd use that iNuke amp for a while and then switch back to something else for a while and see if you notice a difference.
I didn't notice the difference at first. Told myself all amps sound the same. They don't. I ended up selling all of my iNukes. I don't like them on mains.
Notnyt tested one of the iNukes and it didn't measure very well at all. Distortion at higher frequencies. The results are in the Measuring Amplifiers thread from a while back.
dwaleke is online now
post #272 of 452 Old 12-18-2015, 04:42 AM
DrDyna's Avatar
Quoted: 120 Post(s)
Liked: 82
Can you describe your testing methodology in a little more detail?
DrDyna is online now
post #273 of 452 Old 12-18-2015, 06:36 AM
MKtheater's Avatar
Quoted: 1759 Post(s)
Liked: 1356
The distortion measured is inaudible to the human ears and lower than speakers.
Marantz 7704
2 Outlaw 7140s
Speakers- my own creation!
subs 2 XXX ported SLLT.
MKtheater is online now
post #274 of 452 Old 12-18-2015, 04:44 PM
Archaea's Avatar
Quoted: 3086 Post(s)
Liked: 2717
I did distortion measurements on the 228ht and the crown x1000 which is a rebadged crown xli 800. The inuke dsp 3000 had less distortion measured on the 228ht than the budget crown did.
I've not heard the 4 channel 6000 unit but I would assume its similar.
Archaea is offline
post #275 of 452 Old 12-18-2015, 04:46 PM
Bass Enabler
Scott Simonian's Avatar
Quoted: 5973 Post(s)
Liked: 5036
Only time I heard an inuke amp on mains was at @carp 's house and he had an inuke6000 powering his mains. I heard no obvious SQ issues. Sounded great.
Scott Simonian is offline
post #276 of 452 Old 12-18-2015, 05:40 PM
MKtheater's Avatar
Liked: 1356
Remember that .47% distortion at 6khz was at Max Spl which we won't even come close to using. I wonder how much distortion there is at 50 watts and 10 watts which my system uses.
post #277 of 452 Old 12-19-2015, 01:54 PM
carp's Avatar
Quoted: 2885 Post(s)
Liked: 2172
I've gone back and forth about this... Jeff at JTR recommends using something better but I'd bet a lot of money I wouldn't be able to tell the difference and I just love the dsp on the inuke.
carp is offline
post #278 of 452 Old 12-19-2015, 02:07 PM
lukeamdman's Avatar
Quoted: 1229 Post(s)
Liked: 1516
I don't think it's the % of distortion in the inuke's that would be audible, but rather the 3rd harmonic distortion. Doesn't that start to rise around 3khz? 9khz is definitely within our range of hearing.
I've never done an A/B comparison, and even if I did I highly doubt I hear any difference at all, but it might be one of those things that once you do hear it or notice it, you can't un-hear it
Ever had a rattle in the room that no one lese notices but it drives you crazy?
lukeamdman is offline
post #279 of 452 Old 12-19-2015, 02:50 PM
Archaea's Avatar
Liked: 2717
Post 465
Distortion testing on several amps, not 6000, but inuke 3000 included.
Cheap Crown Amp Power $99
Archaea is offline
post #280 of 452 Old 12-19-2015, 03:24 PM
MKtheater's Avatar
Liked: 1356
Again the distortion only gets higher when pushing the amp and with our higher sensitive speakers. I use 50 watts for the fronts and 10 watts for surrounds and sides so that Inuke will be as clean as any.
What is the percentage of the 3rd harmonics and at what wattage? To be fair as measurements are concerned the Emotiva was measured to have lower distortion but at lower power too. Turn down the Inuke to the same levels and it is low too.
post #281 of 452 Old 01-01-2016, 07:29 PM
NODES's Avatar
Quoted: 653 Post(s)
Liked: 273
Excellent information MK! I ordered a 6000 this past week. I'm still on the fence with it but I'm going to give it a go and see how it works out. It's hard to pass up the dollar per watt value of these things. Socked in with a snow day today, so I'm going to rearrange the theater a bit any way to get ready for the iNuke's arrival.
dbl
Did you order it from Amazon by any chance?
Who needs 4K?... just go see your optometrist.
NODES is offline
post #282 of 452 Old 01-01-2016, 07:33 PM
dbldare's Avatar
No. Unfortunately I ordered it from my local GC. It's on back order though. Looks like a month out. Bummed...
dbl
dbldare is offline
post #283 of 452 Old 01-01-2016, 08:37 PM
NODES's Avatar
Quoted: 653 Post(s)
Liked: 273
dbl
Well I guess both of our units are on the same Boat from the Orient, lets hope it arrives before Valentines day
NODES is offline
post #284 of 452 Old 01-01-2016, 09:16 PM
MKtheater's Avatar
Liked: 1356
I just bought 3 NU4-6000's for $900 brand new locally. I am pairing it up with a Marantz 7702 to try out Atmos. Everything is ready to go I just need to mount the ceiling speakers.
I will add pics tomorrow as I am on my phone.
chrapladm and biga6761 like this.
post #285 of 452 Old 01-01-2016, 09:41 PM
Swolephile's Avatar
Quoted: 896 Post(s)
Liked: 356
I can also hear the difference in sound quality using Ipuke amps with mains and subs. Hence why they have been banned from my setup.
Swolephile is offline
post #286 of 452 Old 01-02-2016, 06:53 AM
DrDyna's Avatar
Quoted: 120 Post(s)
Liked: 82
iPuke huh, that's cute.
post #287 of 452 Old 01-02-2016, 07:32 AM
MKtheater's Avatar
Liked: 1356
I can't, I have used many amps and the nu4-6000 sounds great.
Marantz 7704
2 Outlaw 7140s
post #288 of 452 Old 01-02-2016, 11:44 PM
NODES's Avatar
Quoted: 653 Post(s)
Liked: 273
I think my Patience is starting to run very thin now...it is almost a month since I ordered the unit from Amazon, I have not been able to use my theater 6 weeks now.
I am giving it another few days and then ordering the Inuke6000DSP for my martys and then using the 2x 3000DSP's on my L C R instead.
Very disappointed in the handling of this by Amazon, would not allow me to even use the 20% coupon I used on the NU4-6000 on a new 6000DSP even though both items were included in the promo. RANT OVER!!!!
NODES is offline
post #289 of 452 Old 01-03-2016, 05:48 AM
V.X.Donique's Avatar
Quoted: 52 Post(s)
Liked: 45
Wow that sucks man. I have a brand new 6kDSP I'm thinking of sending to ebay valet this week. Didn't know these were so hard to come by in certain areas. I wanted to go with a 4 channel amp instead.
V.X.Donique
Introducing the Vier Systems Xero.1/Midbasiks Subwoofer builds....
Creator of the AVScience DIY Speakers and Subwoofers Forum
"Don't concentrate on the finger or you will miss all that heavenly glory." -Bruce Lee
V.X.Donique is offline
post #290 of 452 Old 01-03-2016, 02:18 PM
NODES's Avatar
Quoted: 653 Post(s)
Liked: 273
The 6000DSP is everywhere, it is the 4 channel NU4 that is the one that is hard to come by.
NODES is offline
post #291 of 452 Old 01-03-2016, 02:46 PM
Quoted: 52 Post(s)
Liked: 45
Yeah, that's what I meant. I was second guessing selling the 6kDSP since the NU4 was harder to get, and that's what I wanted.
V.X.Donique
post #292 of 452 Old 01-03-2016, 04:01 PM
dtsdig's Avatar
Quoted: 912 Post(s)
Liked: 1038
It appears that Sweetwater has them in stock.
Amazon is not the best place for some stuff like this, in my opinion.
http://www.sweetwater.com/store/detail/NU4-6000
V.X.Donique likes this.
dtsdig is online now
post #293 of 452 Old 01-03-2016, 04:50 PM
NODES's Avatar
Quoted: 653 Post(s)
Liked: 273
Noted, but Amazon's price was $279 after taxes with next day delivery. I never expected such a delay with Amazon in the 7 years I have dealt with them.
I could of got the 6000DSP for $319 after taxes with next day delivery, which is the route I should of went with had I known there was a backorder.
Lesson learned I guess, sweetwater.com is next on my list.
NODES is offline
post #294 of 452 Old 01-08-2016, 08:46 PM
NODES's Avatar
Quoted: 653 Post(s)
Liked: 273
Well I finally ended up getting my NU4-6K, the Polk TSI A9 sound a lot better running off that amp then the XPA5 there were attached to for the last 8 months.
Wife actually came in while playing an MP3 and she asked if I had everything hooked up which meant my 15 and 18 Marty's and I said NO. The extra power is noticeable. The amp did have a bad hum, but tracked it down to ground loop and just hooked up a ground wire to DENON AVR strangely the Emotiva did not have that issue.
NODES is offline
post #295 of 452 Old 01-11-2016, 06:38 PM
MKtheater's Avatar
Liked: 1356
My Inukes sound great and very dynamic. My current setup has the lowest noise floor yet. I was pleasantly surprised by this.
post #296 of 452 Old 01-31-2016, 08:27 PM
Quoted: 78 Post(s)
What are the two units on the bottom of your rack?
Ryanweather is offline
post #297 of 452 Old 01-31-2016, 09:49 PM
zeus33's Avatar
Quoted: 1561 Post(s)
Liked: 1406
They are Monster Power AVS 2000s.
Ryanweather likes this.
zeus33 is offline
post #298 of 452 Old 02-01-2016, 08:28 AM
MKtheater's Avatar
Liked: 1356
Yes, they are my triggers for everything.
Marantz 7704
2 Outlaw 7140s
post #299 of 452 Old 02-08-2016, 08:14 AM
KK20's Avatar
Quoted: 12 Post(s)
How do the iNuke's compare to your old ADA's, either the 1260 or 501?
KK20
KK20 is offline
post #300 of 452 Old 02-08-2016, 09:37 AM
MKtheater's Avatar
Liked: 1356
Hard to tell, whole different setup since then but the Inukes are using XLR cables which are dead silent.
Marantz 7704
2 Outlaw 7140s
Emotiva Xpa 5 5 Channel Power Amplifier
