New iNuke NU4 6000 - 4 channel amp - Page 13 - AVS Forum | Home Theater Discussions And Reviews
 100Likes
post #361 of 452 Old 07-05-2016, 12:40 PM
Bassment's Avatar
Quoted: 946 Post(s)
Liked: 379
Originally Posted by rhodesj View Post
Notnyt's testing showed about 1000W/channel with only two channels running at 2 ohms. Obviously, with all four channels in use, it would drop further, not sure how much.
A 15A circuit can supply more than 15A for short periods. Breakers don't trip instantly. A typical breaker will let double its rated current through for at least 20 seconds before tripping. Higher current draw trips it faster.
Not sure if you're agreeing or disagreeing with me, but RMS power is continuous, so the breaker trip time is irrelevant. It can burst way more than 1800W, like you said. But even at 100% amp efficiency (which it's not even close), it could only do 450W RMS per channel
Bassment is offline
post #362 of 452 Old 07-05-2016, 03:27 PM
notnyt's Avatar
Quoted: 2774 Post(s)
Liked: 2561
There's no such thing as "rms power".
All of these are measured off one channel.
1 of 2 bridged channels into 4 ohms
both channels running bridged into 4 ohms
1 of 4 channels into 2 ohms
2 of 4 channels into 2 ohms
LTD02 and biga6761 like this.
notnyt is offline
post #363 of 452 Old 07-05-2016, 03:58 PM
Bassment's Avatar
Quoted: 946 Post(s)
Liked: 379
Lol yeah, RMS voltage, average power. 2 ch into 2 ohm has more output per channel than 1 ch into 2 ohm? The voltage peaks higher with 2 channels driven over 1?
Bassment is offline
post #364 of 452 Old 07-05-2016, 03:58 PM
notnyt's Avatar
Liked: 2561
sorry have the graphs swapped, correcting, please nuke the pics from the quoted post
notnyt is offline
post #365 of 452 Old 07-05-2016, 04:02 PM
Bassment's Avatar
Quoted: 946 Post(s)
Liked: 379
It's not an error, it's just Behringer specs. Complete bs
No, it's an error. That is just some random website hosting an old pdf. The physical manual is accurate. So is their website http://www.music-group.com/Categorie...4-6000/p/P0B1R
Bassment is offline
post #366 of 452 Old 07-05-2016, 04:03 PM
notnyt's Avatar
Liked: 2561
All power measurements are taken with RMS voltage, otherwise you're not calculating power correctly.
The best way to describe power is either burst or sustained.
notnyt is offline
post #367 of 452 Old 07-05-2016, 04:05 PM
Bassment's Avatar
Quoted: 946 Post(s)
Liked: 379
Haha ok that makes sense
Bassment is offline
post #368 of 452 Old 07-05-2016, 04:08 PM
notnyt's Avatar
Liked: 2561
Ah, I see.
From their website, The 4-channel iNUKE NU4-6000 power amplifier packs 6,000 Watts (4 x 1,600 Watts @ 2 Ohms; 2 x 3,000 Watts @ 4 Ohms).
They're quite over inflated
notnyt is offline
post #369 of 452 Old 07-05-2016, 04:54 PM
rhodesj's Avatar
Quoted: 942 Post(s)
Liked: 533
Let me see if I can explain. The circuit and circuit breaker do not directly limit amplifier output. The amplifier will draw as much power from the wall as it wants until the breaker trips or until other factors like sagging line voltage effect the amplifier, or the amp overheats and triggers its thermal protection, etc...
The circuit has no way to stop the amplifier from drawing as much power as it wants other than by tripping the breaker. That's why we have breakers or fuses, to prevent devices from drawing high levels of current long enough to cause a fire.
Per notnyt's testing, the NU4 will continuously output 2x 1200W bridged at 60% efficiency. That means drawing about 4000W from the wall, which it will happily do, even on a 15A circuit.
So you can play a full-volume sine wave outputting 2400W and drawing 4000W on an NU4. And after doing so for about 20 seconds, the breaker trips.
20 seconds is a reasonably long time, certainly enough to be called continuous. I think notnyt uses a 10-12 second long sine wave as his criteria for continuous amplifier output.
rhodesj is offline
post #370 of 452 Old 07-05-2016, 08:06 PM
Bassment's Avatar
Quoted: 946 Post(s)
Liked: 379
You're right, however we're talking about 4 ch operation not bridged. Yes that is 2400W, but we need to divide by 4, not 2 so that's 600W per channel. But that's into a 2 ohm load (4 ch bridge is same as 2 ohm each channel). We're talking 4 ohm, so 450W per channel around. But my point is I don't think 450W per channel is enough for 15" sealed. I'd go for 1000-1500
Bassment is offline
post #371 of 452 Old 07-05-2016, 08:11 PM
Bassment's Avatar
Quoted: 946 Post(s)
Liked: 379
Ah, I see.
True they exaggerate them pretty hard. But if they used the real numbers it is still insanely impressive for the price. I love my NU4
Bassment is offline
post #372 of 452 Old 07-05-2016, 08:20 PM
notnyt's Avatar
Liked: 2561
agreed, I use an nu3000dsp for my transducers. does well, but I am looking for something silent to replace it with at some point. I'm also replacing my fp14000s with speaker power amps just because they're silent. the quest for silence is expensive need to find something that can output 1kw into 8 ohms or 2 ohms without noise. need a limiter and some eq as well. pita since I really like the dsp on the inuke and dynamic eq.
biga6761 likes this.
notnyt is offline
post #373 of 452 Old 07-05-2016, 08:25 PM
Bassment's Avatar
Quoted: 946 Post(s)
Liked: 379
What fan is in your 3000? I have arctic f8 and they are 22.5 dB. I can't tell if the amp is on or off with my ear right on it. Literally silent
Bassment is offline
post #374 of 452 Old 07-05-2016, 08:31 PM
notnyt's Avatar
Liked: 2561
noctua nf-r8, it's silent unless the room gets hot or the amp runs for a while. I have a really low noise floor here. it's the least of my concerns at the moment, though. my hd enclosure is annoying with 8 drives spinning. can't wait for large cheap ssds. that said. the projector is the worst offender.
notnyt is offline
post #375 of 452 Old 07-05-2016, 08:53 PM
goonstopher's Avatar
Quoted: 322 Post(s)
Liked: 66
Those numbers sound basically like a regular 2 channel 6000 but you are given an option to use it as 4 channels.
goonstopher is offline
post #376 of 452 Old 07-06-2016, 05:28 AM
Bassment's Avatar
Quoted: 946 Post(s)
Liked: 379
It is just two 3000s in one chassis. Same with the 6000. The 6000 is just a forced bridge
Bassment is offline
post #377 of 452 Old 07-06-2016, 06:17 AM
Quoted: 322 Post(s)
Liked: 66
That's the 6000. Are you saying the 6000*4 is also?
post #378 of 452 Old 07-06-2016, 08:24 AM
Bassment's Avatar
Quoted: 946 Post(s)
Liked: 379
Yes the Nu4-6000 and the Nu-6000 are the exact same physical amp, however, the Nu-6000 is a forced bridge, so it's 2 ch. The nu4-6000 is an optional bridge, so it's either 2 or 4 channels. And the actual amp board inside is basically just two nu-3000's. With a different power supply
Bassment is offline
post #379 of 452 Old 08-16-2016, 09:43 AM
lukeamdman's Avatar
Quoted: 1228 Post(s)
Liked: 1516
I just did some tests on the NU4-6000. So far my numbers line up pretty good with Not's
Not's test is more advanced where he's actually measuring distortion, but I'm relying on what I visually see in the wave forms on the scope.
http://data-bass.ipbhost.com/index.p...r-tests/page-1
lukeamdman is offline
post #380 of 452 Old 08-17-2016, 04:40 AM
dtsdig's Avatar
Quoted: 901 Post(s)
Liked: 1015
Cool! I would love it if someone had enough loads to be able to measure power output on an NU4-6000 with all 4 channels running at 2 ohms and then 4 ohms. I've been really happy with mine but I've only ever used two channels of it so far and only at 4 ohms each.
dtsdig is online now
post #381 of 452 Old 08-17-2016, 07:55 AM
lukeamdman's Avatar
Liked: 1516
Yeah my testing rig only has two channels.
Later today I'll be uploading 4ohm stereo and 2ohm stereo results where 2 of 4 channels are driven.
post #382 of 452 Old 08-17-2016, 10:34 AM
dtsdig's Avatar
Quoted: 901 Post(s)
Liked: 1015
Sounds good!
post #383 of 452 Old 08-17-2016, 01:57 PM
lukeamdman's Avatar
Liked: 1516
post #384 of 452 Old 08-17-2016, 04:09 PM
Archaea's Avatar
Quoted: 3082 Post(s)
Liked: 2706
This isn't the case. That was an old guess on the forums but internal pics show differences.
Archaea is offline
post #385 of 452 Old 08-17-2016, 04:10 PM
Bass Enabler
Scott Simonian's Avatar
Quoted: 5972 Post(s)
Liked: 5029
Link?
Scott Simonian is offline
post #386 of 452 Old 08-17-2016, 04:24 PM
lukeamdman's Avatar
Liked: 1516
Link?
It may not be two 3k PCBs stuffed into a single chassis, but the output test results certainly line up with the 3k and 6k.
post #387 of 452 Old 08-17-2016, 07:04 PM
Archaea's Avatar
Liked: 2706
Link?
NU46K -
A picture of the inside of my iNuke DSP 6000 - date code 1505
Archaea is offline
post #388 of 452 Old 08-17-2016, 07:56 PM
lukeamdman's Avatar
Liked: 1516
NU46K -
I think the small differences can be easily accounted for with double the Speakons and XLRs and lack of DSP in the nu4.
post #389 of 452 Old 08-17-2016, 09:18 PM
Bass Enabler
Liked: 5029
post #390 of 452 Old 08-17-2016, 10:08 PM
Archaea's Avatar
Liked: 2706
fellows!?! - those are not identical!
Perhaps identical if you are talking about the identical like DNA from Chimpanzee's and Pigs and Humans is identical. I mean it's all like 2-5% different right? Pretty close to identical right? Yeah - okay identical - Got it.
They do have similar elements - but they are designed by the same parent company - so you'd expect that. The left side of the board is very different, there's another two extra caps at the bottom middle right, and quite a few more caps on the left side of the DSP 6000. Who knows what else. Those are visible from a quick glance. The right side of the board does seem to be more similar than the left side FWIW, but I'd hardly say identical.
dwaleke likes this.
Archaea is offline
Emotiva Xpa 5 5 Channel Power Amplifier
