New iNuke NU4 6000 - 4 channel amp - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 76Likes
post #31 of 448 Old 07-29-2013, 04:30 PM
carp's Avatar
Quoted: 2489 Post(s)
Liked: 1746
Wow, the Funky Munky Music that's less than a mile from me has them according to the link. I swear I don't need an amp for my LRC... I swear I don't need an amp for my LRC....
I'll just keep saying that to myself every time I drive by.
carp is online now
post #32 of 448 Old 07-29-2013, 04:35 PM
Bass Enabler
Scott Simonian's Avatar
Quoted: 5283 Post(s)
Liked: 4168
Before I finished my 8 subs I had 2 dedicated lines run, both 20 amps. I thought that would be fine based on advice from the forum but I wish I had gone with 30 at least. I've tripped my breaker 10 times roughly and I want a setup where it never happens.
I have a CV 5000 powering 8 18" SI subs, so that does mean that all subs are on the same line since it's just the one amp powering all of them, so I'm betting I'll have much less of an issue if I someday buy another amp so that I'm running 4 subs off each amp or buy a more efficient amp to run all 8 (new Peavey perhaps?)
Still, it's not a huge deal. The only time I trip the breaker is when doing demo's at insane levels and even then the breaker only goes once or twice at the most after a lot of bass scenes. It has never happened at normal movie viewing/music listening levels (reference and below) and I'm positive it never will.
Scott Simonian is online now
post #33 of 448 Old 07-29-2013, 07:03 PM
noah katz's Avatar
Quoted: 881 Post(s)
Liked: 304
right on the money
Originally Posted by arnyk View Post
Depends if you are playing music or test tones.
Music has a crest factor of at worst 6-8 dB. The standard HT reference setting scheme is based on a crest factor of 20 dB which is presumably reached only for short peaks. 20 dB = 100x peak to average ratio.
Going back to that utter worst case number of 6 dB, that is 4x power suggesting that your 20 amp circuit can actually support 9600 watts of real world music or movies.
Noah
noah katz is offline
post #34 of 448 Old 07-29-2013, 11:27 PM
LTD02's Avatar
Quoted: 2340 Post(s)
Liked: 2576
^^while more or less right, there is more...
some folks run bass hot...add power.
some of the bass notes are more like sustained sine waves than music transients...add power.
redirected bass from up to a poopot of other channels increases demands...add power.
just say'n.
Listen. It's All Good.
LTD02 is offline
post #35 of 448 Old 08-01-2013, 06:41 PM
BassThatHz's Avatar
Quoted: 2032 Post(s)
Liked: 1553
My system draws 1300watts RMS @ idle, and 2400watts RMS when thumping it near clipping, and the breakers I have them connected to can support 15600watts RMS.
Sounds pretty low for 10 amplifiers rated for 35kW peak across 22 channels and 5 breakers doesn't it? (YES, including a clone and an iTech 8000 etc...)
With my sound system, I've never popped a single breaker. But they ARE properly sized to spec.
The CV-5k is a class-H right? That's probably why you popped it. The voltage was probably sagging too, drawing even more current to make up for it.
The power supply of the clones is a switcher @ +90% efficient, where as Class-H is 50%, so (in theory) you could get 40% more power out of the same circuit before it popped just by using a different amp and changing nothing else.
The CV-5k outputting 600watts RMS x2, and dissipating the other 1200watts RMS as heat and then popping the breaker rated for 2400watts RMS. Physics sucks doesn't it? frown.gif
BassThatHz is offline
post #36 of 448 Old 08-01-2013, 11:09 PM
carp's Avatar
Liked: 1746
The runs are pretty long to from the box, outside the house, and then into the laundry room so I'm sure that doesn't help either.
Your post is another reason why I should be looking at the new peavey amps.
carp is online now
post #37 of 448 Old 08-01-2013, 11:19 PM
cookieattk's Avatar
Quoted: 111 Post(s)
Liked: 89
clones are class h with smps
cookieattk is offline
post #38 of 448 Old 08-02-2013, 10:30 AM
MemX's Avatar
Quoted: 55 Post(s)
Liked: 64
I didn't realise the CV5000s weren't Class D... I may have to reconsider them as an option...
I want to avoid the apparent rolloff of the iNukes at c.10Hz but I also don't want to risk a potentially unreliable clone with no real aftersales support!
MemX is offline
post #39 of 448 Old 08-02-2013, 11:00 AM
jonathanc's Avatar
Liked: 48
Quick question, are the newer CHEAP class D amps ie inuke series good enough for full range speakers in regards to low distortion ?
jonathanc is offline
post #40 of 448 Old 08-02-2013, 11:18 AM
MemX's Avatar
Quoted: 55 Post(s)
Liked: 64
I believe they are perfectly fine for full range use, yes.
MemX is offline
post #41 of 448 Old 08-02-2013, 11:29 AM - Thread Starter
Gorilla83's Avatar
Quoted: 370 Post(s)
Liked: 513
I've tried the Inuke6000 full range for mains and it definitely had no shortage of clean power.
Gorilla83 is offline
post #42 of 448 Old 08-02-2013, 11:35 AM
jonathanc's Avatar
Liked: 48
So it's safe to say that the old class-d stereotype(no pun intended) of being not great with the high frequency stuff doesn't apply anymore ?
post #43 of 448 Old 08-02-2013, 11:45 AM
LTD02's Avatar
Liked: 2576
6000 test for power
http://forum.speakerplans.com/behringer-inuke-nu6000-vs-kam-kxd7200-bench-tested_topic69202.html
3000 test includes frequency response
http://www.diyaudio.com/forums/class-d/213071-behringer-inuke-nu3000-measurements.html
not sure if the upper end of the 6000 is the same as the 3000.
LTD02 is offline
post #44 of 448 Old 08-02-2013, 11:46 AM - Thread Starter
Gorilla83's Avatar
Quoted: 370 Post(s)
Liked: 513
I'm not sure that it was ever a valid or legitimate concern. I now use a Crown Drivecore amp for my mains, also Class D. Sounds great, weighs nothing, it's quiet, and has plenty of low distortion power.
post #45 of 448 Old 08-03-2013, 04:23 AM
whoaru99's Avatar
Liked: 69
Considering I have roughly 9kW of Crown and QSC power in my garage jam system on a single 20A breaker and have yet to trip it even at "call the Police" levels, I agree. Test tones at full power are not part of the play list though, to your point.
Just because there is a knob doesn't mean you should turn it.
whoaru99 is offline
post #46 of 448 Old 08-03-2013, 05:26 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
The high frequency problem with Class D has two major components:
(1) Output device issues leading to a rise in high frequency nonlinear distortion
(2) High frequency source impedance issues related to the high level ultrasonic filter which ultimately traces back to switching speed issues with the output devices.
There has been progress in both these areas, and more can be expected.
Current performance of the best class D amplifiers is probably good enough right now so that there should be no audible artifacts.
However there are a lot of class D amps being sold, such as "T-amps" that are legacy designs and have these problems in spades.
arnyk is offline
post #47 of 448 Old 08-27-2013, 09:44 AM
bhazard's Avatar
Quoted: 86 Post(s)
Liked: 55
Just ordered mine via gearclubdirect for a very good price (Under $500). These should hopefully match well with my 500w+ capable SEOS towers. Overkill? Yes. Dynamic headroom, you bet. My XPA-5 is up for sale because of it.
Am I the first to order it?
bhazard is offline
post #48 of 448 Old 08-27-2013, 10:11 AM
Bass Enabler
Liked: 4168
Sweet! Please let us know what you think of it when you get it. I'm very interested in at least one if not several of these. Will clear up a significant amount of RU space and weight.
I haven't seen anyone else mention getting one of these so I think you're the first!
post #49 of 448 Old 08-27-2013, 10:19 AM
LTD02's Avatar
Liked: 2576
"However there are a lot of class D amps being sold, such as "T-amps" that are legacy designs and have these problems in spades."
http://gr-research.com/amps/amps.htm
LTD02 is offline
post #50 of 448 Old 08-27-2013, 10:45 AM
bhazard's Avatar
Quoted: 86 Post(s)
Liked: 55
Make sure to call gearclubdirect for the price if you do. Its actually under $460 if you are close to IL, and they only have 3 left right now.
bhazard is offline
post #51 of 448 Old 08-27-2013, 10:52 AM
Bass Enabler
Liked: 4168
Dayum. Nice deal! No, I live in California so I guess shipping would be more.... unless it's free. biggrin.gif
post #52 of 448 Old 08-27-2013, 10:57 AM
bhazard's Avatar
Quoted: 86 Post(s)
Liked: 55
I'm in NY, so you wouldn't be far off price wise.
bhazard is offline
post #53 of 448 Old 08-27-2013, 11:02 AM
Bass Enabler
Liked: 4168
Agh! I guess I should at least use the amps I have now.....but only for now. biggrin.gif
post #54 of 448 Old 08-27-2013, 02:14 PM
maxmercy's Avatar
Quoted: 63 Post(s)
Liked: 167
I've measured films with 32+ dB crest factor.
JSS
maxmercy is offline
post #55 of 448 Old 08-27-2013, 03:26 PM
LTD02's Avatar
Liked: 2576
"The standard HT reference setting scheme is based on a crest factor of 20 dB which is presumably reached only for short peaks. 20 dB = 100x peak to average ratio."
that's not quite right. the "average" reference is targeted to about 85db in seat. the lfe channel comes in at 115db peak, or 30db higher, which is 1000x peak to 'average'.
good music recordings easily have 15db peak to average. horrible pop compressed recordings have peak to average in the 3-6db range.
LTD02 is offline
post #56 of 448 Old 08-28-2013, 02:18 PM
Point Source
beastaudio's Avatar
Quoted: 3496 Post(s)
Liked: 2826
And why not?!?!?! Haha
beastaudio is offline
post #57 of 448 Old 08-28-2013, 03:06 PM
DiscoDuck's Avatar
Quoted: 14 Post(s)
Back to the how many watts from a 20 amp receptacle discussion (saw this a little late): do not confuse alternating current watts at 120 volts and the rated output of an amplifier in watts as equal for determining how much power an outlet can deliver. My 1200 watt output rated rated amp consumes around 300 watts of 120v ac from the plug at reference levels and its not a terribly efficient design amp. Also dont forget that in the amp is the massive power supply which transforms the power to a lower voltage increasing the wattage ouput several fold. A circuit can deliver ten times the watts after a transformer has stepped down the voltage from 120 to 12 volts for instance.
Sr7009 + external amp for 9.3.4
jbl - northridge x11; sp6cii ceiling
Dayton HF15 sealed x2 on xls1500
av123 mfw15 w/ bash 300
DiscoDuck is offline
post #58 of 448 Old 08-28-2013, 03:09 PM
Suntan's Avatar
Quoted: 75 Post(s)
Liked: 107
Don't confuse wattage and amperage.
That said, yes, amp "watts" and "plug on the wall" watts are not exactly equal.
-Suntan
Suntan is offline
post #59 of 448 Old 08-28-2013, 09:26 PM
whoaru99's Avatar
Liked: 69
Right. Using the 10 times example, a load drawing 10A at 12V through a 10:1 transformer will draw 1A @ 120V. The power (120 watts) is the same on both sides.
Of course, there is some loss so it's not exactly 100%, but it is relatively small and not considered for sake of discussion to make the point. Generally, an audio amp has much lower overall efficiency than simply considering a transformer so, yeah, power available on the output side will always be meaningfully less than on the input side, until we have superconducting amps then it won't be much of a factor to consider.
whoaru99 is offline
post #60 of 448 Old 08-29-2013, 01:40 PM
bhazard's Avatar
Quoted: 86 Post(s)
Liked: 55
I should have mine today. Hopefully I have some time to hook it up.
bhazard is offline
Emotiva Xpa 5 5 Channel Power Amplifier
