AVS Forum | Home Theater Discussions And Reviews
AVS Forum | Home Theater Discussions And Reviews (http://www.avsforum.com/forum/)
-   DIY Speakers and Subs (http://www.avsforum.com/forum/155-diy-speakers-subs/)
-   -   New iNuke NU4 6000 - 4 channel amp (http://www.avsforum.com/forum/155-diy-speakers-subs/1483516-new-inuke-nu4-6000-4-channel-amp.html)
Gorilla83 07-28-2013 05:24 AM
Full credit goes to DD (Diamonddelts) from CHT forums for the find. Looks like Behringer is making the inuke6000 with power split into 4 channels now. There are a few places with them in stock and shipping now, and quite a few on ebay:
http://www.behringer.com/EN/Products/NU4-6000.aspx
http://www.gearclubdirect.com/behringer-inuke-nu4-6000
•Delivers 4 x 1500 Watts into 2 Ohms, 2 x 3000 Watts into 4 Ohms and weighs less than 12 lbs / 5.5 kg
Spec sheet:
http://www.behringer.com/assets/NU4-6000_WebBrochure.pdf
Should Plenty of power for those of us looking to power L/C/R setups or even Bi-amp the L/R.
rangers 07-28-2013 08:53 AM
That thing looks serious, too bad they don't make it in black....or do they
nater1 07-28-2013 09:37 AM
A dsp version and I would be set. Dsp please!
nethien 07-28-2013 10:54 AM
Just got my Inuke NU 6000, i should have waited a little more. Only 3 weeks ago i was told no scheduled release date yet for this beast in Europe.
One question : in the owner's manual, i did not find any mention about the exact speaker connector needed to get the power to my DIY subs. I found both 2 pole and 4 pole Neutrik/Speakon connectors. Does the speaker terminal on the Inuke take both or is there a difference ?
Sorry for the thread hijack and noob question.
N8DOGG 07-28-2013 11:00 AM
7 Attachment(s)
One question : in the owner's manual, i did not fond any mention about the exact speaker connector needed to get the power to my DIY subs. I found both 2 pole and 4 pole Neutrik/Speakon connectors. Does the speaker terminal on the Inuke take both or is there a difference ?
I use 2 pole speakons on my 6000. You can use either one.
bhazard 07-28-2013 01:29 PM
Possible Emotiva competition to the XPA-5? Looks pretty sweet, and a good price too (which will eventually go down a bit through a sale or coupon)
BassThatHz 07-28-2013 03:30 PM
The 6000 has always been crippled in this regard. I guess this amp solves that. (I assume it has internal 4x4 channel matrixing, or at least 2x4.)
First this came out.
http://labgruppen.com/products/fp_plus_series/c/fp_10000q/
Then this.
http://www.crownaudio.com/usa/amplifiers/i-tech4x3500hd.html
Then this.
and then!!!!!!!!!!!!!!!!!!
Nu4-12kDSP? eek.gif...
Me likes where this is going.
Jay1 07-28-2013 04:00 PM
29 Attachment(s)
Looks like a pair of nu3000's in a single chassis.
8 Ω per channel 4 x 440 W
4 Ω per channel 4 x 860 W
2 Ω per channel 4 x 1600 W
Not bad for $550
atabea 07-28-2013 04:35 PM
Not bad for $550
So if I were to get four SI 18s and four flat packs from Erich, all I would need for power is one of these? If that is the case, would it matter if I got the D4 or D2? What would be a better match?
Jay1 07-28-2013 05:14 PM
29 Attachment(s)
Yes, it looks like you should be fine. For true RMS power, you should get 650 WPC x 4 into 4 ohm loads, and 1000 WPC x 4 into 2 ohm loads. Getting power from a standard 20 amp wall outlet looks like it could be an issue...
A 20 amp breaker will barely support the 4 x 650 W, and that is with the amp being the only device on the breaker (you could still blow it with max power though). A 30 amp breaker can not support 1000 W x 4. If you have a 50 amp breaker for your HT, then quad 2 ohm subs should work, other wise the quad 4 ohm setup will work better.
LTD02 07-28-2013 06:27 PM
^^ just remember that speaker loads are not purely resistive loads, so they don't pull full current except under extreme instances and the breaker will often let through a little overcurrent for short bursts.
atabea 07-28-2013 06:42 PM
Thanks Jay1, looks like i will go with D4s then.
Jay1 07-28-2013 07:46 PM
29 Attachment(s)
True, but a 20 amp breaker only supports 2400 watts right? That's 200 watts less then max continuous power at 4 ohms, and doesn't account for peaks.
Mike-ht 07-28-2013 09:02 PM
I think you are only supposed to load the circuit with 80% of it's rated maximum in the code. However I suspect this amp will have a 700w rating at the plug, based on my iNuke 3000 DSP having a 350w label. On the other hand, breakers don't trip right at the amperage they are rated for, in order to allow for surges when electric motors start up. You might be able to pull twice the rated current for 30 seconds to a minute before the breaker trips, or 4x the current for 15 seconds or so. Something like a Kill-A-Watt can let you monitor how much current you are actually pulling from the wall, to see if a dedicated circuit is a good idea.
N8DOGG 07-28-2013 10:11 PM
7 Attachment(s)
If any of us can run a clone on a 20A breaker, these will be a piece of cake.
jonathanc 07-28-2013 11:05 PM
Now if they made an nu5-6000...
Jay1 07-28-2013 11:08 PM
29 Attachment(s)
Just saying, it's something to look at.
Martycool007 07-29-2013 04:59 AM
I seriously wish that Behringer would come out with a 4 channel iNuke with Dsp. That would make life much more simple! That way I could use an iNuke as an amp for my LCR's and have built in EQ and possibly be able to use them as an active crossover. For right now, though, I have my eyes set on the new plate amp with dsp from MiniDsp.
arnyk 07-29-2013 06:05 AM
Depends if you are playing music or test tones.
Music has a crest factor of at worst 6-8 dB. The standard HT reference setting scheme is based on a crest factor of 20 dB which is presumably reached only for short peaks. 20 dB = 100x peak to average ratio.
Going back to that utter worst case number of 6 dB, that is 4x power suggesting that your 20 amp circuit can actually support 9600 watts of real world music or movies.
MemX 07-29-2013 06:55 AM
Quick and probably dumb question...
Does the fact that european voltage is ~230-250v (as opposed to the US 110v, IIRC?) make any difference to the 20amp breaker issue?
I've just been pricing up a quad-SI18 build using a nu6000dsp at 2x3000w (c.2x2100wrms) and I'm aware that I currently have just two wall sockets, into which goes two multi-plug sockets that are running the TV, FreeSat box, PB12-Plus/2, BD Player, Onkyo AVR, VCR, cassette player... and on the same ring main (I believe) are plugs for the fishtank pump and heater, microwave, washing machine, fridge, freezer... LoL biggrin.gif
JWagstaff 07-29-2013 07:19 AM
This will be super useful for powering a L, R, C and a subwoofer or L, R, Sub or L, R, 2 subs. I wish they would make it look a little more "plain". I assume this will have ~10 hz rolloff like the other inukes?
I might get this down the road once I build my tempest mains, and then I can add another sub or 2 biggrin.gif
Freniata 07-29-2013 07:20 AM
If this is somewhat true, it amazes me how many people go out of their way to upgrade electrical circuitry when it may not be needed.
vinodk 07-29-2013 08:24 AM
This will be perfect to run two FTW-21's. Hopefully the fan is as quiet as Crown XLS. Any fan mods for Behringer iNuke units?
Stumbo 07-29-2013 09:05 AM
The nu6000 would work just as well, and is a bit cheaper. The fans are very, very loud.
nater1 07-29-2013 09:30 AM
People have done the fan mod on other inukes with good results, but the stock fans are LOUD.
Scott Simonian 07-29-2013 10:46 AM
135 Attachment(s)
I'm so buying these. Basically two nu3000's in one 2RU case and at 12lbs a pop? Yup... buying at least three. biggrin.gif
I got an awesome budget multi-sub approach with this one. Buy one and purchase four SI18d4's. Then run them dual's in 4ohm for 3000w or wire coils for a 2ohm load each and put in separate enclosures for quad @ 1,600w each.
simp1yamazn 07-29-2013 01:59 PM
3 Attachment(s)
Sounds like these could be a good option for my LCR and sub. LCR are all 4 ohm so 860w for the LCR and then wire my dual opposed sub in parallel for 1600w at 2 ohms. Any reason this wouldn't be awesome?
JWagstaff 07-29-2013 02:25 PM
I'm so buying these. Basically four nu3000's in one 2RU case and at 12lbs a pop? Yup... buying at least three. biggrin.gif
it's two nu3000's, not four. It's four 1500W amps technically I think.
Scott Simonian 07-29-2013 02:41 PM
135 Attachment(s)
carp 07-29-2013 04:15 PM
Before I finished my 8 subs I had 2 dedicated lines run, both 20 amps. I thought that would be fine based on advice from the forum but I wish I had gone with 30 at least. I've tripped my breaker 10 times roughly and I want a setup where it never happens.
I have a CV 5000 powering 8 18" SI subs, so that does mean that all subs are on the same line since it's just the one amp powering all of them, so I'm betting I'll have much less of an issue if I someday buy another amp so that I'm running 4 subs off each amp or buy a more efficient amp to run all 8 (new Peavey perhaps?)
Still, it's not a huge deal. The only time I trip the breaker is when doing demo's at insane levels and even then the breaker only goes once or twice at the most after a lot of bass scenes. It has never happened at normal movie viewing/music listening levels (reference and below) and I'm positive it never will.
Powered by vBulletin® Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
