First Ever Fusion-8 Alchemy MTM Build Thread, Piano Black Finish - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #91 of 132 Old 10-14-2013, 04:44 AM
pbc
pbc's Avatar
Quoted: 414 Post(s)
Liked: 214
I'd love to see/hear them as well though finding the time may prove impossible these days!
My DIY Subs ... http://www.avsforum.com/avs-vb/showthread.php?t=1233892
J Dunlavy:.. if you stop to think about it, no loudspeaker can sound more accurate than it measures.
pbc is offline
post #92 of 132 Old 10-14-2013, 09:10 PM - Thread Starter
JWagstaff's Avatar
Quoted: 28 Post(s)
Liked: 71
Yeah just haven't gotten around to taking a finished picture yet
JWagstaff is offline
post #93 of 132 Old 03-28-2014, 09:37 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2698
I'm about to start on a pair of fusion 8s and is love to see some final pictures. I'm considering the same finish but it looks labor intensive smile.gif
Mfusick is offline
post #94 of 132 Old 03-28-2014, 11:40 AM - Thread Starter
JWagstaff's Avatar
Quoted: 28 Post(s)
Liked: 71
yeah definitely very labor intensive. After this really dry winter the "cracks" where the wood joins each other seems to have made little ridges. So there's a few lines on the finish now, I'm going to try to fix it this summer. The nice thing about this black paint I used is that technically it never fully cures, so when you spray more on it it will basically melt into itself and form a new full layer. Here's some pictures I took with my phone. They came out a weird blue tinge. The second picture half the speaker is covered in dust. The last picture you can see the line that developed over the winter.
post #95 of 132 Old 03-28-2014, 12:35 PM
pbc
pbc's Avatar
Quoted: 414 Post(s)
Liked: 214
Nice grill, how did you attach it? Magnets or otherwise?
pbc is offline
post #96 of 132 Old 03-28-2014, 02:21 PM - Thread Starter
JWagstaff's Avatar
Quoted: 28 Post(s)
Liked: 71
post 85 has some pictures of the grill construction. I have 4 neodymium magnets embedded in the front of the speaker, and the frame has 4 metal L brackets on the corners that stick to the magnets
post #97 of 132 Old 03-29-2014, 05:39 AM
pbc
pbc's Avatar
Quoted: 414 Post(s)
Liked: 214
Did you simply use a thick drill bit to get a hole for the magnets in the baffle?
pbc is offline
post #98 of 132 Old 03-29-2014, 06:45 AM
tuxedocivic's Avatar
Quoted: 2201 Post(s)
Liked: 2075
Ouch on that line. I've had MDF telegraph through veneer and have seen it even in duratex (someone else's speaker). How do you plan on getting rid of it? Just spray more on or sand it out first.
My youtube channel: Impulse Audio
tuxedocivic is offline
post #99 of 132 Old 03-29-2014, 12:37 PM - Thread Starter
JWagstaff's Avatar
Quoted: 28 Post(s)
Liked: 71
yeah i used a drill bit the same size as the magnet and then i put some glue in and then hammered the magnet in.
post #100 of 132 Old 03-29-2014, 12:38 PM - Thread Starter
JWagstaff's Avatar
Quoted: 28 Post(s)
Liked: 71
yeah probably just lightly sand it with some high grit to get rid of the line and the wax on it and then re-coat and then re-wax
post #101 of 132 Old 04-29-2014, 10:55 AM - Thread Starter
JWagstaff's Avatar
Quoted: 28 Post(s)
Liked: 71
So does anyone have any ideas why a lot of the lines appeared through the finish after this winter? They are on almost every joining area where the sides join the top and front. I wonder if putting wax on only a few days after the lacquer did it? Or the primer didn't fully seal the MDF and after this dry winter it sunk in? I'm going to be fixing it soon, as well as doing a subwoofer in piano black, so I'd like to figure out what went wrong so I can fix it and also change the painting process for my subwoofer so this doesn't happen again. You can see the line that appeared in the last picture I posted a couple posts up. Lines like that are also on the sides and the back of the top.
post #102 of 132 Old 04-29-2014, 11:09 AM
pbc
pbc's Avatar
Quoted: 414 Post(s)
Liked: 214
There's a great thread that I will try to locate later for you on how all seams on my will eventually show. Likely due to the expansion/contraction of mdf. Either on parts express or diyaudio.
The poster attempted several methods to mitigate the seam bleed, can't recall which worked best. Think it was cutting a trough into the seams and refilling the trough with a specific filler.
pbc is offline
post #103 of 132 Old 04-29-2014, 11:13 AM
mtg90's Avatar
Quoted: 496 Post(s)
Liked: 974
That's the expansion/contraction of the MDF due to temp and humidity changes, it's almost impossible to entirely prevent. You almost need to use a veneer over the MDF to prevent the joints from becoming visible or use a thick resin like coating to seal the MDF before painting.
mtg90 is online now
post #104 of 132 Old 04-29-2014, 11:25 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2698
What about something like bondo in the joint ? or over the top ?
Mfusick is offline
post #105 of 132 Old 04-29-2014, 11:31 AM
Liked: 2075
I think this would be effective. Smother the whole thing in epoxy or some kind of MDF sealer. Sand it back, then start the finishing process. I'd be tempted to give the mdf edges a sip of yellow glue and water 1:1 mix before the epoxy. Get the edges to swell and harden, then sand them back. Then epoxy. That would make it pretty stable.
Plywood would have been more stable probably, but those edge never disappear. Doesn't matter how much sanding you do cool.gif
Sorry about your luck.
post #106 of 132 Old 04-29-2014, 12:55 PM
Sibuna's Avatar
Quoted: 381 Post(s)
Liked: 449
Bondo should work, same with the 1/1 mix of glue and water, both "should" seal MDF so this does not happen.
ive been lucky with my boxes i just coated in duratex as it did not show and I have some wicked humidity swings to the point where i use a humidifier in the winter that goes through 2 gallons a day and cant keep up, and a de-humidifier in the summer that just has a drain hose and runs 24/7
Sibuna is offline
post #107 of 132 Old 04-29-2014, 01:18 PM - Thread Starter
JWagstaff's Avatar
Quoted: 28 Post(s)
Liked: 71
I was under the impression that shellac primer I used sealed the MDF
So if I fix these lines do you think they will reappear after it gets more humid in the summer and then dry in the winter again?
post #108 of 132 Old 04-29-2014, 01:27 PM
Liked: 2075
The shellac would put a top coat on it, but wouldn't penetrate that edge I don't think.
I had some movement around my waveguides that I bondo smoothed into place. They showed a witness line around the corners of the waveguide. Even though I prepared and primed the joint thoroughly. And that wasn't an edge. MDF edges are worse yet.
You might be fine now if they acclimated, but piano black is very sensitive to imperfections.
post #109 of 132 Old 04-29-2014, 03:20 PM
btinindy's Avatar
Quoted: 38 Post(s)
Liked: 56
I have used fiberglass resin all over the MDF including the edges. It seals and also fills and somewhat self levels in any small enough gaps. It smells nasty, but sands decent and have not had any problems. I have not used it in a while since most projects have not been highly visible.
If you have larger gaps in the seams use bondo and then use a couple of coats of BIN primer with light sanding in between coats. If you wanted a "guarantee" trench the seam which a v shape router bit or a Drexel tool and fill it with bondo.
btinindy is offline
post #110 of 132 Old 04-29-2014, 04:54 PM
pbc
pbc's Avatar
Quoted: 414 Post(s)
Liked: 214
I've read that the seams eventually show through even veneer which I found surprising.
Here is the thread BTW...
http://techtalk.parts-express.com/showthread.php?214399-Best-methods-for-finishing-MDF/page5
pbc is offline
post #111 of 132 Old 04-29-2014, 04:58 PM
Liked: 2075
To late now, so this advice isn't all that useful for you, but maybe someone else. If doing a piano black finish, always good to mitre fold the mdf. Even then, don't want the corners to show a crack. Takes a ton of work to get it prepared.
post #112 of 132 Old 04-29-2014, 05:37 PM
JohnDean's Avatar
Quoted: 470 Post(s)
Liked: 207
Is it possible that the moisture gets in through the ports and effects the inside?
JohnDean is offline
post #113 of 132 Old 04-29-2014, 05:46 PM - Thread Starter
JWagstaff's Avatar
Quoted: 28 Post(s)
Liked: 71
It's useful advice as I'm doing an 18" sub this summer and I plan on doing it piano black again. Also going to do L/R some time in the future as well.
post #114 of 132 Old 04-29-2014, 05:47 PM - Thread Starter
JWagstaff's Avatar
Quoted: 28 Post(s)
Liked: 71
I guess it would be possible in certain situations, but I don't think so because in my case it was EXTREMELY dry this winter where I have my speaker.
post #115 of 132 Old 04-29-2014, 05:50 PM - Thread Starter
JWagstaff's Avatar
Quoted: 28 Post(s)
Liked: 71
so bondo for bigger gaps and fiberglass resin for small ones? Can they be used on the same surface? Which one is better overall?
post #116 of 132 Old 04-29-2014, 05:50 PM
UA_Iron's Avatar
Great thread so far, thanks for posting.
I came across another thread on another forum about how to paint mdf to a mirror finish... He used Vinyl Spackling on the edges of the MDF to prevent it from continuing to soak up like a sponge.
Here's the thread:
http://forums.shoryuken.com/discussion/67501/how-to-paint-mdf-to-a-mirror-finish-worklog
UA_Iron is offline
post #117 of 132 Old 04-29-2014, 05:53 PM
JohnDean's Avatar
Quoted: 470 Post(s)
Liked: 207
Extremely dry can be even worse. I found that out the hard way this winter when the bridge on my Martin D-35 cracked.mad.gif
JohnDean is offline
post #118 of 132 Old 04-29-2014, 07:46 PM - Thread Starter
JWagstaff's Avatar
Quoted: 28 Post(s)
Liked: 71
Here's the thread:
Yeah I was actually just looking at that thread today. The thing about his though is he just did one side of a small piece of mdf, and if you look it has a lot of visible imperfections around the edge so there's no way to tell if that is any better than just using wood filler and shellac sealer. The problem with mine is on the joining edges, not the sides. I think I might try a high-lustre clear gloss lacquer on top of my black paint this time like he did, as his looks quite shiny - shinier than mine is.
post #119 of 132 Old 04-29-2014, 07:53 PM
btinindy's Avatar
Quoted: 38 Post(s)
Liked: 56
Overall, I would say bondo. You have to work very quickly with it though and it can also be tougher to sand, but it holds up the best that I have seen and is relatively inexpensive compared to the high priced wood epoxy's on the market.
It really all depends on how you are planning on finishing them.
LTD02 likes this.
btinindy is offline
post #120 of 132 Old 04-29-2014, 09:43 PM
UA_Iron's Avatar
Some other thoughts:
1. Glue/adhesive and chemical compatibility of it and the paints - it's possible that it could lead to a witness mark like that.
2. It has something to do with the expansion and contraction of MDF - the two panels could be expanding/contracting opposite each other and causing a sheering motion, or some kind of moment is created where the panels pull apart from each other.
Unlike solid wood which sees the greatest expansion and contraction parallel to the growth rings but changes very little in length (0.15%), the composite nature of MDF causes it to expand and contract equally in both width and length (0.3%). This means that in general you should expect less movement across the width of an item in MDF compared to solid wood, but you should expect much greater movement in length.
http://www.koetterwoodworking.com/controlling-wood-movement-part-ii-mdf-and-new-product-announcement-2/
I'm betting it has to do with humidity conditions more than anything else. If the outside of the box is properly treated sealing out any moisture, you might look to coating/treating the inside of the box to create the same moisture barrier.
UA_Iron is offline
Fusion 8 Inch Super Slim Under Seat 300w Amplified Subwoofer
