First Ever Fusion-8 Alchemy MTM Build Thread, Piano Black Finish - Page 5 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #121 of 132 Old 04-30-2014, 06:49 AM - Thread Starter
JWagstaff's Avatar
Quoted: 28 Post(s)
Liked: 71
Originally Posted by UA_Iron View Post
Some other thoughts:
1. Glue/adhesive and chemical compatibility of it and the paints - it's possible that it could lead to a witness mark like that.
2. It has something to do with the expansion and contraction of MDF - the two panels could be expanding/contracting opposite each other and causing a sheering motion, or some kind of moment is created where the panels pull apart from each other.
http://www.koetterwoodworking.com/controlling-wood-movement-part-ii-mdf-and-new-product-announcement-2/
I'm betting it has to do with humidity conditions more than anything else. If the outside of the box is properly treated sealing out any moisture, you might look to coating/treating the inside of the box to create the same moisture barrier.
Yeah I think you're right about treating the inside. Is it a common thing to treat the inside I don't think I've ever seen a build thread where someone did it?
JWagstaff is offline
post #122 of 132 Old 04-30-2014, 07:44 AM
UA_Iron's Avatar
It was a thought - it doesn't look like its super common but it is definitely a topic that has been mentioned on other forums.
Expansion/contraction is hurting the finish, sealing the inside might help mitigate that but not fully solve the problem. It's something at the interface that's probably causing it.
UA_Iron is offline
post #123 of 132 Old 05-08-2014, 10:55 AM - Thread Starter
JWagstaff's Avatar
Quoted: 28 Post(s)
Liked: 71
Ok I grabbed some bondo today to try on my next build - I hope I bought the right one. There was just "body filler" in medium to large size cans, with 2 separate materials you have to mix, and then they had a tube of bondo spot putty which was just one paste and no mixing required. I bought the body filler as it seems stronger and better value, was that the right choice?
post #124 of 132 Old 05-08-2014, 12:29 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2687
Yes
Easy to use. Hardens great and sands great. Just follow the instructions it should work great.
Mfusick is offline
post #125 of 132 Old 05-08-2014, 02:27 PM
UA_Iron's Avatar
It looks like in your build pictures that you dont have inner braces?
That could be another element to this puzzle. The speaker is like a pressure vessel at high SPLs, the wood will want to expand everywhere outward. Inner bracing would keep the entire thing more rigid.
Just some more thoughts lol...
UA_Iron is offline
post #126 of 132 Old 05-08-2014, 02:56 PM - Thread Starter
JWagstaff's Avatar
Quoted: 28 Post(s)
Liked: 71
Correct.. I didn't think they were needed on something this small. It's ported though so would it have that much pressure inside?
post #127 of 132 Old 05-08-2014, 04:10 PM
chalugadp's Avatar
Quoted: 1672 Post(s)
Liked: 1508
Yes you need braces. I put one on either side of waveguide.
chalugadp is offline
post #128 of 132 Old 05-08-2014, 06:42 PM - Thread Starter
JWagstaff's Avatar
Quoted: 28 Post(s)
Liked: 71
should i take the drivers out and add some in?
post #129 of 132 Old 05-08-2014, 06:44 PM
chalugadp's Avatar
Liked: 1508
Yes. I have mine crossed over at 90hz and if you play it loud put your hand on the box. Those woofers are moving, not like a sub, but will reasonate.
post #130 of 132 Old 05-08-2014, 07:09 PM - Thread Starter
JWagstaff's Avatar
Quoted: 28 Post(s)
Liked: 71
yea makes sense, I'm actually not sure why I didn't brace it now that I think about it
post #131 of 132 Old 09-23-2014, 03:15 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2687
You didn't use any braces ?
Mfusick is offline
post #132 of 132 Old 10-19-2014, 09:54 AM
jdaddieo's Avatar
Quoted: 13 Post(s)
Liked: 25
Nice Job
Nice work but what I'm curious about is how do they sound and do you have any testing specs on them yet?
jdaddieo is offline
Fusion 8 Inch Super Slim Under Seat 300w Amplified Subwoofer
