Why not more talk about Waveguide damping and/or foam inserts - Page 5 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #121 of 126 Old 08-17-2015, 06:15 PM
Quoted: 945 Post(s)
Liked: 317
Originally Posted by Jag768 View Post
+1
if you do the comparison, than ideally the response should be EQ-ed to be equal. For the Klipsch speakers, the harsh sound could also be related to diffraction issues.
sorry, can you expound on what you are suggesting. im not quite sure im following.
1201 is offline
post #122 of 126 Old 08-18-2015, 10:39 AM
Jag768's Avatar
Quoted: 18 Post(s)
Well when you put in foam in your waveguide, three things can happen:
- amplitude response changes (this is for sure, it will result in a low pass filter)
- directivity changes
- HOMs are reduced
The idea is, that the latter is responsible for the audible improvement. But the only way to know is by making sure the other two are not the case. So you need to correct the amplitude response after inserting the foam, and measure the directivity to make sure it's equal. If it's not, than you might take them into an anechoic environment (like outdoors) to reduce the effect the directivity has on the audible quality. But it's a hassle, i understand .
Jag768 is offline
post #123 of 126 Old 08-18-2015, 08:40 PM
Quoted: 945 Post(s)
Liked: 317
oh, i see. thanks for the clarification
1201 is offline
post #124 of 126 Old 08-19-2015, 04:30 AM
Quoted: 945 Post(s)
Liked: 317
one thing i did notice is that as you add stuff to the front of a speaker,the distortion increases- the lowest distortion measured by REW is with no grill or fill
1201 is offline
post #125 of 126 Old 08-19-2015, 05:13 PM
Quoted: 995 Post(s)
Liked: 522
That's purely a function of the lowered efficiency.
Besides, harmonic distortion at these levels is perceptually completely irrelevant.
"In many cases there aren’t two sides unless one side is 'reality' and the other is 'nonsense.'" - Phil Plait
Serious Audio Blog
DS-21 is offline
post #126 of 126 Old 08-20-2015, 10:34 PM
Quoted: 945 Post(s)
Liked: 317
roger that. thanks
1201 is offline
