Why not more talk about Waveguide damping and/or foam inserts - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #1 of 126 Old 07-31-2013, 07:22 AM - Thread Starter
goonstopher's Avatar
Quoted: 286 Post(s)
Liked: 55
I know this has been discussed but there seems to be little adoption or clear "how-to" for both horn damping (mass loading the rear) or foam inserts.
I just made a set of seos speakers and my ears must be sensitive (I find all metal domes and all klipsch speakers unlistenable) because the "honk" is just too much for me to handle.
It sounds like the waveguide difracting or somehow "vibrating" - It's hard to put into words but its like reverb of harshness that you don't want reverb-ed.
Long post short:
Are there any (simple) resources on how to dampen/mass load waveguides and what foam to try in them?
Is there some reason these practices are not more widely discussed/used?
goonstopher is offline
post #2 of 126 Old 07-31-2013, 07:42 AM
JWagstaff's Avatar
Quoted: 28 Post(s)
Liked: 71
maybe it's an effect of your room, do you have absorption on first reflection points?
What is the content you are playing? What is your source?
JWagstaff is offline
post #3 of 126 Old 07-31-2013, 08:13 AM - Thread Starter
Quoted: 286 Post(s)
Liked: 55
I've had many speakers including JTR Quint 8's. Source doesn't matter (blu-ray or TV) its all "honky"
I know it's partially just horns nature and my ears but all I can describe it as is "honk" or harshness.
I am going to have my crossovers professionally made to eliminate that factor but am sure I will still notice the harshness.
I'd like to hope that treating the back of the WG and possibly foam would help but there is so little easy to find info on how to do it. (I've searched)
post #4 of 126 Old 07-31-2013, 08:28 AM
bwaslo's Avatar
Quoted: 66 Post(s)
Liked: 182
You do have "CD" compensation in your crossover for the SEOS, right? (constant directivity waveguides with compression drivers don't have a flat response inherently, it has to be flattened in the crossover or it will sound pretty nasal).
___________________________________________
DIY Synergy horn spreadsheet Synergy horn spreadsheet and pdf
XSim -free crossover designer and simulator XSim install file
Easy and cheap sound diffusers (the "Depot Diffusers") making easy DIY depot sound diffuser-panels-step by step.html
SmallSyns - point source controlled directivity in a manageable size SmallSyns
bwaslo is offline
post #5 of 126 Old 07-31-2013, 08:32 AM - Thread Starter
Quoted: 286 Post(s)
Liked: 55
Its not nasal its painful resonance. The speaker is pre designed not one I made up so there is no compensation as side from the crossover design
post #6 of 126 Old 07-31-2013, 09:06 AM
nater1's Avatar
Which design did you build? Are you sure the crossover is correct? I think why you don't read more about foam and mass loading is most people find the listening experience to be pleasant without them.
wvu80 likes this.
nater1 is offline
post #7 of 126 Old 07-31-2013, 09:39 AM
tuxedocivic's Avatar
Quoted: 1905 Post(s)
Liked: 1725
Use open cell foam if you give it a whirl. It'll sound different, but mostly cause it's attenuating the high frequencies more. It'll give it a more laid back sound.
I find Klipsch speakers to sound pretty "honky", but not the SEOS. This is mostly cause the new Klipsch stuff has bright treble to give them a really high apparent sensitivity. Not good.
Like I said to you in PM, as long as those caps in the woofer leg are wired in series, your speaker will not sound right. That cap changes everything at the XO. It's not a matter of a couple db, it's gonna be fairly noticeable. Very noticeable.
Ryan
tuxedocivic is online now
post #8 of 126 Old 07-31-2013, 09:53 AM
bwaslo's Avatar
Quoted: 66 Post(s)
Liked: 182
And without the CD comp in the crossover, it's gonna sound terrible (and will emphasize any distortion in the source, making things sound harsh). You can't just slap any crossover on a CD+Waveguide and expect even tolerable results.
bwaslo is offline
post #9 of 126 Old 07-31-2013, 10:02 AM - Thread Starter
Quoted: 286 Post(s)
Liked: 55
I fixed the capacitors and the sound went down hill. It went from maybe noticeable here and there to somewhat frightening (I was scared to turn up the volume).
I am sending out my crossovers to mtg90 to get fixed... I just hope it doesn't take too long but oh well I shouldn't have even tried to make them.
i will likely use the down time to bondo/putty the back of the horns and look into foam
post #10 of 126 Old 07-31-2013, 10:02 AM - Thread Starter
Quoted: 286 Post(s)
Liked: 55
The kit is from DIY sound group. It's not off the shelf, it's designed and built for these components.
post #11 of 126 Old 07-31-2013, 10:23 AM
zheka's Avatar
Quoted: 29 Post(s)
Liked: 26
could it be a room flutter issue? is the harshness SPL depended?
horn based speakers manage to excite the room much more easily than conventional mid-low sensitivity ones. at least that's my experience.
zheka is offline
post #12 of 126 Old 07-31-2013, 10:31 AM
Bill Fitzmaurice's Avatar
Liked: 4628
Horns don't 'honk', other than those used on cars and by clowns. What's often referred to as 'honk' is when the sensitivity of the horn is higher than that of the low frequency section, and it has not been properly compensated for via level and EQ adjustments. Another issue can be when the higher frequency dispersion is much narrower than the lower frequency dispersion, which is common in horns. One method to address that is to use a relatively high density foam plug that causes diffraction of the shorter wavelengths, broadening dispersion, while have a lesser or even no effect on longer wavelengths. The cost of so doing is lowered sensitivity, but that can also help to better level match horn loaded highs to the direct radiating lows.
Bill Fitzmaurice is online now
post #13 of 126 Old 07-31-2013, 10:39 AM
mastermaybe's Avatar
Quoted: 362 Post(s)
Liked: 305
Long post short:
While I respect your ambition and open mindedness, I think you may be searching for a solution that doesn't exist or at least will not be sufficient for you. I of course also hope to be wrong, for your sake. smile.gif
I've auditioned (and owned) dozens of horn loaded speakers and have since arrived at the conclusion that their sound isn't for me...and apparently not for the vast, vast, majority of loudspeaker manufacturers and consumers for one reason or another. I (perhaps naively so) think the loudspeaker manufacturers are in the business of producing loudspeakers that sound good as to produce sales and a profit, so it behooves them to do so...never mind the fact that many of them have spent decades and millions of dollars R&D'ing to improve upon previous iterations.
That doesn't mean they all sound bad, some of them have actually sounded quite good, it's just that there appears to me to be many more comparably-priced options that sound better. Of course I'm always open to any new design/adaptation.
Because of their remarkable efficiency and (potentially insane) output, it's not surprising to me that they are wildly popular with the DIY set, I just feel there are superior options out there for most.
Sounds like you may be one of them. No big deal, we have plenty of options.
Good luck with any mods, please report back.
James
Actual phone call (see pic to left):
Tech (responding to laughter): "I'm sorry sir, did I miss something?"
Me: "Yeah, a case of Diet Mountain Dew walking across my living room."
mastermaybe is offline
post #14 of 126 Old 07-31-2013, 10:48 AM
Liked: 1725
Well if it got worse, either the XO is still wrong or you don't like the speaker. I'm not sure foam will fix that. Once MTG does the XO'ers maybe the problem will be fixed.
Can you describe the sound problem better? Is it high frequency brightness? That can be adjusted pretty easily. Honk is usually referred to in the midrange, right around the XO. A nasally sound in singers. The SEOS12 is very inert, so it's likely a frequency response type thing bothering you. Let us know what the sound is.
Bill W. I didn't use a discrete compensation network on this one, but there is some HF compensation built into the XO. If anything, I'd say I voiced these a little on the bright side because originally guys were gonna use them as surrounds in big systems. And I put an adjustable resistor to take out some brightness if needed. But I'm not sure anyone has ever played with that resistor. It's 2 x 3ohms in parallel. The idea was a user could wire it up and clip out one of the 3ohms if the speaker was to bright. I liked it with 1.5ohm and toed in, but some people may prefer the 3ohms, including the OP.
Ryan
post #15 of 126 Old 07-31-2013, 10:52 AM - Thread Starter
Quoted: 286 Post(s)
Liked: 55
It is not in high frequencies. There is a certain band.
Lower frequency instruments or more excited/higher frequency voices.
It can get a little painful at times... I may end up getting the completed xovers and just taking the loss on the used market if its just a "horn thing"
post #16 of 126 Old 07-31-2013, 11:09 AM
rajacat's Avatar
Quoted: 52 Post(s)
Liked: 31
James
Have you actually heard any of the SEOS designs? The OP is the first that I've read who's having a problem with the sound quality of the SEOS designs. Most have commented on the smoothness of the sound and the ability to play very loud without audible distortion. Wouldn't this imply any tendency to "honk" has been mitigated. Isn't honk distortion? Does live acoustical music honk?
rajacat is offline
post #17 of 126 Old 07-31-2013, 11:37 AM
pnw
pnw's Avatar
Quoted: 47 Post(s)
Liked: 76
The foam you're looking for is usually stocked at aquarium supply stores. 30ppi filter foam IIRC. (Personally, I've found a shelving curve like S Linkwitz currently uses tames midrange/low treble harshness...there is no reason to fear EQ if you can use measurement gear.)
pnw is offline
post #18 of 126 Old 07-31-2013, 11:38 AM
wormraper's Avatar
Quoted: 313 Post(s)
Liked: 154
James
speaker mfg's are trying to sell you speakers that are made as cheaply as possible for as much money as possible. horns are more expensive to make than other models. Compression drivers cost way more than cheap tweeters etc. Horn based speakers also require more building materials to create a larger cab. to think that horns are shunned because of poor audio quality is NUTS.
wormraper is online now
post #19 of 126 Old 07-31-2013, 12:27 PM
Quoted: 362 Post(s)
Liked: 305
No I have not, but I'm prolly going to build a pair myself in the near future. I don't mean to deride every horn loudspeaker produced. Again, I have just found better options, thus far, personally.
James.
post #20 of 126 Old 07-31-2013, 12:42 PM
Quoted: 362 Post(s)
Liked: 305
Originally Posted by wormraper View Post
speaker mfg's are trying to sell you speakers that are made as cheaply as possible for as much money. horns are more expensive to make than other models. Compression drivers way more than cheap tweeters etc. Horn based speakers also require more building materials to create a larger cab. to think that horns are shunned because of poor audio quality is NUTS.
That's not what I said. And certainly it's incorrect to say "speaker manufacturers are trying to sell you speakers that are made as cheaply as possible for as much money".
There are cheap speakers made cheaply. There are expensive speakers made with a cost-no object approach. Most fall in the middle and those who do not produce a competitive speaker at any price point won't last long.
"Compression drivers way more than cheap tweeters etc." I have no clue what you're saying/contending, here. Probably that compression drivers are much more expensive than cheap tweeters...but that goes without saying, doesn't it? What about expensive tweeters vs cheap compression drivers? confused.gif
I will say that I've been in more than my fair share of studios and have never seen a horn-driven loudspeaker system. Ever. I'm certain this is not because they cannot afford the price or have the space for a horn loudspeaker.
My inclination is that they are- again- primarily purposed towards applications that require extremely high SPL, efficiency and controlled directivity. And that is- again- not to say that they all sound bad, but just may not offer the characteristics of what many consider to be excellent or "reference" sound.
I don't operate in a world of absolutes. I'm simply giving my personal experience which I consider to be pretty substantial at this point in my life...especially so relative to the typical hobbyist.
James
post #21 of 126 Old 07-31-2013, 01:26 PM
rajacat's Avatar
Quoted: 52 Post(s)
Liked: 31
James
How about these AudioKinesis studio monitors. I suspect that there are many pro studios that use waveguide based speakers. I can hardly go to a concert without seeing waveguide/horn monitors being used.
http://www.audiocircle.com/index.php?topic=99552.0
http://www.audiocircle.com/index.php?topic=117991.0
...Roy
rajacat is offline
post #22 of 126 Old 07-31-2013, 01:45 PM
JWagstaff's Avatar
Quoted: 28 Post(s)
Liked: 71
I have never seen a movie theater or a concert venue that doesn't use horns.
post #23 of 126 Old 07-31-2013, 02:11 PM
djginwis's Avatar
My quick research into OP's posts in a build thread lead me to believe that there may be an issue with his crossovers.
djginwis is offline
post #24 of 126 Old 07-31-2013, 02:20 PM - Thread Starter
Quoted: 286 Post(s)
Liked: 55
You may be right but after checking the crossover MANY times... I'm a bit worried I might just not like horns...
Klipsch sounds like painful death to me, maybe I expected too much from these
post #25 of 126 Old 07-31-2013, 02:22 PM
djginwis's Avatar
Certainly everyone has different ears, I hope your project turns out well for you.
djginwis is offline
post #26 of 126 Old 07-31-2013, 02:26 PM
Face2's Avatar
Quoted: 334 Post(s)
Liked: 201
If all those speakers sound wrong to you, have you found any that sounded right? Can you describe your room and gear?
Face2 is online now
post #27 of 126 Old 07-31-2013, 02:28 PM - Thread Starter
Quoted: 286 Post(s)
Liked: 55
I've heard klipsch i other rooms not mine and hated each more then the first. The Heresy 2 sounded like 2 cats fighting a chalk board to me.
I loved JTR's, they totally lacked the harshness. I thought maybe horns could come close with the right design.
If this is anything else but the crossover then I'm left with 1500 on a credit card and no way to afford other speakers so I sure hope its just the crossover.
post #28 of 126 Old 07-31-2013, 04:14 PM
MKtheater's Avatar
Quoted: 1588 Post(s)
Liked: 1116
Have you measured your response with the JTR's and with your current speakers?
Marantz 7702 Atmos
MKtheater is offline
post #29 of 126 Old 07-31-2013, 04:42 PM - Thread Starter
Quoted: 286 Post(s)
Liked: 55
Never measured a speaker... I don't do well with dig so measuring is a long shot
post #30 of 126 Old 07-31-2013, 04:44 PM
Erich H's Avatar
Quoted: 1406 Post(s)
Liked: 1768
You can always switch over to the Fusion-Pure with the compression driver using the mylar diaphragm.
The SEOS Waveguide Project
Erich H is offline
