Help picking amp - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 07-31-2013, 07:13 PM - Thread Starter
mikehenya's Avatar
I am going to try an 18" RE XXX in a sealed box, and will possibly add a second later. I already EQ my current subs with an Velo SMS-1. I am amp shopping right now and was considering the inuke 3000 or 6000. Both seem to have a decent following with the fan mod. My main question is should I go with the standard or DSP version?
Thanks for the help! Also looking to buy 1 or 2 18" heavy duty cabinets if anyone has something lying around.
Thanks for your time!
mikehenya is offline
post #2 of 14 Old 07-31-2013, 10:05 PM
LTD02's Avatar
Quoted: 2553 Post(s)
Liked: 2888
the 6000 is a pair of 3000's and is limited to about 2200 watts per channel at 4 ohms sustained.
the re xxx can eat up a lot of power, but if that is enough power for you, then the dsp version is a no-brainer as far as i'm concerned.
if you haven't already gone forward, you might take a look at the uxl 18 http://www.istonline.ca/mach5_uxl_18.html
measurements for both can be found at data-bass.com if you aren't already familiar with the site.
if going forward with the xxx sealed, shoot for a large cab, as that will really increase the low end sensitivity, which is the xxx's wheelhouse.
a 6 cubic footer will get you roughly 113db at 20hz 2pi space (in model), while a 12 cubic footer will get you roughly 116db at 20hz on 2200 watts power.
Listen. It's All Good.
LTD02 is online now
post #3 of 14 Old 08-01-2013, 05:27 AM
Martycool007's Avatar
Quoted: 280 Post(s)
Liked: 181
I would go with the iNuke 3000dsp and get rid of the SMS-1. Fewer cables to mess with since you won't be needing the SMS-1 plus you could sell the SMS-1 and recoup some of the cost of the iNuke3000dsp!
Martycool007 is offline
post #4 of 14 Old 08-01-2013, 06:12 AM - Thread Starter
mikehenya's Avatar
So, are you saying the iNuke6000 wouldn't be enough power for the RE? I was looking at 5-6 cubic foot for the cabinet anyhow, so I guess I will go with 6. I was going to add another RE when I came across another deal. I already got 1 XXX sub and got a great deal on it, but I am sure I could sell it and get a couple of UXL's.
post #5 of 14 Old 08-01-2013, 06:19 AM - Thread Starter
mikehenya's Avatar
Looking through data-base it seems they only tested the XXX in a 4.5 cubic foot cabinet, so how much difference would a 6cube box do? I see what you mean though, a couple of the uxl (which looks like it gets pretty close) would do better overall than 1 xxx (I did get it cheaper than the UXL however).
post #6 of 14 Old 08-01-2013, 07:49 AM
MemX's Avatar
Quoted: 55 Post(s)
Liked: 65
Have you modelled it in winISD? That will enable you to play with sizes and check output / excursion / power etc.
MemX is offline
post #7 of 14 Old 08-01-2013, 01:49 PM
Mrkazador's Avatar
Quoted: 264 Post(s)
Liked: 390
Here is a model of different sized enclosures, all with 2000w.
Looks like you gain about 1db at 20hz and 2db from <15hz going from 4.5 to 6cu ft
Mrkazador is offline
post #8 of 14 Old 08-02-2013, 11:54 AM - Thread Starter
mikehenya's Avatar
THANKS!! I appreciate the you taking the time to run and post that! I may even try an 8 cube box, I just read an interesting article about. I will have to try the software, I just haven't been that adventurous yet....still learning!
post #9 of 14 Old 08-03-2013, 12:34 AM - Thread Starter
mikehenya's Avatar
Alright, I think I am going to try the 18" in an almost 10cubic foot box with the inuke6000dsp.
Any last minute thoughts, complaints or criticism before I move forward? I appreciate the help so far~!
post #10 of 14 Old 08-04-2013, 04:57 PM
MemX's Avatar
Quoted: 55 Post(s)
Liked: 65
As long as your excursion isn't out of control, all should be fine smile.gif
MemX is offline
post #11 of 14 Old 08-04-2013, 05:48 PM
LTD02's Avatar
Liked: 2888
the inuke will give you about 2200 watts into 4 ohms per side.
in 10 cu ft, excursion is about 46mm, which is fine.
with electronics rolloff, it will be a little less.
LTD02 is online now
post #12 of 14 Old 08-04-2013, 08:50 PM - Thread Starter
mikehenya's Avatar
Well, not to cloud the water, but I know iNuke 6000 has inflated RMS figures, would it be enough to run 2 of the eventually or would a Crown XLS2500 Drivecore or something similar be a better choice?
Limit is $700 on the amp.....thanks again everyone!
post #13 of 14 Old 08-05-2013, 04:55 AM
MemX's Avatar
Quoted: 55 Post(s)
Liked: 65
iNuke6000 is from the peak 6000w figure, the 2x ~2200wRMS figure is pretty accurate, though, as I'm sure it's been measured.
They are great VFM and seem to be generally reliable, they just need a small fan mod for a few $ to quieten them down, I believe (and perhaps some EQ <10Hz because they start to roll off at 10Hz?)
MemX is offline
post #14 of 14 Old 08-05-2013, 06:27 AM - Thread Starter
mikehenya's Avatar
The Peavey IPR2 7500 seems to have some juice too decent juice in the same configuration (running 1 of 2 channels, at 4 ohm) and allows a second at near the same power as well.. Learning get's so frustrating, there is so much to read and so many opinions!
