SubMaximus -- A Large Front-Loaded Horn for UXL18 and Stereo Integrity HT 18" - Page 16 - AVS Forum | Home Theater Discussions And Reviews
 38Likes
Old 06-29-2014, 04:59 PM
Cortga's Avatar
Ideas for a tweak or anything you might change ? I am playing with the idea of a few horns for my build and I would like something monstrous. I am playing with the idea of using my second row riser- and my screen wall is also 3 feet. The room is going to be big (36 feet long by 25 feet wide) and I don't have WAF constraints and it's new construction starting soon so I can tweak the room and design around a great bass solution (if I can figure out a great bass solution). I am not afraid, but I am limited in budget. $1500 or so for drivers. I do not care about size, how much wood or how hard it would be to build it. Suggestions for me ?
http://hifiheroin.blogspot.com/searc...01:05:00-04:00
that just is a bunch of wood and time . He told me, when I was your shoe's, just build the biggest horn you can fit..... no regrets..
three little horns are much, much less bass than one big one.
Cortga is offline
Old 06-30-2014, 08:34 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2688
That is the idea that intrigues me. I want to build a really big horn that digs down that extra octave. I know it takes 4x as much space but I think I could pull it off. If I could not get that extra octave then I will probably abandon horn idea. I am not interested in doing something average.
Mfusick is offline
Old 06-30-2014, 09:09 AM
kevings's Avatar
Quoted: 295 Post(s)
Liked: 457
Talking
you are the kind of guy i like having as a neighbor! ( i love the lets over do it attitude )
kevings is offline
Old 06-30-2014, 09:11 AM
LastButNotLeast's Avatar
Quoted: 1549 Post(s)
Liked: 1154
Just not the neighbor next door!
kevings likes this.
Did you really need to quote that entire post in your reply?
Downloadable FREE demo discs: Demonstration Blu-Ray Discs (Independently Authored)
Welcome to AVS - Get out while you still can!
For most of the time, the here and now is neither now nor here. Graham Swift
LastButNotLeast is offline
Old 06-30-2014, 09:12 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2688
I'll overdo my soundproofing too
Mfusick is offline
Old 06-30-2014, 10:13 AM
asarose247's Avatar
Quoted: 731 Post(s)
Liked: 496
36 x 25 is 900 ft^2, what about the ceiling wrt to volume?
IDK but Max has a foot print of under 10 ft^2 , so unless you're going to seat 25 - 30 in that bodacious show piece of a HT,
as a percent of the overall budget,
build them.
from the cut sheets as posted, what's the price of 4 -5 sheets per sub? oak veneers or sander ply
for $1500 that's 3 UXL 18"s speakers, about 750- 800 plywood
AMPS?
and a mini DSP to rule them all
I'm intrigued
DIY FAN Denon X5200 , ATI A 2000 for 7.4.6 SCATMOS/DSU/SHARP 80" LED/LCD
L/R: Fusion 15 V2 , C: 88 Special , SL/SR: F4Q4LP , RL/RR: F-3, TF/TR: Volt 6's TM: SLX
SUBMAXIMUS, ,Submaximus V3,LOWARHORNCustom Dual Driver VBSS,2 x Inuke6000DSP
www.avsforum.com/forum/155-diy-speakers-subs/1485120-submaximus-large-front-loaded-horn
http://www.avsforum.com/forum/155-di...orn-build.html
asarose247 is online now
Old 06-30-2014, 10:41 AM
notnyt's Avatar
Quoted: 2349 Post(s)
Liked: 2145
And in that same space, you could build something that produces greater output that isn't a horn...
notnyt is offline
Old 06-30-2014, 11:22 AM
Fatshaft's Avatar
Quoted: 591 Post(s)
Liked: 904
If you are talking BASS then I doubt that UNLESS you build a BUNKER! Period!
Nothing will stop bass...it has NO RESPECT for soundproofing!
My Build Thread
Equipment Speakers:
3x 1099's for LCR duty
4x Fusion 8's for surround duty
8x subs: 4x FTW21's and 4x SI18's
Fatshaft is offline
Old 06-30-2014, 11:54 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2688
But could I afford it ?
Ported is my back up plan. I have plenty of space but lack of funds. $2000 is about my max for an initial bass solution but I'd Ike to be able to add and build on it over the years.
Mfusick is offline
Old 06-30-2014, 12:44 PM
kevings's Avatar
Quoted: 295 Post(s)
Liked: 457
Notnyt, can you elaborate on what you'd do here, within the budget specified? thx.
kevings is offline
Old 06-30-2014, 12:45 PM
notnyt's Avatar
Liked: 2145
Notnyt, can you elaborate?
Model a horn that can dig to 15hz, now model a bunch of ported enclosures in the same volume of space.
Scott Simonian likes this.
notnyt is offline
Old 06-30-2014, 04:05 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2688
http://www.data-bass.com/data?page=system&id=81
This looked pretty cool^
B&C 21" in a tapped horn
Mfusick is offline
Old 06-30-2014, 06:39 PM
kevings's Avatar
Quoted: 295 Post(s)
Liked: 457
kevings is offline
Old 06-30-2014, 06:49 PM
Liked: 1154
About which Dr. Geddes speaks at length:
http://gedlee.azurewebsites.net/Books/HomeTheater.aspx
Old 06-30-2014, 06:50 PM
Liked: 1154
But you want to get WAY lower than 27Hz!
Old 06-30-2014, 07:03 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2688
This is true. Ideally I'd like something that's huge so it can go low and loud. Pair it with a high value but high quality sub with lots of Xmax. Perhaps something like a submaximus but with a bigger cab.
Mfusick is offline
Old 07-01-2014, 01:50 AM
Thatsnasty's Avatar
Quoted: 51 Post(s)
Liked: 42
The Dayton Ultimax 18's go in stock in a week according to PE.
Looks promising as the other Ultimax subs were pretty good for the money, and the 18" seems to have a much stronger motor.
4 of those puts them at $266 each, put them in 4 Marty-style cabs 12cuft tuned ~17hz.
Or go a-la Notnyt, tune to 15 hz, and since you have space, make the cabs HUGE.
Sub Upgrade Build Dayton Audio UM18-22 18" x 2 LLT
Sorry to derail.
Mfusick likes this.
Thatsnasty is offline
Old 07-01-2014, 06:30 AM
Martycool007's Avatar
Quoted: 280 Post(s)
Liked: 177
I haven't been following this thread as closely as I was at the beginning, but can anyone tell me what the final driver choice was for this "Sub-Maximus"? What about the final design?
Martycool007 is offline
Old 07-01-2014, 10:22 AM
asarose247's Avatar
Quoted: 731 Post(s)
Liked: 496
Talking Submaximus Driver
the name of this thread mentions a driver or two,
I went with the UXL 18, it weighs about twice as much as the SI model, maybe that makes it "better"
Max does seem to provide respectable FR, ULF and SPL, if you can believe REW
The uxl's are to be available middle of the month
Old 07-01-2014, 04:51 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2688
I am trying to compare MAX to some of the builds here : http://www.data-bass.com/data?page=s...rt=desc&mfr=-1
Specifically the Ghorn. Did you ever take the same measurements so I could compare them ?
Mfusick is offline
Old 07-01-2014, 06:45 PM
asarose247's Avatar
Quoted: 731 Post(s)
Liked: 496
that's quite a read, and presents conditions and parameters and (expensive) equipment and jargon and, nevermind,
I've seen that before and wondered about how things might stack up
however
if the collective mind-meld here can concoct (a) protocol(s) that I can perform (HEY! Kids-try this at Home!) under controlled conditions to produce valid data,
then I'm all for it.
We have audiocheck for a good variety of input, sweeps, straight tones.
I'm sure that what I don't know enough about REW and what it can do for us holds creditable evidence of what just is or isn't really working wrt to design, expectations, ripple , response, spl, distortion, low end , etc and other performance parameters I hear people talk about but lack the background for a nuanced understanding of the real science.
WE are in the company of people who KNOW/LIVE/BREATH this stuff .
What MAX does now is PFG .
I'd like to revisit the HULK scene now that it is dialed in a touch better.
So, get me a test scenario that won't blow up the neighborhood or at least me,
if things prove to be that good, I'd be in for another . . .
Old 07-01-2014, 06:53 PM
asarose247's Avatar
Quoted: 731 Post(s)
Liked: 496
addendum:
IF you can put a team together that would be able to perform all the testing in that link I'd be glad to drive 100 miles , any direction from OC, just to see it all.
or send them to garden grove (for some of it)
THAT would be awesome!
Old 07-01-2014, 07:10 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2688
LTD02 (or anyone) can I ask a few questions about this design ?
First I plugged in some of the figures (I have slightly different driver specs I think loaded)
I have a lot of question but the first I have is how exactly and why exactly did you choose the values you did ?
Specifically why 320 for S2 or 1040 for S3 ? 2259 for S4 seems rather odd number to arrive at so it must have been intentional yes? What was the reason ? I would like to understand more about how this is designed.
Second, If I wanted to make the cabinet bigger and the length longer could I achieve a lower tune ? If I wanted to increase the bottom to a slightly lower tune what would I change ? I am still nooby and learning Hornresp so any advice, guidance and wisdom is appreciated.
Mfusick is offline
Old 07-20-2014, 04:46 AM
Whatever1's Avatar
Quoted: 27 Post(s)
How does this compare to a THT other than reading the specs.
250 Watts seems to be enough for the THT while 2200 watts is talked about with this sub.
Aren't they both horn loaded ?
Thank You
Whatever1 is offline
Old 07-20-2014, 06:03 AM
chrapladm's Avatar
Quoted: 865 Post(s)
Liked: 303
This horn will get a LOT louder than a THT.
chrapladm is online now
Old 07-20-2014, 02:27 PM
audiovideoholic's Avatar
Quoted: 645 Post(s)
Liked: 210
Horns are great but my overall understanding is that one would be wasting space and time if the goal is high spl and a tune under 15-20hz. The goals can be reached by other means when trying to chase the ULF range. A room as big as yours will need lots of displacement in general for high spls and if you want that super low ULF content compromises will need to be made according to your goals.
Mfusick likes this.
audiovideoholic is offline
Old 07-23-2014, 06:07 PM
Whatever1's Avatar
Quoted: 27 Post(s)
So withthe same size amp as a tht this will play as loud ?
Old 07-23-2014, 06:32 PM - Thread Starter
LTD02's Avatar
Quoted: 2366 Post(s)
Liked: 2613
"I have a lot of question but the first I have is how exactly and why exactly did you choose the values you did ?
Specifically why 320 for S2 or 1040 for S3 ? 2259 for S4 seems rather odd number to arrive at so it must have been intentional yes? What was the reason ? I would like to understand more about how this is designed."
I created an exponential horn flare in excel. Then, I approximated that flare with straight sections within the confines of the actual enclosure.
So for example, I'd say, if the horn were exponential flare and there is some distance to the first corner inside the enclosure how much area should be at that corner. and so on. so even though each section is technically best modeled by PAR sections, overall it is an exponential horn.
Listen. It's All Good.
LTD02 is offline
Old 07-23-2014, 06:37 PM - Thread Starter
LTD02's Avatar
Liked: 2613
"Second, If I wanted to make the cabinet bigger and the length longer could I achieve a lower tune ? If I wanted to increase the bottom to a slightly lower tune what would I change ? I am still nooby and learning Hornresp so any advice, guidance and wisdom is appreciated."
in theory, but even this one seems a little too long given the size of the mouth (which of course dictates the overall size of the horn).
if the mouth is too small relative to the length, then the bottom end of the horn won't get ideal loading. this is why I kept focusing on that aspect.
the more that I look at the numbers, the less enthusiastic I am about front loaded horns with low corners under about 25hz or so. there just isn't much benefit relative to a ported enclosure in the region where driver excursion limits output. I actually wrote up a short analysis of this point, just haven't posted it yet. :-(
LTD02 is offline
Old 07-23-2014, 06:46 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2688
I'd like to read it when you get a chance. How does a Ghorn differ?
Mfusick is offline
