SubMaximus -- A Large Front-Loaded Horn for UXL18 and Stereo Integrity HT 18" - Page 17 - AVS Forum | Home Theater Discussions And Reviews
 38Likes
post #481 of 555 Old 07-23-2014, 07:47 PM - Thread Starter
LTD02's Avatar
Quoted: 2456 Post(s)
Liked: 2779
posted.
Listen. It's All Good.
LTD02 is offline
post #482 of 555 Old 07-31-2014, 05:00 PM - Thread Starter
LTD02's Avatar
Liked: 2779
post mortem
a couple of things have had me concerned about how close the actual measurements were to the model.
first, there seemed to be a little more 'chop' in the frequency response than in the model.
second, there seemed to be more "ripples" under 100hz than the model predicted.
third, and of primary concern was the larger drop at the last leg of about 8db or so where the model forecast about 6db or so.
fourth, the low corner seemed lower than the low corner in the model. the target low corner was around 14-15hz and actual ended up around 10hz or so (which is getting into likely signal chain rolloff).
so with all that considered, and after reviewing the layout again, I think what has happened is that with three 180 degree turns, the effective path length has been extended by about 50% relative to the model. this is good news and bad news. it means that with three 180 degree turns, a horn can be shortened by about 33%, which in this case would provide a good deal of space savings. that however is just a theory for the moment.
in order to test the 50% "effective increase in length" hypothesis, I went back to the original hornresp model and increased each leg by 50%. the picture below shows the original target in red and the 50% longer horn in black. the 50% longer horn in black exhibits all four characteristics that were noted above.
as everybody who followed along knows, the construction was a masterpiece, so I don't think any concerns rest there.
the design just missed the mark by coming in with a lower effective tuning than plan.
original hornresp model (red), 50% increase in path lengths (black):
actual measurement with low pass filter in place:
edit: updated initial 25% number to 50%.
Name:	submaximus actual vs model.png
ID:	190562   Click image for larger version
Name:	actual with low pass submaximus.png
ID:	190610   Click image for larger version
Name:	target vs model with 50 percent increase in path lengths.png
notnyt likes this.
LTD02 is offline
post #483 of 555 Old 07-31-2014, 05:27 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2693
So design up another... and I'll build it and test it. How's that ? But make it even more awesome so I can wreck my house with a few of them. The only issue I have is one dimension needs to be like 30" to fit behind screen wall. A few more inches probably ok. But the other dimensions can basically be about as big as you want. If you walk me through folding process that would be super cool.
This idea and subwoofer is just too awesome to let it die. It needs a version 2.0
Mfusick is offline
post #484 of 555 Old 07-31-2014, 06:06 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2693
SUBMAXIMUS V2.0: "home wrecker"
What drivers would work in this monster? Anything other than UXL18 ? (that driver is fine with me btw)
also, what low pass filter was in place? It doesn't look so strong...
Mfusick is offline
post #485 of 555 Old 07-31-2014, 08:23 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2693
Originally Posted by maxmercy View Post
The model is wrong. Make all the hornresp segments PAR in the model (according to post 1, the segments are EXP) and you will see the results meet the model much more closely w/ regards to the ripple amount. I didn't notice this until after I looked at it when I entered the model into hornresp myself a few days ago. If you will build a re ?horn with a rectangular cross-section, always use PAR.
The lower corner is because of horn length/x-section areas not accounted for in the corners by hornresp.
JSS
Can you explain this more?
Mfusick is offline
post #486 of 555 Old 10-29-2014, 08:22 AM
justinjames's Avatar
That is the idea that intrigues me. I want to build a really big horn that digs down that extra octave. I know it takes 4x as much space but I think I could pull it off. If I could not get that extra octave then I will probably abandon horn idea. I am not interested in doing something average.
I've been following this build for a long time now, and its pretty amazing. I would really like to thank LTD02 for all his time and willingness to share his expertise.
justinjames is offline
post #487 of 555 Old 10-29-2014, 08:38 AM - Thread Starter
LTD02's Avatar
Liked: 2779
asarose did the tough part.
there has been some more thinking about this in the background, but I don't want steal any thunder (so to speak).
"Can you explain this more?"
par is the expansion rate of a horn that uses straight sides such as most of these folded horns.
however, by sectioning the horn into smaller sections each with an expansion rate that increases with the length, the overall result is no longer par, but can be closer to con (conical) or even exp (exponential).
while it is true that each section should have "par" as the flare rate, since the overall horn follows generally an "exp" expansion, it doesn't really matter if each section is modeled as par or exp.
if it is still confusing what is going on here, imagine a curved line. now try to approximate that curved line with a single straight line. you can't. however with 3 straight lines, you can get close. with 5 you can get really close and so on. so even if you are using straight lines, section by section, the overall smooth curve "exp" can be well approximated. just because each section uses a straight line, doesn't mean the entire horn flare is expanding as a straight line.
this post shows the neglible effect of switching the sections to "par" from "exp" because the overall horn was designed to be "exp".
LTD02 is offline
post #488 of 555 Old 10-29-2014, 10:08 AM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 233
This really is a great design John! It is one of my favorites for sure.
Kudos once again!
kingpin111 likes this.
Joe = LFE Addict
Joe's LOWARHORN build
jpmst3 is offline
post #489 of 555 Old 10-29-2014, 10:24 AM
kingpin111's Avatar
Quoted: 290 Post(s)
Liked: 283
I'd rather have a couple of these on the side walls being as they are only a couple feet wide then a ported box that jets to far out into the room.
Building vertically doesn't take up much real estate.
Can a FTW21 be used also?
I guess that would totally change the design though.
kingpin111 is offline
post #490 of 555 Old 11-04-2014, 07:23 PM
asarose247's Avatar
Quoted: 804 Post(s)
Liked: 606
I discontinued my test in as much as things are definitely
working and it was hotter than he&& for july and august
BUT! loading vertically can help wrt to the large footprint
on the dolly vertically , the horn would be abput 35-36 inches from the 8 foot ceiling, under 1 meter
since it weighs about 350 making height adjustments could be tricky , , ,
BUT I can get the help to try at least that and the distance wrt to loading adjacent to the wall could provide other data i.e. tight to the wall, 6 inches from the wall, etc.
one measurement John had me try back in the day was in the back of the room directly into a the rear corner, with the horn at 6inches, and 1/2 and then 1 meter and the REW mike about 14 feet away at the MLP, after the near field measurements
the denon 4000 seems to make love to me in the bass department, though the 2 BF subs in an 8 ohm series/parallel combo and being 14 feet apart make any statement regarding "best bass EQ ever" seem sketchy, but
there's plenty of it, no localization
and gaming with the Xbox1 and the sound and especially bass potential there, it does get your attention
Any constructive and or feasible suggestions will be considered
after all there is NO! WAF and we all might just learn something . . .
and every now and then I hear a quiet whisper,
"MAX is lonely, build another one . . ."
DIY FAN Denon X5200 , ATI A 2000 for 7.4.6 SCATMOS/DSU/SHARP 80" LED/LCD
L/R: Fusion 15 V2 , C: 88 Special , SL/SR: 88 Special(V2) , RL/RR: F-3, TF/TR: Volt 6's TM: SLX, FH: F4Q4
SUBMAXIMUS, ,Submaximus V3,LOWARHORNCustom Dual Driver VBSS,2 x Inuke6000DSP
www.avsforum.com/forum/155-diy-speakers-subs/1485120-submaximus-large-front-loaded-horn
http://www.avsforum.com/forum/155-di...orn-build.html
asarose247 is offline
post #491 of 555 Old 02-22-2015, 06:36 PM
mfagains's Avatar
Liked: 26
@LTD02
Would you be so kind as to double check this model for accuracy? http://www.usspeaker.com/rcf%20-%20LF18X451-1.htm
Looks like it's close to the UXL18 by a few DB and smoother than the SI H18.....
Thank you for your time and consideration.
ID:	562185   Click image for larger version
mfagains is offline
post #492 of 555 Old 02-23-2015, 06:46 AM
vitod's Avatar
Quoted: 270 Post(s)
Liked: 144
Man, if this would be a flat pack, I'd jump on this!
Panasonic AE-8000, Carada BW 120", Paradigm Studio 40v3 x 2, Paradigm 690v4, Paradigm ADP 470v3 (rears), Micca M-8C x 4, Volt 6 x 2 (SR), SI DS4-18 in 12cuft X 2, Marantz 7702MKII, OPPO 103D, Emotiva XPA-3,
vitod is offline
post #493 of 555 Old 02-23-2015, 06:51 AM
klipsch's Avatar
Quoted: 189 Post(s)
Liked: 98
Find a local wood shop with a CNC and make it happen based off of the sketchup files made ... shipping would be astronomical if this was a flat pack
klipsch is offline
post #494 of 555 Old 02-23-2015, 07:16 AM
vitod's Avatar
Quoted: 270 Post(s)
Liked: 144
True, but maybe ship it in 3-4 shipments. It will cost more, but they'll be at my door.
vitod is offline
post #495 of 555 Old 02-23-2015, 07:38 AM
klipsch's Avatar
Quoted: 189 Post(s)
Liked: 98
guess it all depends on what your version of "more" is ... Get a quote on a ~4'10" x 4' board being shipped ... that was the original size of the 2 side panels required that I mocked up in sketchup
klipsch is offline
post #496 of 555 Old 02-25-2015, 02:14 PM
bryan.lynch's Avatar
Subscribed
bryan.lynch is offline
post #497 of 555 Old 02-25-2015, 09:17 PM
Woodfiend's Avatar
Originally Posted by jpmst3 View Post
Did anyone happen to model this with the LMS to see how it compares to Ricci's GHorn?
Or the UM18?
I am curious too....
Woodfiend is offline
post #498 of 555 Old 02-25-2015, 09:53 PM
Quoted: 93 Post(s)
Liked: 48
post mortem
Am I missing something? It appears John is not happy with design. Then there is talk about flat packs. I must be confused.
Doradoguy is offline
post #499 of 555 Old 02-25-2015, 10:45 PM
asarose247's Avatar
Quoted: 804 Post(s)
Liked: 606
at around 5 sheets, a flat pack must be tongue-in-cheek, that's already about 300 lbs,
If I thought I could afford to have someone ship me something like that so I could AIY, oh h3ll no.
that's a problem that goes away by writing a check ,
and if I could afford that, my custom designed/engineered and built HT isn't going to be full of gigantic boxes
even your local Cineplex doesn't look like that
But if you want to visit garden grove for a week or 2 and bring a truck and other requisite goodies ($) and don't mind a little focused effort
there's no limit
post #500 of 555 Old 02-26-2015, 05:34 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2693
People that build folded horns don't need flat packs.
If you need a flat pack build a sealed or ported beginner box.
tsloms likes this.
Mfusick is offline
post #501 of 555 Old 02-26-2015, 07:23 AM
vitod's Avatar
Quoted: 270 Post(s)
Liked: 144
Anything is possible. Erich offered a flat pack horn. Sure, it was small...I have two of them, but not impossible. It doesn't have to be this design. It'll be big, but more manageable. Erich asked if we have something in mind, so why not throw him a line about a larger horn? And made mostly of plywood to keep weight down? If a larger flat pack horn can be made with great output, I'm sure it'll be a hit. Most of us are not woodworkers and/or don't have the time to make such a thing. Sure, we can find a wood shop and be lucky enough to have a CNC, but what are the odds of having that AND near by? But, if something like this would emerge, I'd be first in line.
vitod is offline
post #502 of 555 Old 02-26-2015, 08:20 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2693
Well if erich was going to offer a kit I think it would make sense to offer something like the lilwrecker, or a dual alpine 12" like a DTS10. Josh Ricci is an engineer or something to that effect, so his designs probably could translate into a CNC cut easily enough- and those also kick ass. I think the kit is more dependent on the designer, and his willingness to allow it. Past that it logistics of getting the wood cut, storing it, shipping it. It's a big job when you start talking about large horns, the size to store it, weight to move it, cost to cut it, and cost to ship it goes through the roof. And building and assembly is more involved, bracing is more important. It's not a beginner job.
The task of doing flat packs for horns seems like pain to me. I would not want do it for free, and I assume normal people would be the same way.
That is probably why we don't see them.
Oh.. and the patent thing.
Mfusick is offline
post #503 of 555 Old 02-27-2015, 06:31 AM
klipsch's Avatar
Quoted: 189 Post(s)
Liked: 98
Ironically Erich stopped the Anarchy horn design because he was losing money on the shipping...and that is a very very small horn for a 6.5" driver
The DTS-10 were kits from Danley. How much was shipping and such for those? I would imagine the work for Erich to do for a horn that had a 10" driver would be extremely difficult.
I personally just had 3 sealed subs created at a local CNC. I made the designs myself in sketchup and had those components cut via the CNC. I can do the work with a router and table saw, but instead of taking several days of measuring, cutting, gluing, sanding, dry fitting, etc., I spent about 4 hours total to go to a lumber yard, put the 6 sheets of plywood on a machine and watch it cut the sheets. I then had the 3 boxes assembled back at my house that same day.
Where there is a will, there is a way ... that is all part of the DIY spirit in my opinion.
LTD02 and asarose247 like this.
klipsch is offline
post #504 of 555 Old 03-25-2015, 08:52 PM
Clarence's Avatar
Quoted: 298 Post(s)
Liked: 11556
Very interesting. I did some googling and found a CNC shop near me. They even list speaker cabinets in a list of products that they cut. Plywood and MDF (and dozens of other materials)... provide your own or they can source it. Up to 60" x 144". Sweet.
I'll call them tomorrow and get a quote... just to see if it's feasible (e.g., $100 not $1000).
Can you share how much they charged to cut 6 sheets?
Did you export from sketchup or just give the SKP file to the CNC shop and they did all the file conversions?
Clarence is offline
post #505 of 555 Old 03-25-2015, 09:28 PM
popalock's Avatar
Quoted: 1242 Post(s)
Liked: 1736
You are in NoVa? Where is this shop that you speak of???
popalock is offline
post #506 of 555 Old 03-26-2015, 08:55 AM
JohnDean's Avatar
Quoted: 458 Post(s)
Liked: 196
DXF or DWG has been the preferred file type from my experience with CNC. However they can probably convert most types to whatever format their machine requires.
JohnDean is offline
post #507 of 555 Old 03-27-2015, 09:12 AM
MDST's Avatar
Quoted: 32 Post(s)
John, this awesome design serves for Alpine 1522D??
MDST is offline
post #508 of 555 Old 03-27-2015, 09:42 AM
asarose247's Avatar
Quoted: 804 Post(s)
Liked: 606
^ there is no mention of this in 18" size and is recommended in vented or sealed config
buy it may be an interesting unit for modeling something "new"
post #509 of 555 Old 03-28-2015, 07:31 AM
klipsch's Avatar
Quoted: 189 Post(s)
Liked: 98
The "they" is a fellow AVS member. I won't post prices in case he charged me more or less than others. He took the components in the sketchup files and translated then from 3d to 2.5d g code. I had two boxes that were DO designs and one box dual front firing design. DO design worked out great. Front firing needed a little work. All in all, a very good experience. When the bass itch strikes again, I'll prolly ask him if he'll do some more of the DO design for behind the screen
klipsch is offline
post #510 of 555 Old 03-28-2015, 07:32 AM
klipsch's Avatar
Quoted: 189 Post(s)
Liked: 98
I'm 30 miles from the ape man... In PA
klipsch is offline
