SubMaximus -- A Large Front-Loaded Horn for UXL18 and Stereo Integrity HT 18" - Page 19 - AVS Forum | Home Theater Discussions And Reviews
 38Likes
post #541 of 555 Old 03-25-2017, 08:34 PM
Fattykidd's Avatar
Quoted: 561 Post(s)
Liked: 580
The DS115 seems to need less voltage to hit Xmax and looks better spl wise. They are within 1-2db's of each other SPL wise. If I was building these horns I would buy the 21DS115's. I already own some 152's so I would also build with those first.
Comparing the UXL(BL adjusted) to the DS115 the 21's looks better and has 3db more SPL at the knee.
Hey... Here's a curveball.. What does the Mach 5 Ftw21 look like ?
Fattykidd is offline
post #542 of 555 Old 03-25-2017, 08:42 PM
asarose247's Avatar
Quoted: 838 Post(s)
Liked: 644
I'm going with : PLEASE! and THANK YOU!
of course the curious possibility thinkerf asks, : just exactly what nuance could possibly be hidden . . .
Inquiring minds and itchy hands want to know . . .
because : subwoofer . .
this has nothing to do with the more complicated "size issues" the guy with the giant roaring truck has . . .
Fattykidd likes this.
DIY FAN Denon X5200 , ATI A 2000 for 7.4.6 SCATMOS/DSU Sammy 82" 4K/HDR
L/R: Fusion 15 V2 , C: 88 Special , SL/SR: 88 Special(V2) , RL/RR: F-3, TF/TR: Volt 6's TM: SLX, FH: F4Q4
SUBMAXIMUS, ,Submaximus V3,LOWARHORNCustom Dual Driver VBSS,2 x 6000DSP
www.avsforum.com/forum/155-diy-speakers-subs/1485120-submaximus-large-front-loaded-horn
http://www.avsforum.com/forum/155-di...orn-build.html
asarose247 is online now
post #543 of 555 Old 03-25-2017, 08:48 PM
asarose247's Avatar
Quoted: 838 Post(s)
Liked: 644
this chart from the BC site for the DS115,
why does this look not so promising?
no one need answer, really
post #544 of 555 Old 03-25-2017, 09:40 PM
chrapladm's Avatar
Quoted: 944 Post(s)
Liked: 351
21FTW doesnt look that good after adjusting BL. AND I dont have a Le measurement for it either. I thought Ricci had T/S on the FTW but couldnt find it. Best value driver is the 21DS115. But even the 18TBW100 looks good in this with a max of 400watts. So easy amp power for about 120db@20hz and up. AND depending on your budget the Funk Audio 18TSAD 4 ohm looks good in this also.
I like the TSAD pro audio-like specs so I am a fan. I think they are about the same price as the UXL. BUT they are available. Just depends on your budget.
chrapladm is offline
post #545 of 555 Old 03-25-2017, 10:10 PM
Fattykidd's Avatar
Quoted: 561 Post(s)
Liked: 580
Thanks man.. Was just a crazy idea that popped into my head..LOL..The funk/focusworks drivers are unavailable from harbottle at this time as well... But I remember the tsad being a couple hundred more than the Uxl.
post #546 of 555 Old 03-25-2017, 10:14 PM
chrapladm's Avatar
Quoted: 944 Post(s)
Liked: 351
No problem. I didnt know they werent available. Thanks for the heads up. I tend to use pro audio drivers myself. They are much cheaper for me.
post #547 of 555 Old 03-25-2017, 10:19 PM
Fattykidd's Avatar
Quoted: 561 Post(s)
Liked: 580
The 21ds115 is about 725bux here in Canada.
And I was just checking the harbottle site that's how I know.. It says the product line is getting an update.
post #548 of 555 Old 03-25-2017, 10:24 PM
chrapladm's Avatar
Quoted: 944 Post(s)
Liked: 351
Ah I see. Hopefully they have a little bit more Bl on the next batch. But the 21DS115 is about 550 for me and the SW152 is about 700. My 15HST that I am probably going to sell now was about 800 for comparison. Thats mainly because the shipping pricing and that was old prices also. Would be about 1000 for another 15 now.
All these great horn designs make me want to build a TH812 or similar for fun.
post #549 of 555 Old 03-28-2017, 12:58 PM
Funk Audio's Avatar
Quoted: 106 Post(s)
Liked: 186
They are currently available, the website is just being redone right now, to accommodate more information and more products. Feel free to contact them to order anything.
chrapladm likes this.
Nathan Funk
Funk Audio
Funk Audio is offline
post #550 of 555 Old 03-28-2017, 01:27 PM
Fattykidd's Avatar
Quoted: 561 Post(s)
Liked: 580
Thank you for the clarification.
post #551 of 555 Old 03-28-2017, 01:40 PM
LastButNotLeast's Avatar
Quoted: 1804 Post(s)
Liked: 1416
The technical details on Amazon are a hoot:
https://www.amazon.com/21DS115-Speak.../dp/B01DVUPLIG
Michael
Did you really need to quote that entire post in your reply?
Downloadable FREE demo discs: Demonstration Blu-Ray Discs (Independently Authored)
Welcome to AVS - Get out while you still can!
Don't guess, measure: Getting Started With REW: A Step-by-Step Guide
LastButNotLeast is offline
post #552 of 555 Old 03-28-2017, 03:47 PM
asarose247's Avatar
Quoted: 838 Post(s)
Liked: 644
you made me look . . .,copy and paste . .
Technical Details
Item Weight 1 pounds
Product Dimensions 7 x 10 x 8 inches
Item model number 21DS115
Depth (inches) 2 inches
post #553 of 555 Old 03-28-2017, 04:11 PM
asarose247's Avatar
Quoted: 838 Post(s)
Liked: 644
A good question. . .
Is using an approved 21 in stead of an 18 , demonstrable
or is it somewhat listening with the eyes?
post #554 of 555 Old 03-28-2017, 04:19 PM
chrapladm's Avatar
Quoted: 944 Post(s)
Liked: 351
Pro audio verse HT subs tend to need less voltage to hit the same SPL. They have lower distortion for the same SPL generally also. Just use whats available in a 18" or 21. Either will work fine. I remember when I had my THT(FLH) with a 15" with 12mm Xmax I believe and that was awesome. I just wanted more extension so I went with something else.
For me I go with the best value lowest distortion driver I can find. Being in Australia it tends to be pro audio because of shipping costs. Nothing wrong with using a UXL or TSAD or on a budget 18TBW100 as I suggested earlier. If you need the SPL then the bigger UXL/TSAD and 21's make more sense. No need to keep up with the Jones's. Buy what works for your budget and needs.
post #555 of 555 Old 03-28-2017, 05:11 PM
asarose247's Avatar
Quoted: 838 Post(s)
Liked: 644
Thank you
FTR I still have 3 THTLP's with the 15". They are beastly
2 of them in the man cave (<110 ft^2), a 24" and a 30" on BASH 300's pressurizes and rattles stuff in other parts of the house.
very intense for almost everything just not so many of the "demo"(lition) clips
