Help with broken connector - AVS Forum | Home Theater Discussions And Reviews
Old 08-08-2013, 02:48 PM - Thread Starter
Hazarrd's Avatar
I was hoping someone could take a look at this picture and give me some advice on how I can fix it. The red and white connector pieces came off of two of the inputs when I pulled out some cables.
Would greatly appreciate any advice.
Hazarrd is offline
Old 08-08-2013, 03:05 PM
pauleyc's Avatar
Liked: 24
Why not just use XLR to RCA connectors and use the XLR input?
That screw in the middle will release that connector from the chassis. Check MCM or some other parts supply and see if you can find a replacment and solder it in. Pretty standard connector.
Edit: Would this work? http://www.amazon.com/Audio-Female-Socket-Solder-Connector/dp/B008I1HK0G/ref=sr_1_2?ie=UTF8&qid=1375995968&sr=8-2&keywords=rca+panel+mount
pauleyc is online now
Old 08-08-2013, 03:06 PM - Thread Starter
Hazarrd's Avatar
I'm trying to sell the unit (it's a Numark NS7) and would prefer to say it's in perfect working order.
Hazarrd is offline
Old 08-09-2013, 05:37 AM
tsloms's Avatar
Quoted: 54 Post(s)
Liked: 59
Can't you just push the pieces back into the unit? I've had that happen on an old TV when I had some very tight RCA cables and I just pushed the pieces right back in. Maybe use a little super glue to ensure that it stays in?
tsloms is offline
