Zaph ZA5 Center Channel Build - AVS Forum | Home Theater Discussions And Reviews
Old 08-09-2013, 11:36 AM - Thread Starter
reggydavis's Avatar
First try at a build with a table saw. It's in progress...all photos by iPhone 5. I messed up on one of the internal braces, supposed to centered a little more but nothing huge. The crossover was confusing because it was too big or something. In the pics I had to cut off a corner. Sanding is next! Not sure if I want to paint or veneer. I plan on using the ZA5 for a 7.1 surround sound with a 15 or 18 inch sub.
reggydavis is offline
Old 08-09-2013, 11:51 AM
fish323's Avatar
Quoted: 18 Post(s)
Looking really good (with my limited DIY experience smile.gif). I've been considering using the Zaph center & the ZA5.5 towers for my HT. I'd love to read your impressions once completed.
fish323 is offline
Old 08-09-2013, 05:34 PM
kgveteran's Avatar
Quoted: 363 Post(s)
Liked: 130
Nice build. Great attention to details. What will you be powering those with ?
As of Jan 2017, im still looking for (1) Outlaw M-200 mono amp, and a used Marantz 7010
kgveteran is offline
Old 08-09-2013, 09:19 PM - Thread Starter
reggydavis's Avatar
Good question haha...I'm currently trying to find a good solution. I believe the center channel will be my only 4 ohm speaker. I'm trying to find other owner solutions.
Old 08-10-2013, 08:07 AM
Martycool007's Avatar
Quoted: 280 Post(s)
Liked: 176
Do you already have the Zaphaudio mains?
Martycool007 is offline
Old 08-10-2013, 08:09 AM - Thread Starter
reggydavis's Avatar
Old 08-10-2013, 10:51 AM
kgveteran's Avatar
Quoted: 363 Post(s)
Liked: 130
So, eventually there will be a whole set of these speakers. I bet a nice Denon or Onkyo receiver will power them fine. Better yet, get a receiver with pre outs, so later an amplifier upgrade will be easy...... Receiver as a Prepro is the best money spent.....
Old 08-11-2013, 10:46 AM - Thread Starter
reggydavis's Avatar
That's what I'm thinking about doing, but these speakers cost more than planned so we'll see...
Here's some more progress!
Old 08-11-2013, 11:32 AM
Socketman's Avatar
Quoted: 127 Post(s)
Liked: 148
It is amazing how the cost's add up. DIY is not always less expensive, but it is fun and for me there is a huge amount of pride and satisfaction involved. Brand name speakers are actually a huge bargain when you realize what goes into their design and production. Have you decided on a finish for the outside of the speaker ?
When I built my first set of speakers I searched around for a decent vinyl to cover them in but the only thing I could find that was of decent quality was the 3M Di NOC which is about the same price as wood veneer so I went with the wood veneer. Its been a year with no signs of it lifting which is good since I had no idea what I was doing. biggrin.gif
On my first project I used PSA and it worked really good but its tricky to do on my own . On the second set I used paper backed veneer and contact cement applied with a foam brush and it worked really good .
Socketman is online now
Old 08-13-2013, 06:50 AM - Thread Starter
reggydavis's Avatar
Ok so I'm thinking about going with a matte black or black gloss finish. Veneer looks awesome and classy but eventually I'm going to want to paint the walls black for a home theatre. That being said, I'm pretty sure the technique to get a good finish is something like filler - sand - prime - sand - paint - sand - paint....with each sanding step using finer and finer grit paper. I have no idea what type of primer or paint to use other than the primer being oil based. I bought some rustoleum lacquer and some primer last night to test out before I apply. Keep in mind I'm not going to spend out the wazoo for some automotive paint, just wanna get the best for some spray can local.
Any paint type/brand suggestions?? smile.gif
Old 08-13-2013, 07:33 AM
JWagstaff's Avatar
Quoted: 28 Post(s)
Liked: 71
if you're doing black gloss you need to put a lot more filler on and sand it perfectly flat, or you will see all the lines.
JWagstaff is offline
Old 08-13-2013, 07:44 AM - Thread Starter
reggydavis's Avatar
Agreed!...I'm leaning towards matte though. It's more in line with my thinking of making these speakers a transparent part of the home theatre experience. Don't want something shiny below the screen! Although gloss does look super cool B)
http://www.ohio.edu/people/schneidw/audio/zaph_zdt_35.html
^^I'm looking to do something along the lines of the painting section in the link above. I know that requires buying a compressor sprayer, which I literally just said I don't want to shell out for smile.gif, but the results look so fantastic. I have a compressor btw so I won't be buying that too haha
