Fi IB3-18 x 8 and SEOS pure 10 kits! - Page 10 - AVS Forum | Home Theater Discussions And Reviews
 18Likes
post #271 of 1115 Old 10-10-2013, 03:50 PM - Thread Starter
MKtheater's Avatar
Quoted: 1592 Post(s)
Liked: 1122
Yeah, I won't have two rows of 4, I will have 4 rows of 2, top and bottom like JapanDave's except on the sides of the mains and in between.
Marantz 7702 Atmos
MKtheater is online now
post #272 of 1115 Old 10-10-2013, 07:07 PM
N8DOGG's Avatar
Quoted: 967 Post(s)
Liked: 1041
Originally Posted by desertdome View Post
Why did you switch to an array? I have manifolds with two sets of dual opposed subs in each manifold. The manifolds are completely inert. When we had the Omaha Home Theater Tour last year I had all my furniture plus about 25 people in the room. That is over 2 tons on the floor! My floor easily flexed during the demos - especially during Flight of the Phoenix. This is just from the pressure of the back wave/front wave without any driver force. I can't imagine now adding driver force to the baffle wall in addition to the sound waves generated by 8 18" drivers.
I guess Brian Owens did okay with his build: New (8) 18" Fi IB3 IB build
As awesome as that looks, the wall is no where near built enough to withstand the forces of those drivers. Heck, I had 4 IXL is a wall 3" thick braced 10 times that and it still was pulling the screws through the 2 x 6's. That wall must flex pretty good but it sire it a sight to see lol
N8DOGG is offline
post #273 of 1115 Old 10-10-2013, 07:19 PM
LTD02's Avatar
Quoted: 2341 Post(s)
Liked: 2578
"Bizarre formatting going on, tried to edit, to no avail
fixed it, weird ..."
just a glitch in the matrix. :-)
foh, by lack of coupling all I was referring to was the lack of coupling from one motor to another. in a smallish sealed enclosure, if you have two drivers and push one in, the other moves out, because the air pressure between them couples them together. in a theoretical infinite baffle if you push one driver in, nothing happens to the second driver, so they are not coupled together, at least not in the same sense. even in manifold where one driver is sitting right in front of the other, i'm not sure that there is any coupling for that reason, or at least it is not quite the same.
Listen. It's All Good.
LTD02 is offline
post #274 of 1115 Old 10-10-2013, 08:15 PM - Thread Starter
MKtheater's Avatar
Liked: 1122
Yeah that wall looks like it will flex. My drivers will be in 1.5 inch ply and 4x8 worth of studs.
Marantz 7702 Atmos
post #275 of 1115 Old 10-11-2013, 08:46 AM
Lonely Raven's Avatar
Quoted: 29 Post(s)
Liked: 32
I would totally do an array like that myself...but the neighbors might not like the looks of speakers hanging on the *outside* of the house. tongue.gif
Lonely Raven is offline
post #276 of 1115 Old 10-11-2013, 11:11 AM
FOH
FOH's Avatar
Quoted: 38 Post(s)
Liked: 234
push-pull reduces even order distortion non-linearities in the motor/suspension, but it is unclear how much coupling there would be in an infinite baffle because the whole point of an infinite baffle is the lack of coupling.
Originally Posted by FOH View Post
There's been several push pull IBs I've seen, I didn't employ mine that way because of simple mounting logistics.
Lack of coupling, ..? What are you referring to?
Ok, I'm merely focusing on the acoustic energy into the room. Are you saying (something I'd not considered frankly) the benefits from push-pull are lessened by minimal rear coupling?
Parham; "It works best at low frequencies with drivers physically close together, especially when operated in a common chamber. The further apart they are, the less coupling is provided."
The the acoustic nulling is most effective when their outputs, front and rear, are in lockstep? I'd suggest the wavelengths of interest are so long that it precludes any concern.
It could be said a manifold IB, is akin to the acoustic inverse of the small box sub in a room. One side's acoustic output is more closely coupled than the other.
That said, I'd think an IB would still enjoy the benefits, but maybe more in the aero asymmetry nulling, as opposed to the heat and magnetic flux modulation linearization. IBs already enjoy a distinct advantage possessing inherently lower motor currents, lessening their need for such Push-Pull benefits.
But, like most all things, proof is in the testing.
Active 16.8kw, 7.3 system
(2)Seaton SubM-HP, (4)18" IB
FOH is offline
post #277 of 1115 Old 10-11-2013, 11:18 AM
FOH
FOH's Avatar
Quoted: 38 Post(s)
Liked: 234
I've seen multiple IB builds for HTs whereby the back-side is the outside.
I spent years in and around the Convention Center business, being involved in many aspects of big time sporting events, live performances, and of course conventions of all sizes. "Put a plant by it" was our go to saying for any aesthetic concern.
wlelandj and robertintemple like this.
FOH is offline
post #278 of 1115 Old 10-11-2013, 11:24 AM
FOH
FOH's Avatar
Quoted: 38 Post(s)
Liked: 234
Sounds like you'll be fine. Besides, additional spreading of the sources should provide even more modal smoothing in both floor-to-ceiling, and side-to-side. You'll essentially have a planar wave coming at you. Plus, it'll look bad-arse. cool.gif
FOH is offline
post #279 of 1115 Old 10-11-2013, 12:31 PM
Bass Enabler
Scott Simonian's Avatar
Quoted: 5293 Post(s)
Liked: 4178
Scott Simonian is online now
post #280 of 1115 Old 10-11-2013, 12:42 PM
Reddig's Avatar
Quoted: 161 Post(s)
Liked: 306
Put a plant by it LMAO!
JBL Pro Cinema/PSA&HSU subs/Crown power/Sony SXRD
MANCHESTER UNITED!!
Reddig is offline
post #281 of 1115 Old 10-11-2013, 04:03 PM
FOH
FOH's Avatar
Quoted: 38 Post(s)
Liked: 234
... ever see a major trade-show on the eve prior to opening? The uninitiated can never conceive how it'll ever open on time, let alone appear nicely put together.
Those big shows couldn't happen without many essentials, and as I said, a lot of plants. Then gorgeous "hired guns" are brought in as marketing tools, ..nobody has a problem with the trip hazards, and strategically placed plants as long as the hired guns are vying for their attention ... luring individuals into their booth to exhibit their wares. The irony of a buxom, scantily clad amazon getting one's attention while handing out product literature goes unappreciated until you see her displaying a large print credential reading "Exhibitor", ... yeah sweetie, we know.
I digress ..
Back to the baffle wall IB construction.
FOH is offline
post #282 of 1115 Old 10-11-2013, 04:10 PM
Reddig's Avatar
Quoted: 161 Post(s)
Liked: 306
I digress ..
Nice man I could imagine.
MANCHESTER UNITED!!
Reddig is offline
post #283 of 1115 Old 10-15-2013, 08:50 AM - Thread Starter
MKtheater's Avatar
Liked: 1122
OK guys, I have some other things going on now as well. I have 5 Behringer Truth 2031A's and I just ordered 3 SEOS Fusion 10 pure kits with assembled crossovers. I am attending CHT's GTG for their new products and will compare the SEOS. I will also compare the SEOS to my BFM speakers too. I will throw back in the JTR 888LP too just for kicks. You know how memory is so I always remind myself!
Marantz 7702 Atmos
post #284 of 1115 Old 10-15-2013, 09:12 AM
LTD02's Avatar
Liked: 2578
behringer truth's? fusion 10 pures?
mk, have you seen what chop is building in his seosr project? seos24 / bms 459_ coaxial / dual td15m's. high sensitivity, point source, mid-bass monsters.
just say'n.
LTD02 is offline
post #285 of 1115 Old 10-15-2013, 09:20 AM - Thread Starter
MKtheater's Avatar
Liked: 1122
Well these speakers fell into my lap! The truths were free along with a B&K reference 20 processor! The SEOS will go to a good home unless they are better surrounds than my current W10's!
I have been watching the SEOSR build, I would love a DR type speaker with that BMS coaxial!
Besides I did own the JBL 4675C-LF's which had a huge horn and CD with dual 2226's!
Marantz 7702 Atmos
post #286 of 1115 Old 10-15-2013, 10:30 AM
Reddig's Avatar
Quoted: 161 Post(s)
Liked: 306
Nice man sounds like a lot of fun. Curious how the Fusion 10 will compare to the 888 and if they remind u of the SHO-10. Also excited for CHTs new Theater 10 and hope u get to hear them. The BFMs r gunna b LCR champs. I'm not familiar with the Behringers. Fusion 10s should b kickass surrounds
MANCHESTER UNITED!!
Reddig is offline
post #287 of 1115 Old 10-15-2013, 11:33 AM
FOH
FOH's Avatar
Quoted: 38 Post(s)
Liked: 234
I had no idea CHT was even still in existence. Granted, I really wouldn't know, but did ASSume they went belly up.
FOH is offline
post #288 of 1115 Old 10-15-2013, 11:37 AM
FOH
FOH's Avatar
Quoted: 38 Post(s)
Liked: 234
Loved those, and would've enjoyed seeing them/experimenting w/them mated to an über high end compression driver.
FOH is offline
post #289 of 1115 Old 10-15-2013, 12:35 PM - Thread Starter
MKtheater's Avatar
Liked: 1122
Trust me when I say this, I would have never sold them if I did not need the room for subs. Once I went to IB or multiple sealed I needed more space and they had to go. They are still one of my favorite speakers ever! I do like my DR-250 stacks better but the sound stage and mid bass still go to the mighty JBL's! Throw that BMS coaxial and horn on top and who knows?
Marantz 7702 Atmos
post #290 of 1115 Old 10-15-2013, 12:46 PM
FOH
FOH's Avatar
Quoted: 38 Post(s)
Liked: 234
I trust you, and I understand entirely. Plus, you've been on one helluva odyssey, experiencing various mains and subwoofing approaches first hand, in your room. cool.gif
That's very cool.
I've experimented significantly as well, also employing differing sidewall acoustic strategies mated to mains approaches. I've not experimented wrt subwoofer type as you have. But I have experimented with various optimization techniques, time alignments, etc, with my current IB/multiple small-sealed system.
FOH is offline
post #291 of 1115 Old 10-15-2013, 02:59 PM
nfraso's Avatar
Liked: 172
You haven't missed much. Apparently they are ditching the SHO-10's in favor of slapping their name on some mystery Chinese PA speakers, the 'Vcomtek MS-10+':
http://www.vcomtek.com/product/Professional_sound_speaker/2012/0525/83.html
"MS series speaker light in weight,easy to install and hang up,ladder-shape design,control internal standing wave.Outstanding for its sound design to make the sound much clear.It applied to small medium-sized conference room."
nfraso is offline
post #292 of 1115 Old 10-15-2013, 06:16 PM - Thread Starter
MKtheater's Avatar
Liked: 1122
Ok, let's move on please, you need to let it go already. Let's focus on IB and SEOS build.
Marantz 7702 Atmos
post #293 of 1115 Old 10-15-2013, 06:24 PM
LTD02's Avatar
Liked: 2578
"Well these speakers fell into my lap!"
ah! was just wondering...
LTD02 is offline
post #294 of 1115 Old 10-15-2013, 07:21 PM
Reddig's Avatar
Quoted: 161 Post(s)
Liked: 306
Any pics of your handy work so far to the baffle wall?
MANCHESTER UNITED!!
Reddig is offline
post #295 of 1115 Old 10-15-2013, 07:25 PM
nfraso's Avatar
Liked: 172
No problem. You brought up CHT and their new products though. I was just filling in for those who don't know (which is most people). smile.gif
nfraso is offline
post #296 of 1115 Old 10-15-2013, 07:28 PM
LTD02's Avatar
Liked: 2578
and iirc chase partnered with the audio advisor guy to form new company...chain home theater or something like that? maybe it was april fools joke. not sure.
LTD02 is offline
post #297 of 1115 Old 10-15-2013, 09:08 PM
Reddig's Avatar
Quoted: 161 Post(s)
Liked: 306
I heard the same. Think they spelled it Chane
MANCHESTER UNITED!!
Reddig is offline
post #298 of 1115 Old 10-17-2013, 08:39 AM
lukeamdman's Avatar
Quoted: 1080 Post(s)
Liked: 1200
lukeamdman is offline
post #299 of 1115 Old 10-17-2013, 09:33 AM - Thread Starter
MKtheater's Avatar
Liked: 1122
Originally Posted by lukeamdman View Post
Hey MK, how far into the single digits will these eight IB drivers extend in your room? What kind of SPL do you anticipate at and below 10hz?
Max numbers I assume? I usually listen at reference with the LFE 10 dBs hot because I love to feel those ULF's on the body. After looking at some other threads I will try a flat setting but having a house curve boosting the low end. I usually calibrate to a flat response to 4-5 hz and then raise the level 10 dBs on the sub trim. My last system was -3 dBs at 5 hz with the sherbourn AVR in the mix and -3 dBs at 10hz with the meridian. Go figure! I never saved the graph of the sherbourn. I noticed this running spec lab graphs and I gain lots of low end on the same spec graphs.
I hit 127 dBs at 10hz with my last system and now I can't get my sound card to go over 115 dBs since running spec lab. I will figure it out once I am up and running. I am waiting on my tools to return to finish this. I need to add a single 2x4 to the frame, add 2x4's for the attachment of the drivers, then of course add the plywood and cut the circles. Then add another layer of plywood. Once I have the drivers in place I will wire them up and test them just to make sure they all move together. Then I will add the shelves to the speakers. Before I install the speakers I am adding a brand new back panel to my center channel with the proper crossovers. Then I can place the speakers and wire them up and make sure they are working. Finally I will seal them up and add linoacoustic rolls to the wall and then test again. Add screen and then measure! My brother is helping with all this and he only showed up 3 times and 3 hours per so that is why it is taking so long. My other friends who would have finished this in a day are busy but I am bribing them to come over. Hopefully soon. I will take pics before I close anything and use the better camera.
Marantz 7702 Atmos
post #300 of 1115 Old 10-17-2013, 10:12 AM
Reddig's Avatar
Quoted: 161 Post(s)
Liked: 306
Free beer and pizza usually gets my helper friends on board for some labor.
When do the Fusion kits show up?
MANCHESTER UNITED!!
Reddig is offline
