Dayton DVC 15 in 3 cu ft sealed enclosure? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 08-18-2013, 10:38 PM - Thread Starter
cyde01's Avatar
I was given a Dayton DVC 15 from a friend recently, and I have a 240w plate amp that's not being used. I was thinking about buying the 3 cu ft enclosure from DIY Sound Group for this driver. Would a 240w amp be sufficient for this arrangement? The sub would go in my 10x11x8' office. I'm not looking for earth shattering bass but rather clean bass to help my stereo's 10" woofers with the low end.
cyde01 is offline
post #2 of 5 Old 08-18-2013, 10:45 PM
LTD02's Avatar
Quoted: 2341 Post(s)
Liked: 2578
that driver in that enclosure with that amp would be just fine.
a little larger ported enclosure could really give you a lot more bass, so it kind of depends how loud and how low you are shooting for.
Listen. It's All Good.
LTD02 is offline
post #3 of 5 Old 08-18-2013, 10:50 PM - Thread Starter
cyde01's Avatar
Thanks for the input. I honestly don't need anything below 30hz since music is priority. My mains already play fairly low with the significant gain in my small room. I'd just want a boost in the low end for music. It doesn't need to play low or terribly loud since I get a bit of room gain with the door closed.
cyde01 is offline
post #4 of 5 Old 08-19-2013, 05:34 AM
diaz's Avatar
The DVC is definitely a capable speaker, let us know how it goes!
diaz is offline
post #5 of 5 Old 08-19-2013, 11:29 AM - Thread Starter
cyde01's Avatar
I ordered the flat-pack and will assemble later this month after I'm finished painting the kitchen cabinets. I was concerned 240w would under power this sub in a sealed configuration; but since you guys said it's good to go, I'm going forward with the build. I'll report back with pictures once paint goes on the box.
cyde01 is offline
