Active and Passive connections - AVS Forum | Home Theater Discussions And Reviews
Old 08-19-2013, 06:09 AM - Thread Starter
Hindikush's Avatar
I'd love to be able to make a decision and stick with It, but I know myself better than that.
The problem I made for myself Is, I want to go passive on my speaker builds but at a later date I may want to
go active. Thinking ahead (for once) I'd like to implement the hardware to make this possible prior to
final speaker mounting.
Attached Is a pic of what I'd like to do, but have a feeling (I'm no EE) what I propose may still act as a filter when run active.
Any thoughts If this may work?
Hindikush is offline
Old 08-19-2013, 07:37 AM
Trepidati0n's Avatar
Quoted: 39 Post(s)
Liked: 107
It will "probably not" work. The reason being is most of the "passive circuit" is still in parallel with the speaker terminals. Secondarily, the woofer and the tweeter will still be connected via the 10 uF capacitor (unless you run a bi-amp terminal block). A solid amp should be able to overdrive the passive circuit..but probably not your best choice. An external terminal block would do the job...just needs to be sealed VERY well. If you can handle the space,...mounting the crossovers externally in a small box might work as well.
I must be guilty because people say I am guilty because they chose to call me guilty because they refuse to see the truth. Much easier to be part of the mob..
Trepidati0n is offline
Old 08-19-2013, 08:09 AM
tuxedocivic's Avatar
Quoted: 1912 Post(s)
Liked: 1730
I'd just wire it passively with biamp terminals, then down the road, pop the terminal out and detach. Run the active wiring near to the terminal ahead of time, but not hooked up. So when you make the switch, just pull the terminal unhook the passive and hook up the active wire.
Ryan
tuxedocivic is online now
Old 08-19-2013, 09:32 AM - Thread Starter
Hindikush's Avatar
I was hoping I was incorrect, shucks.. Thanks for the ideas though, let me try again.
I wanted to run (2) Neutrik 4 post panel mounts per box, giving me the ability to run them bi-amped or single through the passive (wiring change inside Neutrik connector for bi or single) or active through the second Neutrik.
I could run the passive outs back to the active Neutrik In, then back out to the drivers. Then I could pull this active Neutrik and disconnect the passive out wires leaving the leads going to the drivers connected whew.. I believe this would work, would It not?
I should have ordered the 8 pole Neutrik's, to make this even more confusing for me, lol.. I'm going to need to make a placard to mount to the rear of this box after I screw this all up...
I'll update my layout shortly & re-post the above idea, thanks all.
Old 08-19-2013, 01:15 PM
BassThatHz's Avatar
Quoted: 2038 Post(s)
Liked: 1568
A Neutrik loopback, that's awesome, I'll have to remember that one.
You are giving me idea's... and that's a bad thing for my wallet!!!
I think I will "cheap-out" and put my XO's in an external box in my rack instead.
BassThatHz is offline
Old 08-19-2013, 01:26 PM - Thread Starter
Hindikush's Avatar
If I would have thought this through thoroughly first, may have saved myself some $$ on these Neutrik connectors/plugs.
Old 08-19-2013, 04:22 PM - Thread Starter
Hindikush's Avatar
As understood from earlier thanks for the clarification Tux.., Trepid.., driving speakers actively while leaving the passive crossover connected (as shown In my first pic) Is a bad idea.
Will this work? Pretty much what I explained In post #4, visualized. I'll pull the active Neutrik and re-wire the back end to remove the passive from the chain.
BassThatHZ, external boxes, or removable rear panel, The removable rear panel would also aid In getting the drivers out.
