Setup opinions please. - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 32 Old 08-23-2013, 12:06 AM
BassThatHz's Avatar
Quoted: 2033 Post(s)
Liked: 1556
These are two common SPL meters.
http://www.parts-express.com/pe/showdetl.cfm?partnumber=245-263
http://www.parts-express.com/pe/showdetl.cfm?partnumber=390-792
Without them you can only guess at what levels are sufficient for you.
Workmans occupational safety exposure recommendations
Another words you should never play a movie above105db, and never play anything above 115db.
This is with 4 subwoofers: Quad LMS-18's
This is with 8 subwoofers: Quad LMS-18's and Quad Dayton 18's.
You should be close to 1/3 or 1/4 of my SPL here. A good 105 or 110db I would think.
It should be 3 to 6 times louder than the HSU VTF-15h, for a pair or quad set of Dayton's with 1 or 2 nu3kDSP's.
For $550 this subwoofer would be somewhere between the LMS-18 and the HO-18's performance. Definitely a step up.
http://www.sonicelectronix.com/item_68609_RE-Audio-XX-18D2.html
You get what you pay for...
BassThatHz is offline
post #32 of 32 Old 08-25-2013, 04:06 AM - Thread Starter
03twotonehd's Avatar
Okay, thank you for your input and info. So if I run a dual dayton setup it should theoretically be 3 times louder than the hsu, in relation to that what would the suggestex re audio dual setup achieve for the extra $500? And what amp would I need and what size box?
03twotonehd is offline
