SEOS kits with AE woofers? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 08-21-2013, 12:10 AM - Thread Starter
ozziedog's Avatar
Liked: 24
Has there been any discussion about any future SEOS kits using AE woofers?
Ideally I would like to build LCR's using the TD15M, DNA-360, and either the SEOS 15 or 18 (probably the 15 since their will be a much cheaper plastic version soon) Then for sides and surrounds I was thinking the TD10M, DNA-360, and seos 12.
Perhaps Eric can chime in on this.
ozziedog is offline
post #2 of 12 Old 08-21-2013, 10:23 AM
pgwalsh's Avatar
Quoted: 392 Post(s)
Liked: 284
There's been some discussion, but I believe it was decided not to do it do to availability. There are numerous designs for the 12 and there will surely be more for the 15.
Diy Sound Group - Information & Tips
Builds: Maelstrom 21 Ottoman Build, Dual Opposed MFW's x 2, Statements, SEOS-12/TD12M x 5.
pgwalsh is offline
post #3 of 12 Old 08-21-2013, 10:29 AM
nater1's Avatar
I believe there is a front baffle that works with the 2 cubic foot flat pack. At that point you just need to order the remaining drivers and crossover parts and assemble. Honestly beyong the ordering of parts, it would go together like any other kit.
Edit, this is for the 12" woofer. The 15 and 10 might be available after the matching seos waveguides show up in plastic
nater1 is offline
post #4 of 12 Old 08-21-2013, 03:42 PM - Thread Starter
ozziedog's Avatar
Liked: 24
To me the main difference is being able to order the completed crossover. I don't mind doing any of the box, I just do not want to touch the crossover.
ozziedog is offline
post #5 of 12 Old 08-21-2013, 04:00 PM
wormraper's Avatar
Quoted: 313 Post(s)
Liked: 154
I felt the same way. but the crossovers are actually a piece of cake.
wormraper is online now
post #6 of 12 Old 08-21-2013, 04:47 PM
pgwalsh's Avatar
Quoted: 392 Post(s)
Liked: 284
There are people around the forum's the will build it for you. I don't know if they charge or not. The crossover isn't too bad, just practice soldering on spare wires first.
pgwalsh is offline
post #7 of 12 Old 08-21-2013, 09:28 PM
LTD02's Avatar
Quoted: 2340 Post(s)
Liked: 2576
"Ideally I would like to build LCR's using the TD15M, DNA-360, and either the SEOS 15..."
I would expect that somebody would be happy to design a network for that combo. it will be a winner and like you say, with the plastic 15 horn, it is an obvious low-cost super-performer.
2.5 cubic feet sealed with stuffing gives -3db at 85hz, q=0.707.
robotbunny likes this.
Listen. It's All Good.
LTD02 is offline
post #8 of 12 Old 08-22-2013, 09:58 AM
robotbunny's Avatar
^ Nice.
Before I got the TD12M's I simmed the 15M both ported and sealed...did the same as you for sealed LTD.
ozziedog, you should hop on the plastic 15 GB if you haven't already. I've got the TD10M, DNA-360, and SEOS-12...but I'm designing for the TD10M and SEOS-AT1 w/DNA-360 or BMS 4550 atm.
-Nate
robotbunny is offline
post #9 of 12 Old 08-24-2013, 02:36 PM
John_E_Janowitz's Avatar
Quoted: 26 Post(s)
Liked: 81
Erich and I have discussed some things over the past year or so. We have had some discussions how some kits could be mutually beneficial to both of us as well as the DIY users. The main setback has been mostly on my end in having the time to work through some of the details. If it is something people want to see, I am sure it can be put as more priority here. I just posted up on the facebook page a few days ago asking what people want to see and giving a few options for different kit options I am looking into pursuing. You are welcome to stop by there and weigh in on what you would like to see me work on first.
John E. Janowitz
Acoustic Elegance, LLC
"Learn from the mistakes of others... you can't possibly live long enough to make them all yourself"
John_E_Janowitz is offline
post #10 of 12 Old 08-24-2013, 03:48 PM
gpmbc's Avatar
Quoted: 312 Post(s)
Liked: 197
Things keep getting better.
gpmbc is online now
post #11 of 12 Old 08-24-2013, 04:10 PM
Jon_B's Avatar
Quoted: 25 Post(s)
I'm excited to hear that John. That is great news! I'm not on Facebook, I am interested in the active td12 seos12
Jon_B is offline
post #12 of 12 Old 08-24-2013, 05:41 PM - Thread Starter
ozziedog's Avatar
Liked: 24
Glad to see you and Eric are looking into this already. I will definitely be getting on your Facebook page. Thanks for the reply.
ozziedog is offline
