does driver placement matter in a ported box? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 08-21-2013, 12:51 PM - Thread Starter
stgdz's Avatar
I'm putting together a tall and skinny ported. Its going in the corner behind the plasma. In order to fit it behind everything and allow the woofer to move with out smacking the entertainment center the best option for me is to put it right at the corner where the port starts.
Never built a ported sub just sealed and horns. I wish i could put it in the center but it doesnt look like it will work.
stgdz is offline
post #2 of 4 Old 08-21-2013, 12:57 PM
Bass Enabler
Scott Simonian's Avatar
Quoted: 5302 Post(s)
Liked: 4184
Scott Simonian is online now
post #3 of 4 Old 08-21-2013, 09:41 PM
LTD02's Avatar
Quoted: 2341 Post(s)
Liked: 2578
not sure what you are asking.
Listen. It's All Good.
LTD02 is offline
post #4 of 4 Old 08-22-2013, 08:08 PM - Thread Starter
stgdz's Avatar
I'm going to add one more cross brace to this so I've got four corners that I can put the driver in. The ideal spot for the driver is rite near the port entrance. I can't put it up high as I'm worried the sub may tip and I don't want to put it towards the port exit (front of the sub) since the driver will likely smack the entertainment center.
but mr pizza says that its fine so i'm going to finish cutting up wood soon.
stgdz is offline
