Would this 18" Celestion work in something like an 18" CHEAP THRILL ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 08-22-2013, 12:08 PM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2684
http://www.parts-express.com/pe/showdetl.cfm?partnumber=299-420&utm_source=Retail&utm_medium=Email_Newsletter&utm_content=299-420&utm_campaign=email082213
Celestion 18" Cast Frame Professional Woofer 8 Ohm $99
Just wondering. Would the box size just be kinda big? Or you would need to go 3 way ?
Mfusick is offline
post #2 of 11 Old 08-22-2013, 01:03 PM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2684
Am I way off ? (I am noob)
How would you go about designing such a beast ?
Mfusick is offline
post #3 of 11 Old 08-22-2013, 01:25 PM
pitviper33's Avatar
Quoted: 267 Post(s)
Liked: 116
I'm a noob too... but I'd bet it'll start beaming below the frequency where the 12" waveguide goes omni. You'd probably have to step up to the SEOS 15 or 18.
pitviper33 is online now
post #4 of 11 Old 08-22-2013, 11:05 PM
BassThatHz's Avatar
Quoted: 2038 Post(s)
Liked: 1568
It should work just fine.
At 19inches it would be getting mighty wide.
BassThatHz is offline
post #5 of 11 Old 08-23-2013, 06:04 AM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2684
Bigger is better right ?
Mfusick is offline
post #6 of 11 Old 08-23-2013, 06:11 AM
Thatsnasty's Avatar
Quoted: 51 Post(s)
Liked: 42
But really a bigger driver gets you more bass, for less excursion, and generally speaking, it can be a bit more sensitive too.
I'm not crossover designer but I think because this driver is 18" it limits its extension before it starts to beam (viper said it above).
So get a good directivity match to an 18", one might have to cross it to a large waveguide that can dig lower to reach the woofer.
Others may chime in..
Thatsnasty is offline
post #7 of 11 Old 08-23-2013, 07:56 AM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2684
So what is a good tweet to go with it ?
Mfusick is offline
post #8 of 11 Old 08-23-2013, 08:17 AM
LTD02's Avatar
Quoted: 2344 Post(s)
Liked: 2582
the funny thing is that might actually kind of work.
to match directivity at the crossover region, a crossover around 750hz or so is what one would be looking for and compression drivers that can handle that tend to start getting more expensive which defeats the purpose of cheap thrills.
Listen. It's All Good.
LTD02 is offline
post #9 of 11 Old 08-24-2013, 10:46 AM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2684
So what is a good tweeter option ? Is there a decent one that will dig down low enough to match up well ?
Or is it better to go 3 way ?
How much difference would a good tweeter that digs down low be in cost compared to a cheaper tweeter and a midrange driver ?
Or in comparison to a tweet that does not go so low, but is good and costs less so I could match it up with a better driver instead?
Mfusick is offline
post #10 of 11 Old 08-24-2013, 12:41 PM
Bill Fitzmaurice's Avatar
Liked: 4682
The highest you want to run an eighteen is perhaps 800Hz, pretty much forcing a 3 way unless you use an expensive 2" throat horn HF driver.
Bill Fitzmaurice is online now
post #11 of 11 Old 08-27-2013, 11:08 AM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2684
Thanks !
Mfusick is offline
