Need help loading a drive into WinISD pro alpha! I keep getting errors :( Help me out please - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By LTD02
post #1 of 21 Old 08-23-2013, 06:50 PM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2696
OK so I am trying to load a Soundstream X3 18" into the program and it keeps throwing me errors:
WTF am I doing wrong? Someone help me ?
Here is the specs:
Specifications
Fs (Hz) 32.68
Qms 5.456
Vas (ft³) 2.401
Cms (mm/N) 0.516
Mms (g) 461.6
Xmax (mm) 20.00
Xmech (mm) 40.00
Piston Diameter (in) 13.78
Sd (in²) 149.10
Qes 0.454
Re (Ω) 3.83
Z (Ω) 4
BL (Tm) 28.27
Rms Power DCV & W 84V (7,000)
Qts 0.419
NO (%)0.507
1w/1m SPL (dB) 89.00
Voice Coil Diameter (in) 4.00”
Impedance (Ω) DVC 2Ω
M-vd (ft.3) 0.543
Overall Diameter (in) 19.00”
Overall Height (in) 11.125”
Mounting Depth (in) 10.00”
Cutout Diameter (in) 16.875”
Flange Width (in) 0.75”
Flange Height (in) 1.00”
Weight (lbs) 65
BurpPower DCV (W) 105V (11,000)
and PDF owners manual with the specifics:
http://www.soundstream.com/html/manuals/X3.pdf
What am I doing wrong ?
Mfusick is offline
post #2 of 21 Old 08-23-2013, 07:07 PM
mtg90's Avatar
Quoted: 469 Post(s)
Liked: 922
I enter data in this order,
Mms, Cms, Bl, Le, Re, Sd, Xmax, Pe, Qms, then click on another box or hit tab and save.
Or at minimum Qts, Vas, Fs, Sd, Xmax and Pe.
mtg90 is offline
post #3 of 21 Old 08-23-2013, 07:23 PM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2696
Ok I will try this now... thanks
Mfusick is offline
post #4 of 21 Old 08-23-2013, 07:33 PM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2696
It worked for the first, but when I enter the rest of the specs the same issue mad.gif
Mfusick is offline
post #5 of 21 Old 08-23-2013, 07:44 PM
cookieattk's Avatar
Quoted: 111 Post(s)
Liked: 90
download the newer one that ones pretty old
cookieattk is offline
post #6 of 21 Old 08-23-2013, 08:16 PM
Mrkazador's Avatar
Quoted: 262 Post(s)
Liked: 390
Don't overwrite any values that winisd calculates. I always start with the electro mech parameters and work my way down. After that I fill in any missing values.
Mrkazador is offline
post #7 of 21 Old 08-23-2013, 08:34 PM
dmadesign's Avatar
I was able to enter all the parameters but I noticed when I entered the Fs and Mms I get the wrong Cms??? I attached a screenshot if you want to look it over. I am also using the newest version of WinISD.
dmadesign is offline
post #8 of 21 Old 08-23-2013, 08:56 PM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2696
Where can I get newest version ?
Mfusick is offline
post #9 of 21 Old 08-23-2013, 08:56 PM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2696
Can you send me file ?
Mfusick is offline
post #10 of 21 Old 08-23-2013, 08:59 PM
dmadesign's Avatar
I had to get it from their Facebook page.
https://www.facebook.com/WinISD
I tried to add the file as an attachment but it didn't work I can try to pm it to you.
post #11 of 21 Old 08-23-2013, 09:01 PM
mtg90's Avatar
Quoted: 469 Post(s)
Liked: 922
+1
I enter data in this order, Mms, Cms, Bl, Le, Re, Sd, Xmax, Pe, Qms, then click on another box or hit tab and save.
If you have all the specs to do the top line above you should not need to enter Fs, Vas, Qts, Qes, Dd, Rms, Vd, no, USPL, SPL. Doing so will likely mess things up, if the values are close don't worry about small discrepancies between those that are published and auto calculated.
If you don't have all the needed Electro-mechanical parameters you can get by modeling with only those specs on the bottom line which will give you most of the graphs, but again don't try to enter other T/S specs because it may not like that.
Now if it still gives you problems try clearing fields one by one. Erase the number and click on another box, if the missing data does not auto recalculate put it back in.
mtg90 is offline
post #12 of 21 Old 08-23-2013, 09:06 PM
dmadesign's Avatar
+1
I tried that. I entered the Mms and Cms and I get an Fs of 10.3 Hz.
post #13 of 21 Old 08-23-2013, 09:11 PM
mtg90's Avatar
Quoted: 469 Post(s)
Liked: 922
Looks like their data should have an extra 0 after the decimal point for Cms.
mtg90 is offline
post #14 of 21 Old 08-23-2013, 11:50 PM
LTD02's Avatar
Quoted: 2495 Post(s)
Liked: 2830
+1
by clicking on the units next to cms it will change from um/N to mm/N and so on...
if it is on mm/N then enter 0.0517
if it is on um/N then enter 51.7
Listen. It's All Good.
LTD02 is online now
post #15 of 21 Old 08-24-2013, 09:49 AM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2696
I will try again tonight. If one of you has the file saved and wants to share biggrin.gif
Mfusick is offline
post #16 of 21 Old 08-24-2013, 12:36 PM
Mrkazador's Avatar
Quoted: 262 Post(s)
Liked: 390
There you go
1k .zip file
File Type: zip SoundStream X3-182.zip (730 Bytes, 33 views)
post #17 of 21 Old 08-24-2013, 12:41 PM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2696
There you go
SoundStream X3-182.zip 1k .zip file
Thanks !
I am not sure why I kept getting so many errors. I've done it before with other drivers.
Mfusick is offline
post #18 of 21 Old 08-24-2013, 07:27 PM
Bill Fitzmaurice's Avatar
Liked: 5667
Because WinISD calculates to a higher resolution than the specs provided by many driver manufacturers, and if the manufacturer specs don't precisely match the calculated result it reads as an error. That's why you have to enter as few specs as possible and let the program calculate the rest. I only enter Qes, Qms, Vas, Fs, Mms ,Re, Le, xmax, xlim and Pe.
Bill Fitzmaurice is offline
post #19 of 21 Old 08-27-2013, 10:08 AM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2696
If I enter only what you list above I should get good results ???
Mfusick is offline
post #20 of 21 Old 08-27-2013, 10:28 AM
Liked: 5667
It's what I do.
post #21 of 21 Old 08-27-2013, 01:45 PM
LTD02's Avatar
Liked: 2830
another method:
make sure all fields are clear, then
enter qes then hit tab, enter qms
hit tab a couple times and let it calculate qts
hit tab a few times to move to mms
enter mms, re, bl, le, sd, xmax, and pe
by using tab after entering each data, it will calculate what it needs to
i no longer get any conflicts
sometimes the specs calculated don't match exactly the manufacturer specs, but its only rounding type errors, so it is not material
Hifisound likes this.
LTD02 is online now
