Bass for the 98%. - Page 5 - AVS Forum | Home Theater Discussions And Reviews
post #121 of 124 Old 08-30-2013, 06:16 AM
Mike Garrett's Avatar
Quoted: 6943 Post(s)
Liked: 4622
I swear I've seen you mention xmas in the past...lol
Something you probably never have to worry about with your room full of subs. By the time you hit over excursion, you would be running out of the house because the house was crumbling down. smile.gif
mjgarrett100@gmail.com
Mike Garrett is offline
post #122 of 124 Old 09-07-2013, 01:29 PM
Tony_Montana's Avatar
Quoted: 45 Post(s)
if somebody uses more than 4 diy subs , he will definately use some more advanced DSP settings (with a device like miniDSP, behringer DCX, dbx driverack etc)
Which would be the best AVR for DIY subs?
I read that Audyssey XT32/SubEQ is right now the *hottest* room correction system for bass & multiple subs
but can we combine audyssey with external devices?
Is there any room correction system that completely isolates the bass frequencies?
Tony_Montana is offline
post #123 of 124 Old 09-07-2013, 02:20 PM
Mrkazador's Avatar
Quoted: 262 Post(s)
Liked: 390
If you eq the sub flat using something like a minidsp then I don't think Audyssey will touch it. Could be wrong...
Mrkazador is offline
post #124 of 124 Old 09-07-2013, 02:36 PM
gpmbc's Avatar
Quoted: 340 Post(s)
Liked: 207
I use 8)18s and audyssey xt32 in the denon 4311 does a great job in dialing in the bass. I also have a Marchand bassis which is an external parametric eq but no need at the moment. I do have a couple more subs coming for near field placement. We'll see if audyssey is enough or if I'll need a combination of the two.
gpmbc is offline
