Pro amp sound level - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 36 Old 08-29-2013, 09:01 AM
04rex's Avatar
Quoted: 117 Post(s)
Liked: 26
What is the RMS power for the Crown amps mentioned?
04rex is offline
post #32 of 36 Old 08-29-2013, 10:42 AM
Suntan's Avatar
Quoted: 75 Post(s)
Liked: 107
Originally Posted by Jinjuku View Post
I would gladly pay another $20 if Behringer would put $5 of heatsink and PWM fan in their units.
I wouldn't.
Neither would anyone that would setup this amp outside, or away from the listening area... ...which is what it is sold as, more-so than to be hooked up to a TV sitting next to the couch.
-Suntan
Suntan is offline
post #33 of 36 Old 08-29-2013, 11:37 PM - Thread Starter
DotJun's Avatar
Quoted: 574 Post(s)
Liked: 154
I'm not saying it can't be true, but I find it hard to believe that an 80mm fan @2k rpm is 19db<.
Regardless, I usually use fans that are 10db<.
This is my prefered 120mm
http://www.amazon.com/setting-Anti-Stall-Bearing-NF-S12A-ULN/dp/B00BEZWPTO/ref=sr_1_3?ie=UTF8&qid=1377840889&sr=8-3&keywords=noctua+nf-s12a
And 80mm
http://www.amazon.com/Noctua-NF-R8-80mm-Fan-CFM/dp/B000S95RWE/ref=sr_1_2?ie=UTF8&qid=1377840981&sr=8-2&keywords=nf-r8-1800
DotJun is offline
post #34 of 36 Old 08-30-2013, 04:48 AM
A9X-308's Avatar
Quoted: 1280 Post(s)
Liked: 951
Originally Posted by realtight View Post
Why does no one mention Yamaha pro amps? The fans only kick in under very extreme situations if ever at all. Buy one and be done with the silly jet engine noises.
I agree. I have 6 Yamaha pro amps currently in the rack, 3 new P-S series, and three older P series, and I've only been able to get the fans to come on in rare instances on the subwoofer amps, but even then they are staged and come on as needed at the lowest speed required and switch off when the duty cycle of the material reduces enough. Even then they are not that loud. When I used them in the PA, it was rare for the fans to come on max, and I beat the snot out of them, far, far harder than almost any HT person would.
A9X-308 is offline
post #35 of 36 Old 08-30-2013, 04:57 AM
BIG INJUN CHIEF's Avatar
Liked: 194
And 80mm
I believe most pro amps use 24v fans.
BIG INJUN CHIEF is offline
post #36 of 36 Old 08-31-2013, 11:57 PM - Thread Starter
DotJun's Avatar
Quoted: 574 Post(s)
Liked: 154
Really? That's good to know! I'll check out the suggested fans here and see how tolerable they are. Thanks again.
DotJun is offline
