Any bass heads running single sheet of drywall in their room? - AVS Forum | Home Theater Discussions And Reviews
Old 08-26-2013, 12:11 PM - Thread Starter
MALIX's Avatar
Liked: 33
Related to my other thread ..
I am building a room and wondered if a single sheet of drywall can be bad. I mean can you have strange interactions with the walls when funing four of S/.HO 18's as an example? If so I can just run up another sheet of drywall..and some damping compound.
MIght be a silly question but I figured it coudnt hurt to ask.
Sony HW50ES | Denon X4000 | Rocket RS850s | Rocket RS200 | Rocket RS750s | Rocket RS250s | Quad Stereo integrity 18" d4 sealed subs | Inuke nu46000 | MiniDSP | Oppo 103D
My Build http://www.avsforum.com/t/1510721/the-bass-for-the-98-diy-build
MALIX is offline
Old 08-26-2013, 12:46 PM
realtight's Avatar
Quoted: 18 Post(s)
Liked: 49
Unless you build a concrete bunker 100 feet below the foundation of your house, you will never remove the tactile earth shaking bass 4 18's will create...
realtight is offline
Old 08-26-2013, 12:52 PM
BassThatHz's Avatar
Quoted: 2038 Post(s)
Liked: 1568
I lifted the screws loose on the sheet directly above my subs in my old theater that only had single layer, and it rattled loudly enough that I thought I broke the projector screen mounts.
I now run triple layer with greenglue and haven't had a structural problem yet (6 months).
BassThatHz is offline
MKtheater's Avatar
Quoted: 1596 Post(s)
Liked: 1123
It all depends how silent and low of a noise floor you want. Once bass starts rolling you start hearing the room cry uncle and if you don't want to hear that then you need some help.
Marantz 7702 Atmos
MKtheater is offline
Old 08-26-2013, 01:09 PM
realtight's Avatar
Quoted: 18 Post(s)
Liked: 49
Just out of curiosity... how far away from your neighbors are you?
When I built my first 18" sealed Avalanche I connected it to my living room setup and my friend brought over a bass testing CD and we gave it all we could. half hour later my neighbor called me telling me I knocked down all of the China in her dining room. Her house was 30ft away from my closest wall...
Old 08-26-2013, 01:14 PM
MKtheater's Avatar
Liked: 1123
I say they were full of crap. I bet they just blamed you. I run loud bass and my neighbors never complain. Even in my concrete basement you can hear bass around my house. I have 1.07 acres though but they are closer on the sides. The closest neighbor must be 50 feet or more(their house not land). I have broken lights, marble, door handles, molding, I have knocked down my acoustic panels and pots and pans out the cabinets upstairs.
Marantz 7702 Atmos
Old 08-26-2013, 01:19 PM
Stumbo's Avatar
Quoted: 55 Post(s)
Liked: 88
Typically your neighbors won't even notice the bass during movies, it's the rhythmic thump of music the irritates people.
Oppo 103D
Samsung pn64f8500
Pioneer vsx-82txs
And a bunch of DIY speakers and subs.
Coming soon: Dirac Room Correction
Stumbo is offline
Old 08-26-2013, 03:01 PM - Thread Starter
MALIX's Avatar
Liked: 33
Out of Curiosity What "help have you guys gotten.. Do you have Decoupled walls. or 2 layers GG/ 5/8th Drywall? What has worked for you?
And in my case The closest neighbors house is about 300 ft. So no issue there. And the living areas are separated from my theater room by the garage. The theater is connected to the house by only one wall and that wall is shared with the garage. the attic the theater shares only with the garage so sound isolation from my family or neighbors is not an issue. Its just a matter of not wanting my room to be detrimental to the sound system..
MALIX is offline
Old 08-26-2013, 03:08 PM
Mike Garrett's Avatar
Quoted: 5613 Post(s)
Liked: 3594
I have a single layer of drywall, but it is glued and screwed to 6" studs. Drywall does not make noises in my room. Two SI-18's, One Mal-X 18 and two TC Sounds 12's. Soon to add a couple TD18H+ drivers.
mjgarrett100@gmail.com
Mike Garrett is offline
Old 08-26-2013, 03:09 PM
MKtheater's Avatar
Liked: 1123
All the above! The best way to sound proof a room is to build a room within a room with gaps or air space in between. Concrete will keep in bass but how many have concrete ceilings! I have soundboard, drywall, more sound board, heavy insulation, and concrete outerwalls. The inner walls and ceilings are what I said. I never used GG.
Marantz 7702 Atmos
