Theater sub build - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 08-29-2013, 09:08 AM - Thread Starter
alanhenson's Avatar
Quoted: 32 Post(s)
I'm building my own sub system for a dedicated home theater. My question for the gurus is what sub setup. I mean I could build 12 18s and have massive bass at a certain frequency while others suffer. Wouldn't building a sytem with say 4 18s, 4 12s and maybe 4 10s cover the bass spectrum much better?
alanhenson is offline
post #2 of 4 Old 08-29-2013, 12:42 PM
BassThatHz's Avatar
Quoted: 2034 Post(s)
Liked: 1564
You are better off going with a dual car sub, dual PA sub combo, for lower and upper bass.
They complement each other very well.
That's what I did, and it's awesome.
You can't beat PA subs for upper bass, they are 99db/w or better usually, or about 10x more efficient than a 89db/w car sub.
BassThatHz is offline
post #3 of 4 Old 08-29-2013, 12:51 PM
Mrkazador's Avatar
Quoted: 252 Post(s)
Liked: 378
A 18" sub shouldn't have a problem going up to 120hz so I don't see why you would mix different sized drivers.
Mrkazador is offline
post #4 of 4 Old 08-29-2013, 04:10 PM
Bill Fitzmaurice's Avatar
Liked: 4656
It would if anything be worse, and the unnecessary complication of having to tri-amp would greatly add to expense and system complexity. As for the need for twelve eighteens, only the very largest of rooms need more than four.
Bill Fitzmaurice is offline
