Converting passive woofers in a tower speaker to active woofers? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 08-31-2013, 12:41 AM - Thread Starter
bradleyedward's Avatar
Okay so I have some older Kenwood tower speakers I snagged off craigslist for next to nothing just for fun computer speakers. However, my roommate's tiny little Logitech subwoofer is MUCH louder and punchier than my 15" passive woofers. This may be a stupid questions, but could I add plate amps to these speakers and turn these 15" woofers into powered subwoofers?
I'm very interested at getting into DIY projects and don't have much experience. So if this is possible, please point me in a direction or explain to me in a simple way.
Here are the speakers:
http://i.imgur.com/OPIKCcL.jpg
bradleyedward is offline
post #2 of 12 Old 08-31-2013, 04:05 AM
qguy's Avatar
Quoted: 122 Post(s)
Liked: 91
They should be better than most PC speakers, What amp are you using to drive them ?
If you use a plate amp for a subwoofer, you would be loosing the woofer in the three way speakers and would create a hole in the response as there would no longer be a woofer
qguy is offline
post #3 of 12 Old 08-31-2013, 10:20 AM
LTD02's Avatar
Quoted: 2340 Post(s)
Liked: 2574
how did you hook them up to your computer?
Listen. It's All Good.
LTD02 is online now
post #4 of 12 Old 08-31-2013, 02:39 PM
A9X-308's Avatar
Quoted: 1280 Post(s)
Liked: 951
They are not sub drivers.
A9X-308 is offline
post #5 of 12 Old 08-31-2013, 04:21 PM
Thatsnasty's Avatar
Quoted: 51 Post(s)
Liked: 42
You can add new 15" drivers and plate amps and turn them into sub-woofers... but, like Alpha Niner said, the drivers are more of a woofer then a sub-woofer and will probably blow up if you try to use them that way.
You're better off just leaving them how they are and building something cheap for sub duty... maybe an anarchy tapped horn, or a cheapo sealed / ported infinity 1260 12"
Thatsnasty is offline
post #6 of 12 Old 08-31-2013, 05:25 PM
Manic1!'s Avatar
Quoted: 172 Post(s)
Liked: 73
Just add a cheap powered sub.
Manic1! is offline
post #7 of 12 Old 08-31-2013, 06:22 PM
qguy's Avatar
Quoted: 122 Post(s)
Liked: 91
Those 15 inch woofers should be able to play at least 35 hz. or even 30 hz, Pretty sure the the TS has them underpowered or worse their wired out of phase. Give it some juice and it should provide ample bass, not subwoofer kind of bass, but should be decent enough.
As for conveting them into subwoofers, that depends on the woofer itself, I have converted 12 inch kenwood and KEF woofers into subwoofers and their fine.
qguy is offline
post #8 of 12 Old 08-31-2013, 10:06 PM
Looneybomber's Avatar
Liked: 25
Stupid question, did you change the speaker settings in the computer to large and fiddle with the eq?
YID DIY
Looneybomber is offline
post #9 of 12 Old 09-01-2013, 07:07 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
These speakers are problematical. The woofer drivers in them are probably cheaper than cheap. They no doubt lack what it takes to deliver good bass. No amount of good electronics are going to overcome that absence of worth.
If the boxes have a good real wood veneer on them, and were solid they might be the basis for a thorough going re-engineering project, but you don't seem to be experienced enough with this sort of thing to have a good chance of success.
arnyk is offline
post #10 of 12 Old 09-01-2013, 07:13 AM
Bill Fitzmaurice's Avatar
Liked: 4629
+1, and what EQ?
Bill Fitzmaurice is online now
post #11 of 12 Old 09-05-2013, 12:34 PM - Thread Starter
I'm using an older 5.1 Kenwood receiver. I haven't changed any EQ settings and am playing everything through "direct"
post #12 of 12 Old 09-05-2013, 03:07 PM
qguy's Avatar
Quoted: 122 Post(s)
Liked: 91
Use "Stereo" setting, then adjust the bass from the AVR or use the EQ (if you have) from the PC if your using a PC as source
qguy is offline
