need help with system in a 3k sqft room 2 huge nulls - AVS Forum | Home Theater Discussions And Reviews
Old 08-31-2013, 10:05 PM - Thread Starter
davece's Avatar
ok heres a quick drawing and no it s not to scale , and yes my drawing skills suck
the black is the outer walls, and the piece that hangs into the room is part of that wall , the table in the center on the left is the dj table
above and below that the red rectangles represent the 3 micro wreckers per side , and the mains are the black dots, theese are stacked ontop of the micros
ive got 300w rms to each main , and 450w rms to each micro
right infront of the dj table sound is great , then u see the 2 blue lines.
in between these 2 blue lines bass is gone , u can feel the floor shake like mad but cant hear it.
from the second blue line on the right to the green line sound is great again , and then from the green line to the back wall its gone again , its about a 5-7 ft span i drew the green line in the wrong place
any ideas ?
davece is offline
Old 08-31-2013, 10:08 PM
Looneybomber's Avatar
Liked: 25
Can you spread those micros out onto other walls?
YID DIY
Looneybomber is offline
Old 08-31-2013, 10:11 PM - Thread Starter
davece's Avatar
i take it ur meaning from the left wall behind the dj table to the wall on the bottom then face them twards the top of the drawing?
i could do that but what kind of funky delays would i need
davece is offline
Old 08-31-2013, 11:18 PM
LTD02's Avatar
Quoted: 2344 Post(s)
Liked: 2582
read all of this!
http://forum.blu-ray.com/showthread.php?t=48286
then if possible move the whole system for to about 20% of the way into the room...and move the bottom subwoofer array up toward the table...
Listen. It's All Good.
LTD02 is offline
Old 08-31-2013, 11:23 PM
Manic1!'s Avatar
Quoted: 175 Post(s)
Liked: 75
Subs should be coupled for maximum output.
Manic1! is offline
Old 09-01-2013, 12:29 AM - Thread Starter
davece's Avatar
read all of this!
thank u that was a good read and still have some to read on it.next time i dj in that room i am going to try all 8 microwreckers with a pair in every corner with the phase reversed on the back wall, when ever i dj there i have a day before to setup
moving them into the room further is not an option , it gets very crowded in that room so moving the system and setup inboard off the wall is a no go
davece is offline
Old 09-03-2013, 10:27 PM - Thread Starter
davece's Avatar
i ended up stacking all 6 subs in the lower left corner and corner loading them , holy crap what a difference , i have one minor null at the very back of the room that is about 2 ft wide across the width of the room.
i can live with that for sure. only downside is now i dont have anything to put my mains ontop of , ill have to use some of my leftover wood from the micros and build some stands to get my mains back in the air
i also made the mistake of standing in that corner with all 6 at war volume , talk about an experience lol
davece is offline
Old 09-04-2013, 06:07 AM
Bill Fitzmaurice's Avatar
Liked: 4678
Sometimes yes, sometimes no. It depends on the room size and the system bandwidth. In medium sized pro-sound, where rooms tend to be fairly large and bandwidth only goes to 30-35Hz, single clusters tend to work best, as explained here:
http://www.prosoundweb.com/article/in_search_of_the_power_alley/
In very large pro-sound venues, where the room is at least 4 wavelengths wide and the sub stacks can be placed at least 2 wavelengths apart, split clusters regain the advantage. In home theater sized rooms, where the room is 2 wavelengths and less in dimension, multiple subs will usually work best when separated as far as possible,
Bill Fitzmaurice is online now
Old 09-04-2013, 06:14 AM
MemX's Avatar
Quoted: 55 Post(s)
Liked: 64
MemX is offline
