Have a question about relays and the 12v trigger from my receiver. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 09-03-2013, 10:29 PM - Thread Starter
Mrkazador's Avatar
Quoted: 252 Post(s)
Liked: 378
I probably should have asked before buying anything but I bought this relay to switch on a 12v pc fan that is triggered by the receivers 12v trigger.
http://www.digikey.com/product-detail/en/1461069-5/PB1321-ND/3318145
That relay should work right? I did some reading and people recommend adding a diode (1N4001??) to prevent current from going back into the trigger. Is this right? If so, where would the diode connect to exactly? I'm new to all this so any help would be great!
So I found this image which I assume is correct.
http://www.bcae1.com/relays.htm
Mrkazador is offline
post #2 of 13 Old 09-04-2013, 06:53 AM
NicksHitachi's Avatar
Quoted: 182 Post(s)
Liked: 189
FWIW I've been using relays like that for years without any diodes. I haven't had any problems but YMMV.
Also, I find these worth the extra dollar to have the diodes, leds, and terminal blocks already on a circuit board. Before I used these I did exactly what your doing but I turn on my EP4000 with a DIY relay board.
EP4000 12V Trigger Mod.
Cheers!
NicksHitachi is offline
post #3 of 13 Old 09-04-2013, 07:14 AM
paskal9's Avatar
Liked: 24
it is indeed correct.
the diode is there to protect the trigger circuit from reverse current when the relay coil magnetic field collapse.
normally an amp external trigger is already protected but if it weren't then the discharge will surely destroy it.
paskal9 is offline
post #4 of 13 Old 09-04-2013, 07:17 AM
paskal9's Avatar
Liked: 24
and also make sure the diode polarity is wired correctly.
the diode negative pole must be connected to the trigger positive output. reverse that and it will also destroy the trigger. smile.gif
paskal9 is offline
post #5 of 13 Old 09-04-2013, 08:38 AM - Thread Starter
Mrkazador's Avatar
Quoted: 252 Post(s)
Liked: 378
post #6 of 13 Old 09-04-2013, 09:22 AM
paskal9's Avatar
Liked: 24
This diode would work?
http://www.radioshack.com/product/index.jsp?productId=2036268
or one thats rated higher?
http://www.radioshack.com/product/index.jsp?productId=2036270
both should be fine, but since they're similarly priced get the 1N4004.
paskal9 is offline
post #7 of 13 Old 09-04-2013, 11:01 AM
pitviper33's Avatar
Quoted: 267 Post(s)
Liked: 116
What are you using as your 12V power source? Will it just be running all the time? I'm just thinking it might make more sense to switch upstream of the source so that it's not running when the system is off.
pitviper33 is offline
post #8 of 13 Old 09-04-2013, 11:16 AM - Thread Starter
Mrkazador's Avatar
Quoted: 252 Post(s)
Liked: 378
I'll be using a 12v ac-dc wall wart which would be on all the time.
post #9 of 13 Old 09-05-2013, 09:22 PM - Thread Starter
Mrkazador's Avatar
Quoted: 252 Post(s)
Liked: 378
Another thing I just noticed. The mono 3.5mm plug I got is rated for 6vdc 1a... Is this going to be a problem? The relay draws 30ma if that helps.
post #10 of 13 Old 09-06-2013, 01:05 AM
paskal9's Avatar
Liked: 24
not gonna be a problem. with any plug (or any cable) its the power rating (voltage x current) that's more important than voltage or current alone.
the tip of the plug is usually the positive pole. if you have a multimeter confirm the polarity before wiring the diode.
paskal9 is offline
post #11 of 13 Old 09-06-2013, 08:33 AM - Thread Starter
Mrkazador's Avatar
Quoted: 252 Post(s)
Liked: 378
Thanks, I will check polarity with a multi meter.
post #12 of 13 Old 09-07-2013, 12:49 PM - Thread Starter
Mrkazador's Avatar
Quoted: 252 Post(s)
Liked: 378
I finished building it and it works fine, thank you everyone for the help. I made this crude drawing so if anyone wants to build it
Parts I used from Digikey
CR282-ND - http://www.digikey.com/product-detail/en/09080-G/CR282-ND/250523
PB1321-ND - http://www.digikey.com/product-detail/en/1461069-5/PB1321-ND/3318145
CP3-1005-ND - http://www.digikey.com/product-detail/en/MP3-3501/CP3-1005-ND/992141
WM4201-ND - http://www.digikey.com/product-detail/en/0022232031/WM4201-ND/26669
and from Radioshack
1N4005 - http://www.radioshack.com/product/index.jsp?productId=2049728
post #13 of 13 Old 09-07-2013, 07:02 PM
Quoted: 182 Post(s)
Liked: 189
Thats the DIY spirit son!
