TV speakers too loud at lowest volume setting - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 09-04-2013, 12:07 PM - Thread Starter
haqattaq's Avatar
I have a new 39-inch Toshiba LCD in a bedroom and the sound is actually too loud on the lowest volume setting. The previous CRT that this replaced, had much lower volume.
The difference between the lowest setting (1) to (0) is too great. I was thinking of taping something over the speaker so volume would be softer however I don't want to 'muffle' the sound to a point where its not clear.
Does anyone have a creative idea on what i could try other than tape cloth over the speaker?
haqattaq is offline
post #2 of 8 Old 09-04-2013, 12:21 PM
BassThatHz's Avatar
Quoted: 2296 Post(s)
Liked: 2038
You could take it apart and solder a resistor on each speaker, probably adding another 8-ohms should do it.
BassThatHz is offline
post #3 of 8 Old 09-04-2013, 01:01 PM
nograveconcern's Avatar
Quoted: 91 Post(s)
Liked: 128
Or maybe just pick up some computer speakers and try running the audio out of the TV into those. I have to think there must be a setting somewhere buried in the menu system of the panel that has enable some kind of dynamic volume or something. Have you referenced the manual?
nograveconcern is offline
post #4 of 8 Old 09-04-2013, 06:36 PM
BassThatHz's Avatar
Liked: 2038
Originally Posted by nograveconcern View Post
Nah, that's all wrong...
7 of these
http://www.higherfi.com/spkrlist/speakerlist.php
and 7 of these should fix it.
http://www.higherfi.com/spkrlist/speakerlist.php?category=amps
post #5 of 8 Old 09-04-2013, 07:04 PM
Mrkazador's Avatar
Quoted: 262 Post(s)
Liked: 390
Are you using a cable box or antenna? If you're using a cable box or something similar, I was thinking you can add some kind of volume control on the rca jacks or a resistor to lower the output voltage.
Mrkazador is offline
post #6 of 8 Old 09-05-2013, 09:27 AM - Thread Starter
haqattaq's Avatar
Are you serious? Of course i haven't!
But when i did look through the manual, I discovered that the mute button has 2 levels when you press it, full mute and half mute. So last night i was able to lower the volume to 2, then press mute and still hear just fine without any complaints. doh!
haqattaq is offline
post #7 of 8 Old 09-05-2013, 09:34 AM
Bill Fitzmaurice's Avatar
Liked: 5623
Bill Fitzmaurice is online now
post #8 of 8 Old 09-05-2013, 01:09 PM
ozziedog's Avatar
Liked: 24
I thought this statement was breaking the man rules!
ozziedog is offline
