Large Ported Dayton HO18's - Page 36 - AVS Forum | Home Theater Discussions And Reviews
 26Likes
post #1051 of 1079 Old 10-27-2014, 08:58 PM
BacHolz's Avatar
Quoted: 17 Post(s)
Liked: 34
Originally Posted by fperra View Post
You mean like this?
Thanks for sharing these, they are fantastic. Your shop a few pics earlier ain't shabby either. Well done...
BacHolz is online now
post #1052 of 1079 Old 10-28-2014, 08:12 AM
Liked: 0
Yep, that's what I mean(t). Plans? Or is it a secret?
babadono is offline
post #1053 of 1079 Old 10-28-2014, 09:35 AM
fperra's Avatar
Quoted: 50 Post(s)
Liked: 71
Another Marty Sub
fperra is offline
post #1054 of 1079 Old 10-28-2014, 04:42 PM
Liked: 0
Any expert opinions on these vertical Marty subs? Are they going to give the same performance?
fperra, have you made any measurements on these?
babadono is offline
post #1055 of 1079 Old 10-28-2014, 04:44 PM
Liked: 0
fperra,
BTW those are b-e-a-u-t-i-f-u-l. Awesome job.
babadono is offline
post #1056 of 1079 Old 10-28-2014, 04:59 PM
fperra's Avatar
Quoted: 50 Post(s)
Liked: 71
Only with my ears and seat of the pants since they shake the chair I sit in watching movies.
fperra is offline
post #1057 of 1079 Old 10-29-2014, 01:35 AM
LTD02's Avatar
Quoted: 2525 Post(s)
Liked: 2868
"Any expert opinions on these vertical Marty subs? Are they going to give the same performance?"
vertical or horizontal will have some different effects in how they work with the walls/floor etc. and it can't really be said that one will be better than the other. so as far as a rule of thumb, the performance will be the same whether upright or horizontal or even sideways as in the Cyclops design.
Listen. It's All Good.
LTD02 is offline
post #1058 of 1079 Old 11-05-2014, 03:17 AM
Liked: 0
Well I got the enclosure together finally. Sub is mounted in it and ive been playing with it since late Sunday evening. Playing test tones it went as low as 14 hz, after that it just sort of dropped off. Much better than my dayton sub 1200 which was dropping off at 28 hz. I ended up using an ultimax 18 in this box instead of an ultimax 15. This sub is supposed to be going into my living room but im having a hard time going back to the sub 1200 in the office after having heard this one. Ill probably end up building a mini marty or maybe a cube now.
SilkyJohnson1989 is offline
post #1059 of 1079 Old 10-28-2015, 04:42 AM
Quoted: 157 Post(s)
Liked: 68
I've never built a speaker or sub before and I was wondering if anyone could help me out. I have 3 JBL 4722's and want to put them behind a AT screen. Could I modify a full or mini marty to match the 17.5" depth of my JBL's? Space is limited. Thanks!
podboy is offline
post #1060 of 1079 Old 10-28-2015, 05:20 AM
BCRSS's Avatar
Quoted: 293 Post(s)
Liked: 227
You may want to look here for the Stonehedge. http://www.diysoundgroup.com/18stone...structure.html
All gone for now---->The Elusive 1099 (L/C/R)---6 DIY Volt 10 (surrounds 9.4)---SVS PB 12 Plus---SVS PC 12 Plus---2 DIY 18's sealed--2 Pico Wreckers (tapped horns)---AVR Denon 4311CI---Emotiva Xpa-3---Behringer Nu6000DSP & Nu3000DSP iNuke---TV Vizio 70---110" Motorized Screen---Epson 8350 Projector---Unraid Network Storage---Gateway SX 2370 HTPC with 120 SSD
BCRSS is offline
post #1061 of 1079 Old 10-28-2015, 06:33 AM
Quoted: 157 Post(s)
Liked: 68
That's perfect except they're out of stock with no plans to make any more.
podboy is offline
post #1062 of 1079 Old 10-28-2015, 12:41 PM
kmhvball's Avatar
Quoted: 542 Post(s)
Liked: 301
@squiers007 I think makes some, you could find him in this thread, or even post your same question over here.. MartySub FAQ
kmhvball is offline
post #1063 of 1079 Old 10-28-2015, 12:48 PM
ESSNEFF's Avatar
Quoted: 21 Post(s)
Liked: 7
Originally Posted by Martycool007 View Post
Wow! Thanks the help guys! Being that I have a Lowes and a Home Depot locally, I believe they both have the pre-cut 2' by 4' and 2' by 2', I think that I will go with the last design that LTD02 suggested using the 2' by 4' panels that are available pre-cut.
If I do that, what would be the optimal slot port for either a 16hz tune, or a 17hz tune? I like the idea of using a side ways slot port, I just need to figure out the optimal hight width, and depth of the slot port, and the hight, width, and depth of the front baffle?
The rear panel would just use a complete 2' by 2' sheet, right?
Make sure to measure those..........The one's I bought were NOT exactly 24" x 48".
Just a head's up.
ESSNEFF is offline
post #1064 of 1079 Old 12-17-2015, 03:25 PM
mikectm2's Avatar
Quoted: 20 Post(s)
Liked: 6
I'm re-doing a box that is 2' x 2' x 44" long. .....3/4" Baltic Burch
Rather than constructing a slot port (which is fine ) ..we're gonna try the two corner / triangle ports.
The internal dimensions of the box are 22.5" x 22.5" x 42.5"
So each triangular port will be (measured internally ) 7" tall x 7" wide x 40" long ....hope we have that right. This is for the Dayton RSS460HO-4
Here's the box originally
Now we're putting on a new front baffle
The old one is already off
LTD02 and JohnDean like this.
mikectm2 is offline
post #1065 of 1079 Old 12-18-2015, 06:31 AM
Quoted: 517 Post(s)
Liked: 59
I currently have two Marty subs with the 18" Dayton 460HO's. I am framing the baffle wall in my new dedicated by room this weekend, and only have 2.5' behind the baffle wall. So being as I want to have my two Marty subs in the baffle wall, (I will soon build two more that I can put in the rear) I am going to have to build some new Marty Sub enclosures that are vertical with the subs and port mounted in the front.
With that in mind, I can't decide if I want to do slot ports again or round ports. Here is a question for LTD02..If I go slot ports in the front, how long should they be, and how should the snake up the back of the enclosure? Or if I use round ports, what size should they be?
Tip24/96 is offline
post #1066 of 1079 Old 12-18-2015, 11:19 AM
squiers007's Avatar
Quoted: 757 Post(s)
Liked: 378
I know I'm not LTD02, but I thought I'd chime in.
Which Marty Sub? The box size, port area, and tuning will determine port length.
Check out my End-Table Marty Build
squiers007 is offline
post #1067 of 1079 Old 12-20-2015, 09:12 AM
Shadowed's Avatar
Quoted: 705 Post(s)
Liked: 630
Are you putting any bracing and absorption liner inside ?
Shadowed is offline
post #1068 of 1079 Old 12-20-2015, 01:04 PM
LTD02's Avatar
Liked: 2868
@Tip24/96
if you keep the internal volume of the sub the same, then the size of the slot would remain the same.
for an angled slot, just measure down the middle of the port. if it is off by an inch one way or another, it won't matter.
if you get stuck, shoot me a pm. it was just by chance that i saw your question here.
LTD02 is offline
post #1069 of 1079 Old 12-20-2015, 01:22 PM
mikectm2's Avatar
Quoted: 20 Post(s)
Liked: 6
Shadowed
Just about six 1 3/8" dowel pieces of wood.
Nothing at all for lining the box.
Had thought to just throw in 5lbs of polyfill ..acquired from Parts Express
But i have read that in a ported box ..this acustastuff polyfill isn't so important
But that lining the box is.
How many walls should be lined ?
I do have some that egg crate looking stuff up in the rafters of the garage
LTD02 is in the house !
LTD02 ..did you get the original idea for this MartySub in anyway from the 2001 Adire Audio Tempest EBS design plans ?
mikectm2 is offline
post #1070 of 1079 Old 12-20-2015, 01:36 PM
Shadowed's Avatar
Quoted: 705 Post(s)
Liked: 630
Shadowed
I think the back wall and sides should be lined. I don't know if the backside of the baffle needs it.
As per your other thread question, I am getting similar lengths as LTD02 for your triangle ports.
2 ports approx. 40" long to get into the 18hz tuning.
I don't think you have enough room for that length and still leave enough space for the inside end of the port opening.
Shadowed is offline
post #1071 of 1079 Old 12-20-2015, 01:39 PM
Shadowed's Avatar
Quoted: 705 Post(s)
Liked: 630
To reply to someone, or get their attention, Use @LTD02
(or just reply to their post)
LTD02 likes this.
Shadowed is offline
post #1072 of 1079 Old 12-20-2015, 03:15 PM
LTD02's Avatar
Liked: 2868
the marty sub came out of a request from a forum member, martycool007, who was looking for something that would be relatively simple to build and would maximize performance of the 460ho driver. in its original conception the large panels were 24"x48" +/- (i.e. pre-cut handi-panels available from h.d.) and the smaller panels required only one cut. starting with the handi-panels (assuming the ones purchased are all the exact same width), only crosscuts (and driver cutout) are required to complete the entire cab. so in this case, it was more about the availability of materials and construction method than the size and tuning of the cab. the so-called mini-marty achieves almost all of the performance, is a little smaller, but requires a little more chopping.
DIY Subwoofer help needed after reading.
the relative simplicity and cut-sheet friendly 2' wide panels survive though. :-)
LTD02 is offline
post #1073 of 1079 Old 12-30-2015, 09:28 PM
scsmitty's Avatar
I've built many sealed subs before. Im ready to get into the ported game now. i have 2 Dayton ultimax 18s and a Inuke 6000DSP on the way. Am I correct in thinking that the marty's would be good for the subs I bought? I was running a WMD18 in a sealed 4cu ft box with an EP4000. I need more low bass. This setup might be a little over kill being that it will be in a 1400 cu ft room.
scsmitty is offline
post #1074 of 1079 Old 12-30-2015, 09:34 PM
LTD02's Avatar
Liked: 2868
those drivers do a little better in the big cabs, so if the full size is possible go for that. if not, the revised minimarty is another option.
there are also other form factors that will perform more or less the same. the Cyclops build comes to mind. also, the big cabs that notnyt designed. lots of options. probably best to figure out what form factor you would like then hunt around for a design. there are countless designs floating around that will work just fine with the um18's.
LTD02 is offline
post #1075 of 1079 Old 12-30-2015, 09:46 PM
scsmitty's Avatar
I have no problems using the big ones. I like the 2' x 2' x 4' size. I can use 1 up front and 1 behind my seats. These should pressurize my small room nicely.
scsmitty is offline
post #1076 of 1079 Old 12-30-2015, 09:57 PM
scsmitty's Avatar
Thanks for the quick reply LTD02. What exactly was the port length? ive seen a few different numbers. I should be able to have these done this weekend. Subs wont be here till Tuesday so I can take my time building them. Just need to decide on a finish for them.
scsmitty is offline
post #1077 of 1079 Old 12-30-2015, 10:02 PM
LTD02's Avatar
Liked: 2868
cool, and i think so too. :-)
LTD02 is offline
post #1078 of 1079 Old 12-31-2015, 09:01 AM
scsmitty's Avatar
Ok. Just to make sure ( I dont want to screw this up). The port size is 21.0" wide X 3.0" tall X 36.0" long?
scsmitty is offline
post #1079 of 1079 Old 09-12-2017, 07:35 PM
samarmstrong's Avatar
Long thread, but can someone please specify the practical port measurements after all these various builds with the best tune around 15 Hz. TIA.
samarmstrong is offline
