2x SEOS Fusion-12 Tempest + Fusion-8 Alchemy MTM build thread - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #61 of 68 Old 11-18-2013, 09:45 AM - Thread Starter
amo76's Avatar
Quoted: 16 Post(s)
Since you are planning on building the box yourself I assume that you have all required tools (incl. a router). I highly recommend going with a flat pack (Erich has one for MTM), saves so much time and you don't have to eat MDF dust. If you get all items you have listed, you should be good to go. I highly recommend duratex if you decide to paint the box.
amo76 is offline
post #62 of 68 Old 11-18-2013, 05:24 PM
chalugadp's Avatar
Quoted: 1673 Post(s)
Liked: 1531
I'm a woodwork teacher so making the box will take less then an hour. And all the tools are free biggrin.gif
chalugadp is offline
post #63 of 68 Old 11-18-2013, 08:52 PM - Thread Starter
amo76's Avatar
Quoted: 16 Post(s)
Maybe I should outsource my next box building project to you. Took me more than an hour (or two).
amo76 is offline
post #64 of 68 Old 11-18-2013, 09:15 PM
chalugadp's Avatar
Liked: 1531
Well when you have a dozen clamps it makes it a lot easier . Yeah you can send me your build with drivers and stuff , I'll get them back to you in a few years biggrin.gif
post #65 of 68 Old 03-07-2014, 06:53 PM
WarrenBerry's Avatar
Quoted: 43 Post(s)
Liked: 52
I bought the same grill kit. What do your speakers look like with it on? I see in your pic you covered the 3 ports. Does dust build up on them? Do you have to clean them? Was thinking terminating the grills just above the ports to allow good air/dust flow.
WarrenBerry is offline
post #66 of 68 Old 08-02-2014, 12:32 PM
kevings's Avatar
Quoted: 298 Post(s)
Liked: 464
kevings is offline
post #67 of 68 Old 08-03-2014, 03:36 AM
mtbdudex's Avatar
Quoted: 79 Post(s)
Liked: 771
Originally Posted by amo76 View Post
Decided to keep the speaker grill frame kits I purchased from PE and spent the evening yesterday putting them together.
I didn't really need to purchase three kits, two would have been enough but I should have purchased an extra T-Joint Kit for Alchemy MTM. I am going to order one today.
Duratex is arriving today and I'll start painting my boxes. How long does it takes for it to dry before I can apply the second coat?
I'm starting to see the finish line or is it a mirage?
Here is the picture of the finished speakers:
How do they look with speaker grilles on?
Did the PE plastic grilles fit around or over the wavegides?
Looks kinda tight so over is my guess
Would you use the PE kit again?
mtbdudex is online now
post #68 of 68 Old 08-11-2014, 02:39 PM - Thread Starter
amo76's Avatar
Quoted: 16 Post(s)
I ended up not using the grilles. They felt a bit bulky to my taste. At this point speakers are sitting uncovered. I purchased these 2 items instead but didn't get a chance to mount them yet.
Steel Mesh 2-Piece Grill for 8" Speaker Black
Part # 260-424
Steel Mesh 2-Piece Grill for 12" Speaker Black
Part # 260-428
amo76 is offline
Fusion 8 Inch Super Slim Under Seat 300w Amplified Subwoofer
