Small air leak in screw area of sub box after box build and sub install - AVS Forum
post #1 of 14 Old 09-19-2013, 06:27 PM - Thread Starter
04rex's Avatar
I noticed that after I built the boxes and put the subs in, if I pushed the sub in there was a tiny amount of an air leak on one of the screw areas for 3 of the subs (I have 4 total). I tried to tighten the screw but it doesn't go anymore. How will this affect sound quality and is there an easy fix to it?
04rex is offline
post #2 of 14 Old 09-19-2013, 06:28 PM
LTD02's Avatar
Quoted: 83 Post(s)
Liked: 808
did you use a gasket?
Listen. It's All Good.
LTD02 is online now
post #3 of 14 Old 09-19-2013, 06:35 PM - Thread Starter
04rex's Avatar
I used what came and was attached to the sub. I didn't look actually. But it should come with one I assume.
For it to happen to 3 out of 4 subs is very weird.
04rex is offline
post #4 of 14 Old 09-19-2013, 06:40 PM
wormraper's Avatar
Liked: 38
ahhh, probably should have used gasket tape around the edge before you mounted it...
wormraper is online now
post #5 of 14 Old 09-19-2013, 06:41 PM - Thread Starter
04rex's Avatar
I notice a noise. Like a fluttering or something. Could that be the issue of the noise? My boxes are sealed btw.
04rex is offline
post #6 of 14 Old 09-19-2013, 06:46 PM
steve nn's Avatar
Liked: 425
Your driver is mounted nice and flat correct? What I'm trying to ask is it fits in the cutout fine.
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
On-going SW management class
Denon
PS3
steve nn is offline
post #7 of 14 Old 09-19-2013, 06:50 PM - Thread Starter
04rex's Avatar
Fit perfectly. 3 out of the 4 have this issue.
What does that fluttering sound indicate?
04rex is offline
post #8 of 14 Old 09-19-2013, 06:58 PM
wormraper's Avatar
Liked: 38
Get some foam weatherstripping from the hardware store and put around the cutout edge. Reinstall driver and u should be good to go
post #9 of 14 Old 09-19-2013, 07:06 PM
steve nn's Avatar
Liked: 425
That’s most likely the air coming out of the leak! There is nothing like building a sealed sw and then taking your finger tips and press into the driver. You want it to be stiff and no whoosh sound from a leak! Go with what worm suggests then.
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
Denon
PS3
steve nn is offline
post #10 of 14 Old 09-19-2013, 07:13 PM - Thread Starter
04rex's Avatar
I think I will. Any weather stripping or a certain type or thickness?
04rex is offline
post #11 of 14 Old 09-19-2013, 07:18 PM
wormraper's Avatar
Liked: 38
Just get some decently thick foam tape. They sell foam weather stripping for RVs at home depot that works. Or get a roll of speaker gasket tape from PE
post #12 of 14 Old 09-19-2013, 07:32 PM - Thread Starter
04rex's Avatar
Ok I will. Thanks again.
04rex is offline
post #13 of 14 Old 09-20-2013, 11:03 AM
noah katz's Avatar
Quoted: 35 Post(s)
Liked: 125
You wouldn't think it would make a sound like that, but when I had a screw leak once it made a ticking sound (with a test tone).
Noah
noah katz is offline
post #14 of 14 Old 09-21-2013, 08:53 PM
chilort's Avatar
Liked: 55
When I built my first (and currently only) horn sub, LilMike recommend Duct Seal to seal the driver. I used it. It seems to work. I don't wan to ever have to remove it, but it would likely roll off ok.
http://www.idealindustries.com/prodDetail.do?prodId=duct-seal&div=5&l1=accessories
It can be found at Home Depot or Lowes in the electrical department. It is used for sealing the elements out of electrical boxes.
chilort is offline
User Tag List
